Hi, just noted this in your code. FYI: This is decluttering card variable format.
I remember when I started with HA and that Google (these days AI) would lead me down strange paths that just would not work. Usually it was following some example where context was not fully documented.
Good feedback. Thanks I can see where the documentation can be improved. `popup_card_idā is new feature and would lead you to think it would just work the way you expect. However there is the need to work with the way Home Assistant services work, and that Browser popup service can work both ways. The doco should have both methods in that section.
Hello everyone, Iāve been sitting in front of my PC for hours now trying to get Browser_Mod to work in Home Assistant.
What Iāve managed to do:
I can easily display a pop-up with text.
alias: 1 Test Stream Haustür Kamera
description: āā
triggers:
trigger: state
entity_id:
input_boolean.testschalter
to: āonā
conditions:
actions:
When streaming from a Reolink camera, no image appears, only the pop-up runs for 30 seconds. But no stream is displayed. The camera is integrated into Home Assistant and works.
Can anyone tell me what the problem is?
THX Reinhard
Hi. Itās likely a network/url issue of the media source stream, in that the resolved media url canāt be played by the Browser. If this is not working on your desktop, checking the browser console log will likely have an error to help you along. If it is a device that is not working, then you can try the Browser Mod media player for that device. If it fails, look at the media player device in states tab if Developer tools, look at the attributes to find the url that was attempted.
Usual issues here is that the Browser is using https to access Home Assistant, perhaps cloud, but the media is being streamed by http using local network URL. Another issue if both are http is that one is a named url and one an IP address, then being a CORS issue. All these sort of network issues can be first managed by checking your local and cloud URL in network settings. You can also set cors_allowed_origins under http in configuration.yaml if required.
One question: i guess that media player (and with that the need for interaction) canāt be disabled (so that itās not created at all) if itās not in use? I only use fullyās media player, so if this interaction is only for media player it can be somewhat annoying, especially this new one where you HAVE to press on play icon exactly. I already got a call from my family member that āthereās a huge icon across the screen and i canāt do anything with HA no matter where i pressā. So, i think that this precise clicking can be a problem with some people.
Ok, i guess that one option is just to hide interaction icon in settings�
I had not expected this would be required for so many devices, as there have only been few issues related to audio not available for Browser Mod media player. It looks full interaction is needed more than I thought, but like you, Browser Mod media player is not used so never an issue. I will put full interaction behind a Frontend setting so as to keep the status quo for devices.
Version 2.5.2 Released. This makes the Full user interaction opt via a new Frontend settings which defauls to unset (off), bringing back the prior 2.5.1 experience.
Iām testing V2.5.3 B1 and new service call ābrowser_mod.change_browser_idā.
Question: is current browser mandatory to select? Iād like to change ID of device where i trigger this new service call, so i guess iād need something similar as ābrowser: THISā. Is that possible? Currently if i leave ācurrent browser IDā blank nothing happens.
If thatās possible it would be a great way to change ID of device with non-admin call with button card click. Or, at least is there any command for retrieving current ID? (similar like "return localStorage[ābrowser_mod-browser-idā] " for custom-button-card)
Leave both current_browser_id and new_browser_id blank to get a interactive popup as per the documentation. If Browser call then this will show only on current Browser. If Server call will popup on all Browsers. It is not intended that you use the interactive method as a Server call, but at the same time is easily cancelled.
Changing Browser ID is not intended to be a non-admin operation, nor a non-interactive action. The way the new service is constructued is to make sure that an unintended Browser ID change is not actioned. If you are guiding a remote user on the update, then it would be to press the button you have set to do a Browser call, then select the Browser ID as instructed by yourself. I thought long about the best way to manage this, and any other method comes with various risks, all which may lead to support issues for admins or Browser Mod maintainers in allowing for an unintended Browser ID change.
If wishing to use an advanced solution, my suggestion would be either:
To have a Device management dashboard/view of some kind, and have button-card buttons, perhaps conditionally shown by user, if using different HA users, that use templating to get the current Browser ID to pass to browser_mod.change_browser_id, along with the new (existing) Browser ID. FYI: The best way to get the current Browser ID in javascript is window.browser_mod.browserID.
Use a Home Assistant script as your Browser call action where you can pass browser_id: THIS and new/existing Browser ID, then the script can send browser_mod.change_browser_id.
If using either of these methods you do so at your own risk of unintended Browser ID change.
Thanks, iāll try. It seems that i canāt find beta documentation you mention, though.
For now only thing it works is if i leve all blank - i do get popup window and i can change ID. However, what i must figure out is to change name with only one click (make button card with tap action). code below for example doesnāt work (yet):
type: custom:button-card
tap_action:
action: fire-dom-event
browser_mod:
service: browser_mod.change_browser_id
browser_id: THIS
new_browser_id: new_device_id
refresh: true
register: true
of course, i understand. But in my case i want user to intentional changes ID from random to pre-set one (in button card)
Beta documentation is in dev branch, use link from beta release notes. This is always the case for beta documentation.
browser_id is not a parameter of the service. It is current_browser_id and THIS is not and cannot be supported.
In button/card all action parameters are recursively employable, so you can template current_browser_id: ā[[[ return window.browser_mod.browserID ]]]ā
I canāt stress enough that while I can assist you with Browser Mod knowledge this custom method is not supported as it relies on you protecting that button in some way so it is not pressed on the wrong browser causing an unintended Browser ID change. This comment is as much for you as it is for others reading this, including AI
Yep, i see what you mean - i just did that⦠But, iām on my ātest PCā, so it was intentional ( i hoped that iāll do that).
Your template suggestion works, thanks a lot! I guess iāll solve āwrong browser clickā with a kind of current user condition or current device⦠i know i already tested that for a different purpose a while ago, so it is doable. I do have notes somewhere, i just have to find it among my saved ātestsā.
Allow disable of screen ālightā to prevent any brightness changes to device when using Full Kisok. (Issue #1021)
New service browser_mod.change_browser_id. See SERVICES.md for more information.
Browser ID edit field on configuration page now a combo-box which includes existing known Browser IDs. This may be useful to reset a Browser ID that has been lost.
Fixes
Fix interact console error on touch devices. (Issue #1016)
When Save screen state Frontend setting is active, save screen state on state change. Beforehand screen state was only saved on disconnect from Home Assistant server.
Hello
when i open HA main url, i have to click twice to use the site. The first click is to disabled āBrowser modā icon, i donāt know why?
I run with last version (this behavior occurs recently)
