What bigger issue?
The issue I am experiencing and is displayed in the inspector as a thing between card-mod and custom header, please see this link: Custom Header
Oh. That issue. About an entirely different plugin in an entirely different thread unrelated to both. Silly meā¦
Edit: Ok, you did link it. But this is not the place.
thing is, it could be related, hence my cross post here, wouldnāt have dared if I would have been sure it wasnāt related of course.
reloading the cache (which is very much related to this thread apparently, my browser_id just got reset once more unfortunately) is needed in the other issue to show the frontend correctly, until the error mentioned in the link hits againā¦
maybe these issues are symptoms of another issue, the constant disconnects I see pop up. donāt know which causes which. only thing I see in the home assistant log is endless amounts of:
2020-01-26 17:04:22 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection.2908295216] Client exceeded max pending messages [2]: 512
I see those messages also, I really donāt know where to search what this can be.
Is it possible (and if so, how) to have multiple cards display in a popup? For example, I have four sensors each displayed in their own mini-graph-card. Iād like to have the four of their graphs stacked top to bottom in a popup. I currently can only get one to show up:
- type: entity-button
entity: sun.sun
tap_action:
action: call-service
service: browser_mod.popup
service_data:
title: Popup Example
card:
type: custom:mini-graph-card
icon: "false"
height: 75
font_size_header: 12
font_size: 75
animate: true
hours_to_show: 18
points_per_hour: 2
color_thresholds:
- value: 72
color: "#E23201"
- value: 68
color: "#FEB938"
- value: 64
color: "#6BBCD1"
entities:
- sensor.living_room_temperature
deviceID:
- this
Do note; I am using the sun.sun as just a temporary entity to tie this too while I explore how this all works.
Hi, u should use first a vertical card and then all yours custom mini graph card
That was it, man, I swear I tried everything but a vertical stack card. Thank you; sometimes itās the simplest solution that gets over looked the most.
Thank you very much for this mod @thomasloven ! Love it so far.
Just one question:
Iām using Fully Kiosk browser on an android tablet and would like to turn off the screen (light.tablet) 5 minutes after no interaction on the device. Havenāt found which trigger I need to use to get it done.
Could you please help?
Thereās a setting for that in the FKB app somewhere. Thatās better than to rely on hass to do it for you.
I know but I would like to deactivate the screen only at night.
Thatās why Iām asking
I use this command to display a camera image on a tablet, what to do to make a photo from the camera appear instead of a movie
auto_close: true
command: more-info
deviceID:
- dce9ca7a-98b720e2
entity_id: camera.streaming_enabled
large: true
First-things-first, thanks for this wonderful plugin! I realy love it, but I have a little problem with camera.
Iām using Hass.io with browser_mod on a Huawei tablet Fully (PLUS) with enabled camera access, javascript frontend, and almost everything what i can enable. In the HA configuration.yaml:
browser_mod:
prefix: ābrowser_ā
devices:
mydeviceid:
name: my terminal device
camera: true
In the HA log, browser terminal there is no error, and I can reach every other sensor, binary sensor from this device. Even motion detection!
I have several other generic cameras and those are configured and present in system. Only the camera.my_terminal_device is not showing.
Of course Iāve rebooting the Hass.io and the tablet after every change.
In the Fully, (or even in Chrome) the HomeAssistant website is not asking permission for the webcam and/or the microphone. I use it on http.
What am I missing, what I can do to access camera?
Thanks,
Gabor
Thanks, the direct camera access by Fully is working!
First let me say thanks Thomas for all the amazing components you have created.
I do have a major problem with the popup function though (which my UI design depends heavily on).
Whether I override a more-info dialog with a popup_card OR use browser-mod.popup, the card does work as intended BUT all the other āvanillaā info cards no longer appear (the screen gets greyed out but the standard popup does not appear). I can reproduce the problem on iOS HA app, Safari and Chrome.
Only way to ārestoreā the normal behavior is to force reload the page.
Any idea what could be happening? Thanks
Iāve been setting up browser_mod yesterday / today and this answers so much. Iām also experiencing this bug on Firefox and Iāve been trying to fire out whatās been going on and why things arenāt working. I now see itās also reported on github - more-info does not work after browser mod pop up Ā· Issue #56 Ā· thomasloven/hass-browser_mod Ā· GitHub
Hey, is there some way to get a camera stream to pop up in fullscreen mode rather than windowed? I have some portrait orientation cameras that donāt display nicely unless they are in fullscreen streaming. I tried it like this, but canāt get it to open with fullscreenā¦
- service: browser_mod.command
command: more-info
entity_id: camera.back_stream
deviceID:
- !secret kindle_kitchen_deviceid
large: true
Oh thanks Perry! That was indeed the bug and with the upgrade to 0.105 everything is working great again!
Hi All,
Im trying to use the camera part. But really donāt know how to do this.
The camera: true is added in configuration.yaml in browser_mod part.
Do I need something enable in FKB ?
