Hello - Really like this. I purchased the PRO version of Fully to use with this. Iām having troubles getting the screen to wake up when I want it to. At first it was just showing the light
entity as Unavailable. I changed to display settings to never turn off (system settings). Then I went ahead and turned off the light entity. 10 minutes later, trying to turn it on - HA allows me to flip the switch but it does nothing and then the switch turns off by itself. Iām not super smart about this stuff. Whatās the best way to troubleshoot this? Might it be because I have a very old tablet w/ a very old version of Android (6.0 - no further updates available)?
Good day,
Exactly like @jschwalbe, Iāve purchased Fully Kiosk Browser in order to use the browser_mod entirely.
It seems like browser_mod wonāt detect Iām using FKB at all. No binary_sensor is created for that device.
Iāve created a user specifically for my Pixel C Tablet which has admin rights.
What is weird though is the fact that Fully Kiosk shows a Device ID which is not the same as the one detected by the browser_mod. Iāve cleared the cache several times. Each time I had a different device id from HAās perspective, but still the same device id on fully kiosk.
Any ideas? Thank you!
EDIT: Nevermind, I had to enable JavaScript in the settings. Now I have the binary sensor!
Try adding top: 0
to styles
Works, thx!
I have no doubt this is a blatantly dumb question but whatās the best way to do an easy migration from the old pop up card to this? I have all my pop ups in a separate yaml that I call on the more-info tap action. Am simply looking to replicate this for now
- Uninstall popup-card.
- Install browser_mod.
Thanks Thomas, knew it was a dumb question. Will give it a shot!
Hi Thomas, Iāve used tileboard with fully kiosk, and I had this code to change the timeout of the tablet through a home-assistant event that I sent through an automation:
events: [
command: 'setscreenmode',
action: function(e) {
if (typeof fully !== undefined) {
fully.setScreenBrightness(e.level);
fully.setStringSetting("timeToScreenOffV2", e.timeout);
if (e.timeout == 0) {
fully.setStringSetting("keepScreenOn", true);
fully.turnScreenOn();
else {
fully.setStringSetting("keepScreenOn", false);
fully.turnScreenOff();
Iām now switching to Lovelace, and I was hoping to use browser-mod to control these Fully functions (they are documented by Ozerov), but I have no idea how. Can you please point me in the right direction?
Thanks, Johan
All those options have corresponding commands in the REST interface. That should be easy enough to controll from the Home Assistant backend.
Hi Thomas,
I am trying out your browser_mod, which is awesome by the way. Trying to replace some more-info popups and that seems to work out. Only the attribute large: true doesnāt change a thing, the pop-ups keep appearing as the small version. Any ideas?
Example:
popup_cards:
sensor.attic_temperature:
title: Attic Temperature
large: true
card:
entities:
- entity: sensor.attic_temperature
font_size: 75
line_color: orange
line_width: 8
type: 'custom:mini-graph-card'
Thanks, I was not aware of that option.
Also a big shout out to Andrew Molina for this great link explaining exactly how to do it!
But I have a follow-up:
Using this method I have to define the URL for each tablet (I have 13); can you think of a way where we could use the HA-events bus and process them on the client with Browser_mod, similar to Tileboard?
What is the best approach for splitting out these popups. I am reviewing code from this example: https://github.com/matt8707/hass-config/blob/fe294e98be324ac4dd6b27fb8d4db6c663f78a30/ui-lovelace.yaml and can see on a custom button (which i am using) there is a tap action which has an !include popup/something.yaml
I have tried to replicate this but i get the following error in my logs
Uncaught TypeError: Cannot assign to read only property '0' of string '!include /config/popup/light_office.yaml'
Adding a bunch of popups can make the lovelace-ui.yaml hard to read so splitting out makes more sense. Plus this doesnt take the default more-info panel away.
Edit: It appears i am getting errors because i am not using āyamlā mode for LoveLace. I do my edits via the UI and i dont believe i can use !include tag in this mode.
Hi, is this working for Ring doorbell 2? Thank you.
Hey. Can anyone help me with what css properties I need to set to modify the style of the title of a popup, including the āxā icon?
Thomas, to make it easier to control these āextraā features of Fully on multiple tablets, Iām asking you to consider to add one of these two Textfeatures:
- expose the IP number of a device, so that the IP-numbers of the Fully devices donāt need to be hard-coded
- accept a javascript-key and a value and post that to the device(s). That would also be great to play eg a tone when opening a door on every tablet.
Thank you for considering, Johan
@thomasloven
I am trying to find a good background-color for this browser_mod_popup:
And this is my code:
hold_action:
action: call-service
service: browser_mod.popup
service_data:
theme: darkmix
title: Info RGB
large: false
auto_close: false
style:
border-radius: 20px
--ha-card-border-radius: 20px
card:
type: entities
entities:
- type: custom:slider-entity-row
entity: light.yeelight_strip_2
name: Luce Strip 2
hide_when_off: true
toggle: true
- type: custom:rgb-light-card
justify: center
hide_when_off: true
colors:
- rgb_color:
- 255
- 5
- 5
brightness_pct: 100
transition: 10
- rgb_color:
- 240
- 252
- 3
- rgb_color:
- 23
- 252
- 3
- rgb_color:
- 3
- 78
- 252
- rgb_color:
- 244
- 3
- 252
Can someone suggest me a style to make the background more clear and the font more visible?
The theme
option seems to not workā¦
Iām using browser_mod
with popup
but there is something strange with the styling. I use border-radius
but the bottom two corners donāt seem to be radiused although the shadow is.
(Iām also using lovelace_gen
which explains the {{ cycle }}
in the following code)
tap_action:
service_data:
title: Cycle {{ cycle }} Settings
card:
type: entities
entities:
- entity: input_datetime.irrigation_cycle{{ cycle }}_start_time
deviceID:
- this
style:
font-family: Oswald
font-size: 14px
border-radius: 1em
box-shadow: 0em 0em 0.5em 0.2em
opacity: 0.9
Nice work.
I would like to ask something regarding accessing home assistant through nginx proxy when outside of local network.
Is there a way for devices to keep the same id?
eg. i have a tablet i want to use as a media player but device id is different in local and outside connection.
Thatās a bit of an unfortunate oddity in the popup.
The top part belongs to the popup itself, but the bottom part - including the two bottom corners - belong to the included card.
You need to add a border radius to the card as well, using e.g. card-mod or a theme.
Note that CSS allows for rounding individual corners too.
Only if they connect through the same URL.
So if you use your cloud/duckdns/other outside url solution to connect even when at home, youāll get the same deviceID.
Your router/firewall may not like a connection going outside and the coming back, but thereās usually a way to enable it. It may be called āNAT mirroringā, āhairpinningā or something like that.
If not, you may be able to redirect calls to your domain via the DNS settings. YMMW.
