šŸ”¹ Browser_mod - turn your browser into a controllable device, and a media_player
Please read the GitHub docs.
its very simple. I needed 10 minutes to figure that out:
Here is an example:
custom_header:
  chevrons: false
  compact_mode: true
  hide_header: true
title: Wecker
  - badges: []
    popup_cards:
      group.all_light_groups:
        title: Light groups
        card:
          type: entities
          show_header_toggle: false
          state_color: true
          entities:
            - light.wohnzimmer
            - light.schlafzimmer
            - light.gastezimmer
            - light.kuche
            - light.office
            - light.treppe
            - light.fitnessraum
            - light.eingang
    cards:
      - cards:
          - cards:
              - entity: group.all_light_groups
                icon: 'mdi:lightbulb-group'
                layout: vertical
                show_icon: true
                show_label: false
                show_name: false
                show_state: false
                styles:
                  card:
                    - width: 50px
                    - height: 90px
                  icon:
                    - color: |
                          if (entity.state == 'on') return 'yellow';
                          else return 'red';
                tap_action:
                  action: more-info
                type: 'custom:button-card'
              - entity: sensor.time
                layout: vertical
                show_icon: false
                show_name: false
                show_state: true
Beside badges and cards you have an additional element: popup_cards:
You have to link this type of card to the entity, which shall show this alternate, in the given example the group.
As popup you can choose any type of card. In this case I have choosen a simple entities card
Thats it.
Here is an extended version:
background: var(--background-image)
custom_header:
  button_text:
    options: '{{ time }}'
  compact_mode: true
  exceptions:
    - conditions:
        user: Yvonne
      config:
        hide_tabs: '9'
    - conditions:
        user: Mobile
      config:
        hidden_tab_redirect: false
        hide_header: true
        shadow: false
  header_text: Zu Hause
  hide_header: true
  indicator_top: true
title: Varadero
  - badges:
      - entity: person.jorg
      - entity: person.yvonne
      - entity: person.chiara
      - entity: person.niklas
      - entity: variable.housewife_present
    popup_cards:
      binary_sensor.washer_state:
        title: Waschmaschine
        card:
          type: entities
          state_color: true
          entities:
            - entity: binary_sensor.washer_state
              secondary_info: last-changed
            - entity: sensor.waschmaschine_watts
            - entity: timer.timer_waschmaschine
      binary_sensor.dryer_state:
        title: Trockner
        card:
          type: entities
          state_color: true
          entities:
            - sensor.8_hour_rain_forecast_total
            - entity: binary_sensor.dryer_state
            - entity: sensor.trockner_watts
            - entity: timer.timer_trockner
      switch.zone_1_zone:
        title: BewƤsserung
        card:
          type: entities
          state_color: true
          entities:
            - entity: sensor.netatmo_imeerbus121_rs_garten_sum_rain_24
            - entity: sensor.8_hour_rain_forecast_total
            - entity: input_boolean.rain_delay
            - entity: input_number.time_since_last_irrigation
            - input_number.irrigation_frequency
            - entity: switch.zone_1_zone
    cards:
      - cards:
          - icon: 'mdi:shield'
            label: Innen
            layout: vertical
            show_icon: true
            show_label: false
            show_state: false
            styles:
              card:
                - height: 30px
              icon:
I defined new popup-cards for 3 entities. and you can see, that each popup card can handle all options the card provides.
You can also just call browser_mod.popup if you only want to trigger on one card, with deviceID: this.
@Pirol62 thanks for the informationsā€¦ I have not being able to replicate your code. But finally able to make some popup using others videos. However still trying to figure it out if there a possibility to make a button (for example TV button and if that being press then the popup such the remote card witll appear)
making the ATV remote appear as a popup
    cards:
      - type: vertical-stack
        cards:
          - type: horizontal-stack
            cards:
              - type: 'custom:button-card'
                color_type: blank-card
                color_type: card
                color: black
                icon: 'mdi:home'
                tap_action:
                  action: call-service
                  service: remote.send_command
                  service_data:
                    command: home
                    entity_id: remote.atv_main
                hold_action:
                  service_data:
                    command: home_hold
                    entity_id: remote.living_room
                color_type: card
                color: black
                icon: 'mdi:sleep'
                tap_action:
                  service_data:
                    command: suspend
                hold_action:
                  action: none
                color_type: card
                color: black
                icon: 'mdi:menu'
                tap_action:
                  service_data:
                    command: menu
                hold_action:
                  action: none
I tried add this cards but nothing appear
This works.
Try to execute the browser_mod.popup in developer screen using this payload:
title: ATV Remote
card:
  cards:
      cards:
          color_type: card
          color: black
          icon: 'mdi:home'
          tap_action:
            service_data:
              command: home
          hold_action:
            service_data:
              command: home_hold
          color_type: card
          color: black
          icon: 'mdi:sleep'
          tap_action:
            service_data:
              command: suspend
          hold_action:
            action: none
          color_type: card
          color: black
          icon: 'mdi:menu'
          tap_action:
            service_data:
              command: menu
          hold_action:
            action: none
deviceID:
  - this
By the way, would love for you to share the rest of your card. Itā€™s really nice.
Got itā€¦ thank you so much.
cards:
  - name: Apple TV Bedroom
    type: media-control
    entity: media_player.atv_main
    cards:
        color_type: card
        color: black
        icon: 'mdi:home'
        tap_action:
          service_data:
            command: home
        hold_action:
          service_data:
            command: home_hold
        color_type: card
        color: black
        icon: 'mdi:sleep'
        tap_action:
          service_data:
            command: suspend
        hold_action:
          action: none
        color_type: card
        color: black
        icon: 'mdi:menu'
        tap_action:
          service_data:
            command: menu
        hold_action:
          action: none
    cards:
    cards:
    cards:
    cards:
        color_type: card
        color: black
        icon: 'mdi:arrow-up'
        tap_action:
          service_data:
            command: up
        hold_action:
          action: none
    cards:
        color_type: card
        color: black
        icon: 'mdi:arrow-left'
        tap_action:
          service_data:
            command: left
        hold_action:
          action: none
        color_type: card
        color: black
        icon: 'mdi:apple'
        tap_action:
          service_data:
            command: select
        hold_action:
          action: none
        color_type: card
        color: black
        icon: 'mdi:arrow-right'
        tap_action:
          service_data:
            command: right
        hold_action:
          action: none
    cards:
        color_type: card
        color: black
        icon: 'mdi:arrow-down'
        tap_action:
          service_data:
            command: down
        hold_action:
          action: none
    cards:
    cards:
    cards:
    cards:
        color_type: card
        color: black
        icon: 'mdi:play-pause'
        tap_action:
          service_data:
            command: play_pause
        hold_action:
          service_data:
            command: home_hold
        color_type: card
        color: black
        icon: 'mdi:volume-plus'
        tap_action:
          service_data:
            command: volume_up
        hold_action:
          action: none
    cards:
        color_type: card
        color: black
        icon: 'mdi:skip-next'
        tap_action:
          service_data:
            command: next
        hold_action:
          service_data:
            command: home_hold
        color_type: card
        color: black
        icon: 'mdi:volume-minus'
        tap_action:
          service_data:
            command: volume_down
        hold_action:
          action: none
Here is my card combine with button-card for an Apple TV remotes
Special Thanks to @Pirol62 and @sergio_pt for making this possible
Looks great
Itā€™s been a while since Iā€™ve been around. I just updated to Home Assistant core to the most recent release and supervisor versions.
Now it seems that when I use device_ID: this it displays the popup on all currently running devices. Any ideas?
It should be deviceID: this, not device_ID: this (no underscore).
Not sure how to do a new post instead of a replyā€¦ this is reposted from issues in case someone else has a solutionā€¦
Thanks for a great mod! Really really appreciate it.
I have an issue with a new android tablet running 10 go edition however. Webkit (android not ASOP) is v85 etc. mod_browser is v1.1.6.
I use the blackout feature as a screen saver for a wall mounted tablet - blackout after 60 seconds of inactivity so it doesnt annoy people walking past - not for power saving as I dont care about power used.
Wake on touch works if the screen is touched within a few seconds but if I leave it for say 5 minutes or longer then the screen will not wake.
Tested on fully kiosk AND the HA companion app. Both have the same behavior.
Things I have tried:
  • cleared cache
  • I have disabled all setting to put the screen to sleep
  • disabled lock
  • including developer settings - donā€™t allow screen to sleep
  • Tried fully kiosk and HA app - both have the same issue
  • Seemed to work fine on an ipad I have
If I repeatedly tap the screen then it might wake up after 5 or so taps OR I get an error - app not responding message.
The funny thing is if I send a no_blackout message then the screen wakes when in this state fine - after a bit of a lag (2 seconds or more).
No errors in the HA logs on the server side.
So, I am thinking that this seems to be a webkit issue maybe? Any ideas? Anything else I can try or test?
Do you think the device actually turned off the screen instead of just making it black, and in that state it doesnā€™t respond to touches because itā€™s asleep?
Yup that could definitely be the causeā€¦ Thank you!
But trawling through the javascript it looks like the screen off function only works if it is fully kiosk browser. It wouldnā€™t work with the HA app would it?
blackout(e) {
            const t = ()=>{
                window.fully ? fully.turnScreenOff() : this._blackout.style.visibility = "visible",
                this.update()
            e.time ? this._set_screensaver(t, e.time) : t()
The screen never goes off just sitting on the home screen or when I dont send a blackout command - so yes - it is something in the code causing itā€¦ hmmmm. Iā€™ll give it a try by changing the javascript to not detect fully when I get a chance and report back.
Also thinking that maybe it is just the HA app going to sleep and taking a long time to wake up. Disabling app sleep is looking to be a pain on android 10 - they disabled the priority app feature.
Hi, I had some problems realizing an alarm clock with browser_mod and HA Companion app as well.
I could not activate the app and play a sound at alarm time.
Changed then to wallpaper and everything works fine.
Would anyone know what controls the ability to change font and size in the popup window bar? I have tried many styles changes but I have yet to figure out what updates the popup window bar. I have been able to change many of the styles in the rest of the window but canā€™t figure out the popup window bar. The text in red is what I would like to update. Hopefully someone has an example they can share.
Browser_mod
- service: browser_mod.popup
     command: popup
     title: System
     style: |
       :host .content {
         width: 50vw;
         height: 80vh;
       :host {
          --mdc-theme-surface: rgba(0,0,0,0.5);
          --secondary-background-color: rgba(250,0,0,1.0);
          --primary-text-color: rgb(255,255,255);
          --ha-card-background: rgba(0,0,0,0.9);
     card:
Iā€™m interested in using this for my alarm panels (fire7) using fully kiosk. Iā€™m having trouble getting any of them to register in HA. My PC browser registers ok but nothing else. Is there some setting in Fully Kiosk that has to be enabled/disabled for the browser to become an entity in HA?
Hi all,
Your command ā€œbrowser_mod.set_themeā€ works with you?
Hi All,
Just for those interested in this problem - it IS an android 10 complexity. Backout causes a screen off not just a screen blank on Android 10. This happens for Fully and the latest HA App.
Workaround is to hack the mod_browser java script to ignore the condition that screen off is supported - not my choice of workarounds as it breaks upgrade. Perhaps a setting could be added to mod_browser?
Android 10 GO edition is so very locked down - cant set a background app. Unfortunately I cannot find a rom for my device for Android 9 or earlier to get around this so I am thinking of just adjusting the screen brightness to minimum and adjusting up on press detection.
Cheers all.
The media_player device created by browser_mod only supports audio playback.
This is not well documented IMO and cost me some wasted time. But, I will likely use this feature once I get the toys, Iā€™m doing some preliminary research ATM.
Is there any way to get the path from the browser mod sensor for a specific device as an attribute?
What Iā€™m trying to do is when ever the tab changes from my tab named home on my tablet to any other tab I want browser mod to change it back to home after a set time.
I got an automation with browser_mod.navigate working for the specific tablet and Iā€™ve tried to find a way to use the path as a template from the browser mod sensor states and try to use it in an ā€˜if notā€™ to start and stop a timer but I donā€™t know how to make this specific attribute available. I tried ā€˜state_attrā€™ and ā€˜states.sensorā€™ with no luck.
Iā€™m new to HA and programming and I donā€™t know what to try next.
Is there a solution to this or am I just searching for a holy grail here?
