šŸ”¹ Browser_mod - turn your browser into a controllable device, and a media_player
If the description of a new release starts with ā€œBREAKINGā€, itā€™s a good idea to read the release notes:
https://github.com/thomasloven/hass-browser_mod/releases/tag/1.3.0
cover-popup-card doesnt work anymore since last updates, is anybody else having the same issue?
No issues here. Havenā€™t had a single breaking popup using browser_mod.
This is running latest updates:
All DBuits popup cards work for me (light and mediaplayer popup-cards).
Can you help me? Where is the problem? Should I check the log??
Are you using browser mod built in pop up? Cuz Iā€™m using cover pop up card. May you send me your yaml?
Hi, Iā€™m really struggling to get this to work.
  - title: '1'
    path: '1'
    cards:
      - type: vertical-stack
        cards:
          - type: horizontal-stack
            cards:
              - type: 'custom:button-card'
                color_type: card
                color: 'auto'
                icon: 'mdi:thermostat'
                tap_action:
                  action: call-service
                  service: browser_mod.popup
                  service_data:
                    title: Popup example
                    card:
                      type: entities
                      entities:
                        - light.livingroom_lamp
                    deviceID:
                      - this
Without the deviceID section, it works as expected. Adding this breaks it.
Any help would be greatly appreciated.
replacing ā€œthisā€ with a specific deviceID works and only opens the popup on the specified device. So the issue is with ā€œthisā€.
This is my screen saver, browser mode, pop-up after 3 min
Is it possible to add weather forecast, card- darksky![IMG_20210323_225824|690x388](upload://deUSQ5qfu3R1lFojkm8zFnmXzLB.jpeg
Forecast card
Iā€™m struggling with not getting the prefix and the alias for my devices. In the configuration.yaml file, I add the following lines:
  prefix: "browser_mod_"
  devices:
    ef1d212f-90d0bc54:
    7351ff94-d017bf2e:
I checked the deviceIDā€™s via mod_browser.debug under Services. But these deviceIDā€™s are not getting the Alias. I expect that I can find these renamed" entities under the Entity tab by searching for it.
What am I doing wrong?
Do you have browser_mod listed first in configuration.yaml?
browser_mod:
  prefix: ā€œbrowser_ā€
  devices:
Thanks, that does the trick. Another issue: the alias doesnā€™t work, it doesnā€™t replace the unique id.
I checked if they are available via de Developer tools.
I searched the entity and selected one of them, and there I see the alias mobiel:
2021-04-06_10-32-43
And I guess, imac is not a unique name, so I need to assign an unique name. Lets try this out
Yes, same here now. Somehow it changes the device name itself, but not the entities tied to it. I manually changed the entities names (like you can with any entity). Workaround, but fine for the time being.
Large: true is to large for my display. How can i make ist smaller?
Iā€™m using card-mod.
              tap_action:
                action: fire-dom-event
                browser_mod:
                  command: popup
                  title: "DWD Wetterwarnung \U000026A0"
                  style:
                      :host .content {
                        width: 600px;
                  card:
Be aware that this is the old syntax of card-mod. With the new one it didnā€™t work for me.
To access the new cool features, you need to replace
style:
ā€¦ stuff here ā€¦
with
card_mod:
style:
ā€¦ stuff here ā€¦
Just style should still mostly work, but you wonā€™t get the new features.
this dont work for meā€¦
I canā€™t find this option anywhere. Where can i read about it?
host .content {
  width: 600px;
Is there a way to periodically check the deviceID via an automation? Mine periodically changes and breaks another automation - so I was hoping there is a way to retrieve the deviceid with an automation periodically and see if it has changed.
How do I implement the browser_mod popup service using the new 1.3.0 version?
Where do I put the popup command and what was ā€œservice_dataā€ before (the cards themselves)?
For example, how do I modify this?
        tap_action:
          service_data:
            card:
              type: 'custom:weather-card'
              entity: weather.darksky_hourly
              hourly_forecast: true
              forecast: true
              number_of_forecasts: '18'
              details: false
              current: false
              icons: /local/icons/weather_icons/static/
            deviceID:
              - this
            style: |
              :host .content {
                width: 80vw;
            title: Hourly Weather Forecast
So with the latest version calling the service via the front end using Custom Button Card i cannot use the service fire-dom-event as it isnt a valid service in my list of available services.
Instead i had to remove deviceid: this from my buttons to allow the popup to work which now presents the popup on all devices.
What is the workaround to this? I only want the popup to appear on the device that initiated the popup.
