I do not understand. Where did this deviceID get? thanks.
Iām struggling with browser_mod. Everything (everything I tested) is working perfectly on chrome on my laptop. But I canāt do anything with my android phone. I managed to get a device id for my phone (I donāt know how I did), so it works for few hours but the device went unavailable and nothing is working on my phone anymore (I mean popup etc.).
Also, Iām not able to have a device created for my wifeās phone. I tried many thing like cache cleaning and phone restart, etc.
I created an issue Can't manage to have a deviceID generated for android app Ā· Issue #222 Ā· thomasloven/hass-browser_mod Ā· GitHub
Does anybody have any tips ?
could anyone possibly help me understand why nothing happens when I click the horseshoe card referenced below?
Script
browser_popup_climate:
sequence:
- service: browser_mod.popup
data_template:
deviceID:
- 48b8a5de-47e9ac05
card:
type: custom:thermostat-popup-cards
entity: climate.downstairs
Lovelace (scroll to bottom for tap action on horseshoe card)
- type: vertical-stack
cards:
- type: 'custom:flex-horseshoe-card'
card_mod:
style: |
ha-card {
background-color: var(--primary-background-color)
height: 118px;
width: 118px;
border-radius: 30px;
entities:
- entity: climate.downstairs
attribute: current_temperature
decimals: 1
unit: Ā°F
attribute: temperature
decimals: 0
unit: Ā°F
icon: 'mdi:thermometer'
attribute: current_humidity
decimals: 0
unit: '%'
icon: 'mdi:water'
show:
horseshoe_style: lineargradient
scale_tickmarks: true
layout:
hlines:
- id: 0
xpos: 50
ypos: 50
length: 50
styles:
- stroke: var(--primary-text-color);
- stroke-width: 5;
- stroke-linecap: round;
- opacity: 0.7;
states:
- id: 0
entity_index: 0
xpos: 50
ypos: 42
styles:
- font-size: 3em;
- id: 1
entity_index: 1
xpos: 29
ypos: 66
styles:
- text-anchor: start;
- font-size: 1.9em;
- id: 2
entity_index: 2
xpos: 62
ypos: 66
styles:
- font-size: 1.9em;
icons:
- id: 0
entity_index: 1
xpos: 28
ypos: 65
align: end
- id: 1
entity_index: 2
xpos: 61
ypos: 65
align: end
names:
- id: 0
entity_index: 0
xpos: 50
ypos: 90
horseshoe_scale:
min: 50
max: 90
color_stops:
'50': blue
'90': red
tap_action:
action: fire-dom-event
browser_mod:
command: call-service
service: script.browser_popup_climate
service_data:
deviceID:
- 48b8a5de-47e9ac05
so far as I can tell I have the browser mod and thermostat popup card functioning correctly, but here is the resultā¦what could it be?
Slightly off-topic, but why this difference? I wonder if this is by a HA Dev design choice, or a must?
If only a fraction of my fellow HA users have wasted just a fraction of the time I have - fighting this difference, then I think it deserves attention - if at all possible to change?
I know, itās plain and straight forward and should be easy to remember, but as you so elegantly put it yourself; " with a lot of other plugins and stuff running through ones head while writing (whatever)ā¦" it becomes so easy to overlook the obvious. Especially with 110% mindset on new Custom Card YAML or a new integration Template.
If Front-End and Back-End had been using the same syntax, life with HA would be a lot easier.
Please, how to call popup from popup correctly?
It works, but the second popup closes the first one (doesnāt show in front of it).
Is it possible?
I am creating a button-card in popup but the following command to display the brightness in the label is not displayed in browser_mod, while in lovelace it works regularly.
I can fix this?
- type: custom:button-card
icon: mdi:lightbulb
entity: input_boolean.prova
aspect_ratio: 1/1
label: Ciao
show_state: true
show_label: true
tap_action:
browser_mod:
command: popup
title: "Prova"
card:
icon: mdi:lightbulb
entity: light.led_tv
aspect_ratio: 1/1
show_state: true
show_label: true
label: "[[[ if (typeof(entity) === 'undefined') return; if ('brightness' in entity.attributes) { if (entity.attributes && (entity.attributes.brightness <= 255)) { var bri = Math.round(entity.attributes.brightness / 2.55); return (bri ? bri : '0') + '%'; } } ]]]"
The Home Assistant has a trick, it is to take snapshots of the state and then you can return to the state as it was before. We are talking about scene.create service. Can this be applied to browser_mod.navigate navigation? For example, I had page 1 open, then after starting the trigger, I opened page 2, when the trigger is re-triggered, it should return to page 1. Thus, no matter which page was opened, the return will always be to the page that was opened before switching.
hello, you have found the solution to that error, Iāve been seeing the same message in the log for a while
Logger: homeassistant
Source: helpers/entity.py:340
First occurred: 1:27:30 (1 occurrences)
Last logged: 1:27:30
Error doing job: Task exception was never retrieved
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 340, in async_update_ha_state
raise RuntimeError(f"Attribute hass is None for {self}")
RuntimeError: Attribute hass is None for <Entity None: 1>
Same here. The. combination of custom:button-card
as container and popup-content custom:button-card
including Javascript causes display errors.
hi, please could someone help me out - I am using custom-button-card - and wanted to combine it with browser-mod. What I want to achieve is popup just on the device where the custom-button was pressed.
This is my code so far - it does work, but popup shows on every device.
tap_action:
action: call-service
service_data:
data_template: null
title: Mistral Smart 400 + CleanR
large: false
card:
type: custom:vertical-stack-in-card
cards:
- type: entities
entities:
- entity: switch.gosund_sp111_reku
icon: hass:fan
- type: gauge
entity: sensor.gosund_sp111_reku_energy_power
min: 0
max: 500
severity:
green: 0
yellow: 200
red: 250
- type: glance
entities:
- entity: sensor.reku_daily_combined_cost
icon: hass:cash
- entity: sensor.reku_monthly_combined_cost
icon: hass:cash
- entity: sensor.reku_yearly_combined_cost
icon: hass:cash
show_name: true
show_icon: true
show_state: true
columns: 3
Use fire-dom-event
tap_action:
browser_mod:
command: popup
large: false
hide_header: false
title:
card:
type:
amazing - thank you!!!
i have browser mode on my tablet, after update it is gone
when i try " Browser mod: debug" doesnt show any more on that tablet, doesnt show device_id
tap_action:
service_data:
title: Popup example
card:
type: entities
entities:
- camera.lenovostick_screen_0
deviceID:
- this
target: {}
entity: sensor.time_since_most_recent
hold_action:
action: none
instead of getting the camera entity popup for current running device only, i get the default tap action for the sensor.time_since_most_recent sensor (more info-esque dialog box). what am i doing wrong?
- this
is deprecated. Use alias (if given) or the bare deviceID.
Oh really? Why did they take this function away? it was very useful. Is there any way to automatically include all devices?
I just canāt get it to work. Could someone give me a hand? This was the code I had (I donāt want to specify any ID):
entity: input_boolean.radio_da_suite
show_entity_picture: true
styles:
card:
- height: 7em
state:
- entity_picture: /local/img/icones/radio-on.gif
value: 'on'
- entity_picture: /local/img/icones/radio-off.png
value: 'off'
tap_action:
haptic: light
service: script.radio_suite_toggle
hold_action:
service_data:
card:
cards:
- cards:
- color: red
color_type: card
icon: mdi:power
styles:
name:
- font-weight: bold
tap_action:
type: horizontal-stack
- cards:
- color_type: blank-card
styles:
card:
- height: 1em
deviceID:
- this
- dashboard
title: RĆ”dio da SuĆte
So i tried:
styles:
card:
- height: 7em
state:
value: 'on'
value: 'off'
tap_action:
browser_mod:
command: popup
large: false
hide_header: false
card:
cards:
- cards:
- color: red
color_type: card
icon: mdi:power
styles:
name:
- font-weight: bold
tap_action:
- cards:
styles:
card:
- height: 1em
But didnt work either.
