Does browser_mod work with the IOS companion app or only the browser app? Also, does the iphone need to be unlocked with screen on and ios app having focus for a sound to be played?
I have google speakers around house on which I can cast internet radio stations via URL and they all play without any issues.
When looking for a solution how to play this radios inside the home assistant tab in browser I found this addon. When trying to play online radio station from url (http://nrj.de/rock) to media_player.alias_id nothing is beeing played, but under states it says it is playing.
I can see an error under browser console:
Playing such streams is not possible or I am doing something wrong?
Thank you.
Hi, Most possible a simple answer, however I have been looking through this thread and can not finde anything, and I can not get it to work form the documentation.
I use the browser_mod.more-info with this code, and it works perfectly for me. The reason for the entiti_id is beeing part of a declutteringcard. Works perfectly.
However, it opens on all browsers, and I would like it to only open on active screen where the tap_action is started.
I have looked all over, however not able to figure it out. There is a lot of examples like this, however not working for me. Anyone have a good working example
@doktordoc : Iāve done exactly like bearder tinker on that video. Doesnāt work on browsers. Works on tablets, and i guess that it works on add-on speakers, too. But not in browser (on PCās soundcard).
Iāve tried so many combinations and changes, my head has exploded. Can anyone suggest what I am doing wrong?
- type: glance
entities:
- entity: switch.fanpower
tap_action:
action: fire-dom-event
browser_mod:
command: popup
# title: Dyson Fan Controls
card:
- type: horizontal-stack
cards:
entities:
tap_action:
action: toggle
- entity: switch.master_bedroom_auto_mode
tap_action:
action: toggle
- entity: switch.master_bedroom_night_mode
tap_action:
action: toggle
- entity: switch.oscillation
tap_action:
action: toggle
HI All,
IS there a way to config the browser_mod integration to stop register new browsers?
I have 2 in use⦠(FKB and my iMac) on my work IP address is changing all the time so I get many new entities. I will stop this. I tried disable āEnable newly added entitiesā but didnāt work.
Ya, I facing this too. I cannot get the popup work. Hope some one can find out.
From what I know you have to have a title line. Yours is commented out. Here is how mine looks,
tap_action:
browser_mod:
command: popup
title: []
card:
type: "custom:vertical-stack-in-card"
cards:
Yes, same here.
tap_action:
browser_mod:
command: popup
title: Wecker
card:
type: entities
Thanks, looks like you are right and the title is required. Thank you!
Just double-checked again. In both cases
tap_action:
browser_mod:
command: call-service
service: browser_mod.popup
service_data:
deviceID: this
title: Wecker
card:
type: entities
tap_action:
browser_mod:
command: popup
title: Wecker
card:
type: entities
you are right and it is only working with title here as well.
I have a question regarding browser_mod integration because Iām facing out an annoying situation.
Each time I reset my browser cache with cookies (which often happens with Home Assistant troubleshooting ), it creates a new device when I log back with the same browser.
After a time, I get a huge list of unavailable devices.
in the above screenshot, I have 12 devices (cache cleared two days ago, Iast time I got until >50 devices), while only 3 browsers still exist.
I can remove manually the entities from the āentities panelā, but I donāt find a way to remove devices easily.
How do people deal with that? By my side, the only solution I found for the moment is to delete the integration and re-add it.
Thanks for your feedback.
Thanks again @rmertz3282 & @arganto, I have it working again finally
If you are interested @kazihaha , below is my working card config, if you compare it to my previously posted one above:
- type: glance
entities:
tap_action:
browser_mod:
command: popup
title: 'Dyson Fan Controls'
card:
type: glance
entities:
tap_action:
action: toggle
tap_action:
action: toggle
tap_action:
action: toggle
tap_action:
action: toggle
I think the trick lies in disabling.
I originally had your same problem until I did this.
Thanks for your answer.
This only disables all entities related to devices (available or unavailable), but devices are still there.
If the devices are unavailable (and for sure it will never be back in the future), Iām not able to delete them without removing the integration⦠thatās my concern.
As browser_mod is probably based on a cookie that is related to the session context, the behavior seems correct: when clearing the entire cache, it will delete the ID related to the device and create a new one when the browser reconnects the next time because it is considered as a new device.
But I would like to clean up the mess without having to remove and re-add the integration.
By looking at the community feed I finally found an old thread that cover this problem : Delete individual device (and entity) from integration - #55 by SnoWake
This is apparently not only related to browser_mod.
Hi all,
A question.
Is it possible to make a button when i click on it, i get a popup showing the new energy dashboard or the media browser (with other button) inside the popup?
Iām not sure how.
Use iframe (web) card inside the popup and put your energy dashboard or media browser address as URL.
Why didnt i think of that myself lol
Great will do that
Iām having issues with this card. I have the following in my config.yaml:
browser_mod:
prefix: "browser_"
devices:
a1521498_ea1ae31b:
disable:
- light
- media_player
218f8982_b93c0162:
disable:
- media_player
enable:
- camera
- binary_sensor
- sensor
- light
disable:
- all
However, in Developer Tools/States, I only see entities with the browser mod ID (i.e. 218f8982_b93c0162) and only camera and media_player with no sensor.
My goal is to manage charging based on the battery of my tablet (Fire HD 10) running Fully Kiosk, so maybe thereās another way thatās a bit simpler. Very curious what Iām missing here.
Thank you!
