Has anyone had issues with popups and Android companion app, on the latest versions of android app, hass core, supervisor os, and browser_modā¦ Iām using homekit-panel-card and things work from chrome browser on the phone and my laptopā¦
I cleared the cache on the companion app hoping that would fix it because I did need a force refresh in mobile chrome and laptop
For others, you have to not only clear android companion cache, but also dataā¦ so you have to set things back up, make sure to name your device the same and it should at least create sensors with the same names you had before saving you time
Hello Iām using this browser mod to Send some TTS messages to a dashboard.both Mediaplayer are created bit it will never play a sound .I use Mary TTS add-on and it works for other TTS bit not with this browser mod. I access my ha over HTTPS and proxy server . Any idea how to debug this ?also when I log in locally it wonāt work and play any sound
This is not exactly related, but I think this is the best place to ask.
I was trying to change some style on the button depends on how much the user scroll from the top.
It is working fine, the only problem is that the script in custom button card is not being refreshed constantly, only once in few seconds, so it is not smooth.
Is there anything can be done here, maybe with help of browser-mod?
Here is the code:
- background: |
var supportPageOffset = window.pageXOffset !== undefined;
var y = supportPageOffset ? window.pageYOffset : isCSS1Compat ? document.documentElement.scrollTop : document.body.scrollTop;
if ( Math.round(y) > 15 ) {
return 'var(--header-background-color)';
} else {
return 'none';
Okay, I will give it a shot and hope someone can help. This is driving me mad, but I must be doing something wrong here.
Iām trying to set up browser_mod on my HA. Installation through HACS went fine, and after HA reboot I can see the browser_mod integration. Now comes the strange part. Iām trying to get the deviceID with browser_mod.debug, but nothing happens. It does show a popup on my pc, but not on my android device where Iām trying to set things up. So now I have the deviceID for my PC, but not for my android device. When I close down the browser on my PC, and after that open it up again, browser_mod is unavailable, just like on my android device. I can see this quickly because I have added a browser-player card to the dashboard, which gives me the error in the screenshot I added.
For the PC, refreshing the page works and the mod becomes available again. For android, I wouldnāt know how to refresh.
But still, the mod should be available, no matter where I fire up HA, right?
There is one more thing I noticed: if I connect to HA on its local LAN address, browser_mod is always available instantly. The problems seem only to occur when Iām connected to HA remotely via domain name, which I usually am.
Excuse me to revive a 1.5 year old post but is there any way to get rid of this annoying tooltip (set to the title, which is mandatory)?
Itās everywhere on the screen, even outside the popup.
Using Chromeās Inspector I cannot find any hint on any :hover attribute so Iām unable to kill the tooltip with card_mod.
Help!
Hi, Iāve created a popup card with a custom button-card inside, containing more button cards etc. For example Iāve created a button to toggle lights, the toggle is working, only the card is not updated and not showing the changed styles/icon. The card is working as a normal lovelace card. Any ideas how to fix this? Thanks
I got the popup to work and it is showing my live feed when the doorbell is pressed but the popup is very small. Any thoughts on how i can make it fullscreen or at least bigger then the small popup showing up now?
