šŸ”¹ Browser_mod - turn your browser into a controllable device, and a media_player
so this was going to be my first browser-mod more-info, but I am not getting the correct syntax, so turn to your assistance please:
      - type: custom:auto-entities
        card:
          type: entities
#              title: Family abroad
          card_mod: &style
            style: |
              ha-card {
                margin: 0px -16px;
                box-shadow: none;
          tap_action:
            action: fire-dom-event
            browser_mod:
              command: more-info
              parameter: >
                {{states(config.entity|replace('duration','route'))}}
        filter:
          include:
            - entity_id: sensor.*naar_huis_duration
              options:
                type: custom:template-entity-row
                  {{state_attr(config.entity,'friendly_name').split(' Dur')[0]}}
                state: >
                  {{states(config.entity)}} min - {{states(config.entity|replace('duration','distance'))}} km
                secondary: >
#                secondary_info: last-changed
        sort:
          method: state
the section in the astro-entities filter does all work, so I am positive about the template under secondary.
However, id love that show on more-info when tapping the entity, simply because the secondary line is too small to display.
hence my effort to show the same template on a tap action on the entity (did try it in the filter section options, but that didnt work either.) Yet nothing showing but the real entity’s more-info…
if I do
        filter:
          include:
              tap_action:
                browser_mod:
                  command: more-info
                  parameter: >
the whole entity disappears…
please have a look where my error lies? thanks!
update
#                tap_action:
#                  action: fire-dom-event
#                  browser_mod:
#                    command: popup
#                    title: Whatever
                state: >
                secondary: >
                tap_action:
                  browser_mod:
                    command: toast
                    message: Hello, world!
make the toaster appear alright, so that would at least tell me the spot in the crd co fig is correct under the template-entity-row
now how to get the syntax for showing
                    command: more-info
                    entity: >
                tap_action:
                  browser_mod:
#                    command: toast
#                    message: Hello, world!
                    command: popup
                    title: Route
                    card:
                      type: markdown
                      content: >
give me a popup but an empty markdown card.
If I replace the template with a plain string (ROUTE to be displayed here…)
that works alright. So, almost there!
now how to get the template working… because
title: >
   Route for {{states(config.entity)}}
doesnt work either. Maybe this boils down to templates not supported in Browser-mod… no. it must be me doing something wrong
Although: https://github.com/thomasloven/hass-browser_mod/issues/286 …
Hi, is there a way to open a popup to a fully kiosk browser (on my tablet, dashboard)? I can play music and things like that to the browser mod mediaplayer, but i want to send / cast an popup message.
Thanks for the help!
Hello, i am using Browser Mod to play back stored MP3 files from a script:
alias: bedroom yellow_1'
sequence:
  - service: media_player.play_media
      media_content_type: audio/mp3
      media_content_id: /local/media/bedroom yellow/yellow_1.m4a
      area_id: room_27
mode: single
max: 10
This script is triggerd from a hotspot in Lovelace, to make this work I need to assigne the browser to Room 27 for it to run, this is fine untill the Mobile app generates a new Browser then the scrip wont run untill i have been in and assigend the new browser to Room 27.
I am sure there is a better way to do this but cant work it out, any ideas? even to broadcast to all active browser would work
Hi. Is there any way of putting a background picture to a popup window ?
I’ve reported a bug with FKB becoming unavailable again even though force_stay_awake: true or screensaver: true are both used
I’ve tried running one option on one device and the other one on a second and both devices go unavailable after approximately 5 minutes
Is this broken, I’m on 2022.7.7 but haven’t tried it before in honesty so wondering if maybe I’m missing a new workaround that I was unaware of.
I discovered there were newer versions of FKB, so have now installed FKB 1.48.2 and will try force_stay_awake
anyone knows how to get the browser_mom.popup make the same style as the theme itself?
new FKB version on both tablets didn’t help…devices are still becoming unavailable…not sure what else to try
HI, I disabled the Broser_mod integration. Now I can’t Enable it. I can see the enable button, but when I select it nothing happens. Any suggestions?
Hi can anybody help with this please, nothing pops up when I click the button, thanks.
type: custom:mushroom-template-card
primary: null
secondary: ''
icon: mdi:sofa
icon_color: orange
card_mod: null
style:
  mushroom-shape-icon:
      .shape ha-icon
          --icon-animation: blink 1s linear infinite;
        @keyframes blink {
          30% {opacity: 0.5;}
layout: vertical
tap_action:
  browser_mod:
    command: popup
    deviceID: this
    service_data:
      card:
        - type: custom:stack-in-card
          cards:
            - type: custom:mushroom-chips-card
              chips:
                - type: back
                - type: entity
                  entity: scene.diy_fireplace_on
                  content_info: name
                  use_entity_picture: false
                  card_mod: null
                  style: |
                    ha-card {
                      --text-color: green ;
            - type: horizontal-stack
              cards:
                - show_name: true
                  show_icon: true
                  type: custom:button-card
                  tap_action:
                    action: call-service
                    service: scene.turn_on
                    service_data:
                      entity_id: scene.diy_fireplace_on
                  icon: mdi:fire
                  color: Green
                - show_name: true
                  show_icon: true
                  tap_action:
                    service_data:
                      entity_id: scene.diy_fireplace_off
                  icon: mdi:fire-off
                  color: red
              cards:
                - show_name: true
                  show_icon: true
                  tap_action:
                    service_data:
                      entity_id: scene.diy_kitchen_light_on
                  name: Kitchen Light On
                  icon: mdi:water-pump
                  color: Green
                - show_name: true
                  show_icon: true
                  tap_action:
                    service_data:
                      entity_id: scene.diy_kitchen_light_off
                  name: Kitchen Light OFF
                  icon: mdi:water-pump-off
                  color: red
              cards:
                - show_name: true
                  show_icon: true
                  tap_action:
                    service_data:
                      entity_id: scene.diy_living_room_light_on
                  name: Living Lamp On
                  icon: mdi:lightbulb
                  color: Green
                - show_name: true
                  show_icon: true
                  tap_action:
                    service_data:
                      entity_id: scene.diy_living_room_light_off
                  name: Living Lamp OFF
                  icon: mdi:lightbulb-off
                  color: red
              cards:
                - show_name: true
                  show_icon: true
                  tap_action:
                    service_data:
                      entity_id: scene.diy_yorkie_light_on
                  name: Yorkie Lamp On
                  icon: mdi:dog-side
                  color: Green
                - show_name: true
                  show_icon: true
                  tap_action:
                    service_data:
                      entity_id: scene.diy_yorkie_light_off
                  name: Yorkie Lamp OFF
                  icon: mdi:dog-side-off
                  color: red
          cards:
              primary: Incense Burner
              secondary: >-
                Living Room:{{ state_attr('climate.home', 'current_temperature')
                }}°C
              icon: mdi:oil-lamp
              entity: switch.led_phone_box_socket_1
              tap_action:
                action: toggle
                entity_id: switch.led_phone_box_socket_1
              hold_action:
                action: toggle
              icon_color: '{{ ''teal'' if is_state(entity, ''on'') else ''disabled'' }}'
              fill_container: true
              layout: horizontal
              multiline_secondary: false
              card_mod:
                style: |
                  :host {
                    background: rgba(var(--rgb-card-background-color), 0.2) url( '/local/images/oillamp.jpeg' ) center no-repeat;
                    background-size: cover;
                    #background-blend-mode: overlay;
                    background-color: rgba(var(--rgb-card-background-color), 0.8);
                    --mush-icon-size: 76px;
                    height: 66px;
                    margin-left: -18px !important;
              chips:
                - type: conditional
                  conditions:
                    - entity: binary_sensor.lounge
                      state: 'on'
                  chip:
                    type: template
                    icon_color: disabled
                    icon: mdi:motion-sensor
                    tap_action:
                      action: none
                    hold_action:
                      action: none
                - type: conditional
                  conditions:
                    - entity: media_player.steven_s_3rd_fire_tv_2
                      state_not: 'off'
                      state_not: unavailable
                  chip:
                    type: template
                    icon: >-
                      {% set media_type =
                      state_attr('media_player.steven_s_3rd_fire_tv',
                      'media_content_type') %}
                      {% if media_type == 'tvshow' %}
                        mdi:television-classic
                      {% elif media_type == 'movie' %}
                        mdi:movie-open
                      {% elif media_type == 'music' %}
                        mdi:music
                      {% elif media_type == 'playlist' %}
                        mdi:music
                      {% else %}
                        mdi:plex
                      {% endif %}
                    tap_action:
                      action: none
                    hold_action:
                      action: none
                - type: conditional
                  conditions:
                    - entity: climate.home
                      state_not: 'off'
                  chip:
                    type: template
                    icon: |-
                      {% if is_state(entity, 'idle') %}
                        mdi:sync
                      {% elif is_state(entity, 'heat') %}
                        mdi:fire
                      {% elif is_state(entity, 'auto') %}
                        mdi:snowflake
                      {% elif is_state(entity, 'boost') %}
                        mdi:water-percent
                      {% elif is_state(entity, 'off') %}
                        mdi:fan
                      {% else %}
                        mdi:air-conditioner
                      {% endif %}
                    tap_action:
                      action: none
                    hold_action:
                      action: none
                    card_mod:
                      style: |
                        @keyframes rotation {
                          0% {
                            transform: rotate(0deg);
                          100% {
                            transform: rotate(360deg);
                        ha-card {
                          {% if is_state('climate.home', 'off') %}
                             animation: rotation 2s linear infinite;
                          {% endif %}
                - type: conditional
                  conditions:
                    - entity: script.stairs_led_lights_script
                      state: 'on'
                  chip:
                    type: template
                    icon: mdi:led-on
                    tap_action:
                      action: none
                    hold_action:
                      action: none
              alignment: end
              card_mod:
                style: |
                  ha-card {
                    --chip-box-shadow: none;
                    --chip-background: none;
                    --chip-spacing: 0;
          card_mod:
            style: |
              ha-card {
                height: 102px;
                {% if is_state('switch.led_phone_box_socket_1', 'on') %}
                  background: rgba(244, 67, 54, 0.1);
                {% endif %}
              :host {
                background: var(--card-background-color);
                border-radius: var(--ha-card-border-radius);
      deviceID:
        - this
      title: šŸ›€ Lights
Is it possible for the popup to display more than one column? Trying to have 5 cards popup without a scroll bar.
Is navigation to external URL’s already possible?
Did you find a solution to this?
Yep
        style:
            .mdc-dialog__surface {
              left: -50%;
Plz guide how to open a webpage in popup
Am I right here or does this not work on mobile? I created a popup map but it doesn’t show on my phone…
I defined my popups like this:
tap_action:
  browser_mod:
    command: popup
    title: BMW X3
    card:
      entities:
        - entity: device_tracker.520d
          icon: mdi:car
        - entity: sensor.template_driving_distance
        - entity: sensor.template_avg_km_per_day_used
          name: pro Tag gefahrene KM
          icon: mdi:null
They work on mobile as well as desktop
Thank you!! I’m using the HA app on Android and it’s still not popping up… not sure why.
Your version is MUCH quicker on HA though :slight_smile:
I figured this out. If I use it in a browser on my phone it works… if I used the HA app it does not.
