I used TTS but I think that part doesnāt matter. I also have played numerous types of audio to google devices but in this instance it was advantageous for browser-mod to navigate to a tab displaying a camera and then browser-mod to play audio while that tab was open. I could probably just play audio to a speaker right beside the hub. As of now I have returned to a backup that utilized browser-mod 1.53
Thanks a lot, it helped me
@reste_narquois Is there any way how to format font used in the popup window header? As it differs from the font used in the theme.
I mean change font
and font-variant
Anyone else getting this in their logs since upgrading to 2.x?
Logger: homeassistant.components.binary_sensor
Source: helpers/entity_platform.py:520
Integration: Binary sensor (documentation, issues)
First occurred: September 15, 2022 at 6:22:03 PM (3 occurrences)
Last logged: September 15, 2022 at 6:22:03 PMPlatform browser_mod does not generate unique IDs. ID 58157dcc-da85eb01-Browser_dark_mode already exists - ignoring binary_sensor.58157dcc_da85eb01_browser_dark_mode
Platform browser_mod does not generate unique IDs. ID 58157dcc-da85eb01-Browser_FullyKiosk already exists - ignoring binary_sensor.58157dcc_da85eb01_browser_fullykiosk
Platform browser_mod does not generate unique IDs. ID 58157dcc-da85eb01-activity already exists - ignoring binary_sensor.58157dcc_da85eb01
These are the sensor entities for my main desktop browser. They all show as unavailable. The Screen switch works fine.
I was just going to ask a similar question.
I used to use this, but it no longer seems to work.
style:
.mdc-dialog .mdc-dialog__container .mdc-dialog__surface {
font-family: "Oswald" %};
but that no longer works.
I know about the websocket closing but with the old browser mod I could get around that using an automation.
Whenever the media player became unavailable
would send a rest command to Fully Kiosk to reload the start URL and the media player became available again.
That doesnāt work anymore. Is there any other way than touching the screen?
- platform: homeassistant
event: start
- platform: state
entity_id: media_player.hallpanel
to: unavailable
- delay:
seconds: 10
#=== If unavailable then reload start url
- if:
- condition: state
state: unavailable
then:
- service: rest_command.hall_panel_fully_kiosk_load_start_url
Glad that I am not alone, still believe that there is the solution, but not able to find it
i have a question. Is it possible to show a āgallery-cardā as timeout action?
How it works?
This is my configuration in the lovelace:
type: custom:gallery-card
show_reload: true
entities:
- path: media-source://media_source
recursive: true
title: Abwesenheit
parsed_date_sort: false
caption_format: '%m/%d %H:%M %p'
maximum_files: '5'
thanks for your help
The idea behind it would be that I show a video of the doorbell ringing when Iām not at home. In other words, a notification should be triggered here in which I can then click on it and watch the video.
I donāt understand how to use form data from the popup. Could someone give any insight?
In the popup I would like to be able to select the value for an input_datetime
helper.
Iāve managed to create the popup with an input for time but I donāt know how to pass the value to the set_datetime
service.
hold_action:
action: fire-dom-event
browser_mod:
service: browser_mod.popup
title: Set charging start time
content:
- name: startTime
label: Start charging at
selector:
text:
type: time
right_button: "Set"
right_button_action:
action: call-service
service: input_datetime.set_datetime
time: [[ HOW DO I PASS THE INPUT VALUE HERE? ]]
entity_id: input_datetime.ev_charging_start_time
EDIT
Ok, I managed to learn how to pass along form data. All I needed to know was in the documentation, I just had to re-read it again.
Sorry, but I canāt make it work on unregistered devices. According to the documentation a browser call will perform the service on the current browser if browser_id is omitted. I am not entirely sure on how to accomplish a browser call despite reading the documentation.
In my Lovelace dashboard I have
type: custom:mushroom-light-card
entity: light.outside_lights
hold_action:
browser_mod:
service: script.light_info_popup
entity_id: light.outside_lights
and in scripts I have
light_info_popup:
sequence:
- service: browser_mod.popup
data_template:
title: "{{ state_attr(entity_id, 'friendly_name') }}"
content:
type: custom:auto-entities
card:
type: entities
filter:
include:
- domain: light
group: "{{ entity_id }}"
What am I doing wrong here, what do I need to make this a browser call?
where is the error?
entity: binary_sensor.stato_bnt
type: custom:button-card
show_state: false
aspect_ratio: 1/1
state:
- color: red
icon: mdi:shield-lock
value: 'on'
- color: green
icon: mdi:lock-open-variant
value: 'off'
tap_action:
title: Alarm
content:
type: alarm-panel
states:
- arm_away
entity: alarm_control_panel.centrale_allarme
target: {}
ShouldĀ“t be like this?
tap-action:
browser_mod:
with this code doesenāt work
Is it possible to hide the scroll bar in a popup?
UPDATE: It would appear that adding browser_id: THIS is stopping browser_mod working on all my use cases. I have some where tap_action should pop-up a thermostat card. Again if I remove the browser_id: then it attempts to show the card, although the content is missing. FIXED: I hadnāt changed card: to content:
ORIGINAL QUESTION - STILL OPEN:
I have updated to the latest version of browser_mod and most of my pop-ups are working, except where Iām using browser_mod.more_info.
My code is:
</s> <s>hold_action:</s> <s> action: call-service</s> <s> service: browser_mod.more_info</s> <s> data:</s> <s> entity: number.wiser_away_mode_target_temperature</s> <s>
This works on my laptop, but if I hold on this on my phone the pop-up appears on the laptop.
So I added browser_id: THIS
Following this the pop-up doesnāt appear at all on any device.
Any clues? FIXED: I changed to using the fire-dom-event and this is now working.
Hey. Im trying to do a pop up within a slider card but cant get it to work/call the service. Any help would be awesome. Im trying to build a slider card (works) where i can press the āpictureā i,e āLightsā which shows me a pop up to all my lights/light group. Right now its just showing me a blank pop-up without any text or entities/lights
Thank you
type: custom:swipe-card
cards:
- type: horizontal-stack
cards:
primary: Licht
secondary: ''
icon: mdi:lightbulb
icon_color: yellow
layout: vertical
tap_action:
browser_mod:
entity: light.alle_lichter
cards:
primary: Temperatur
secondary: ''
icon: mdi:thermometer
icon_color: blue
layout: vertical
tap_action:
action: navigate
navigation_path: temperatur
cards:
primary: Jalousie
secondary: ''
icon: mdi:window-shutter
icon_color: green
layout: vertical
tap_action:
action: navigate
navigation_path: rollos
cards:
primary: Media
secondary: ''
icon: mdi:cast-variant
icon_color: teal
layout: vertical
tap_action:
action: navigate
navigation_path: test
i have the same problem, the browser_mod panel is empty, try Edge, Chrome, Firefox, same problem.
Uncaught SyntaxError: Identifier 't' has already been declared (at browser_mod_panel.js:1:1)
is someone can help please?
help myself lol : find a glitch :
right click on the panel ā open in a new window, and the panel display!!! and i can check the register box! 4 hours for that lol
SOLVED
this code work:
type: button
tap_action:
title: ALARM
content:
type: alarm-panel
states:
- arm_away
but I need a type: custom:button-card
this code doesenāt work:
show_state: false
aspect_ratio: 1/1
state:
- color: red
value: 'on'
- color: green
value: 'off'
tap_action:
title: ALARM
content:
type: alarm-panel
states:
- arm_away
For anyone wondering: Ive got it working now. Missed the ācontentā
cards:
cards:
primary: Licht
secondary: ''
icon: mdi:lightbulb
icon_color: yellow
layout: vertical
tap_action:
title: Lichter
content:
type: entities
entities:
- entity: light.tv_board
- entity: light.hyperhdr
cards:
primary: Temperatur
secondary: ''
icon_color: blue
layout: vertical
tap_action:
action: navigate
