Bruh LED configuration question for automation section
Hi Community,
OK, I am just starting with getting into HASS.IO. I got into this because I would like to get into more home control and automation.
Right now, it’s just control. Later, automation…
Here is my project. I want to put ambient exterior lighting using LEDs on the exterior of my house. I plan on installing these under my eves, for both security and ambience. Sick example…
I am very versed on the HW and electrical aspect of all this. I have had a job in technology for the past 20 years but I’ve never seemed to pick up development. I’ve dabbled in it but just enough to be dangerous. LOL.
Bruh_Automation has some really great examples and I’ve been pouring over all the code samples.
Here is one thread that has been very helpful to me:
Here is where I am at:
R-pi3 running latest version of HASS.IO – 0.61.1
HiLetgo ESP8266 NodeMCU LUA CP2102 ESP-12E – loaded with Bruh LED sample code and connected to network
Visdoll 16.4Ft WS2812B 300Leds RGB Pixel Strip Lights, 60 Pixel/m WS2811
ALITOVE 5V 60A 300W Power Supply Transformer Adapter Converter
Used touliloup’s example and created a separate “Packages” directory and included “packages: !include_dir_named packages” under the homeassistant: section in the configuration.yaml
Underpackages, I’ve included a separate: exteriorleds.yaml which has:
light:
  - platform: mqtt_json
    name: "House Top Eve"
    state_topic: "rasperry/topeve"
    command_topic: "rasperry/topeve/set"
    effect: true
    effect_list:
      - bpm
      - candy cane
      - confetti
      - cyclon rainbow
      - dots
      - fire
      - glitter
      - juggle
      - lightning
      - noise
      - police all
      - police one
      - rainbow
      - rainbow with glitter
      - ripple
      - sinelon
      - solid
      - twinkle
    brightness: true
    flash: true
    rgb: true
    optimistic: false
    qos: 0
input_number:
  animation_speed:
    name: Top Eve Animation Speed
    initial: 150
    min: 1
    max: 150
    step: 10
  strip_brightness:
    icon: mdi:brightness-7
    initial: 150
    min: 1
    max: 150
    step: 10
When I start HASS.IO, log into the HA webpage and check the “Configuration” → “General” → “Configuration Validation button” it gives me a valid configuration.
Here is the issue.
When I include the automations section of those samples in the community help linked above, I get a ton of configuration errors.
On the main home page of the HA webpage is states:
So, I go back to the “Configuration Validation Button” and it says:
I cut and paste the code and made just a few changes to the alias and topics.
automation:
  - alias: "Top Eve Animation Speed"
    initial_state: True
    hide_entity: False
      - platform: state
        entity_id: input_number.animation_speed
      - service: mqtt.publish
        data_template:
          payload: '{"transition":{{ trigger.to_state.state | int }}}'
Here is the kicker… I also loaded Configurator: The browser-based configuration file editor for Home Assistant.
It’s telling me that the YAML looks good?
Questions:
  • I am assuming that I need the automation to actually publish changes that I make in the animation speed and brightness to the ESP8266?
  • What is wrong with the automation configuration?
Any help with the configuration would be greatly appreciated!!!
Sincere thanks.
-W
Edited for code blocks
You may need automation old: instead of automation: for the way you are doing it.
Thanks!
So, is there a better way to do this vs an “old way” assuming that automation style has changed for formatting in YAML?
-W
The new way is the automation editor and the old way is the way you have done it, I prefer the old way as the automation editor mangles the code making it hard to read and fix.
Thanks again. I appreciate the insight.
when i put in automation old instead of "automation in the exteriorleds.YAML file and rerun the configuration validation tool, it states this:
what am i missing?
Also, I am struggling through the code. One of my questions is I am assuming that I need the automation to actually publish changes that I make in the animation speed and brightness to the ESP8266?
Appreciate the help!!
Hmm I didn’t realise you had it in a package, you probably can’t do automation old: in a package. I have all my automations in automation.yaml which is called with automation old: !include automation.yaml as a standard include in the configuration.yaml
Yep that’s what the publish line does :slight_smile:
ok, it’s still throwing errors at me… Gonna need some time to look into this more for the new styles. Ugh.
I’ve did the following:
  • Added “automation old: !include automation.yaml” as you stated.
  • I’ve moved the contents of exteriorleds.yaml to the configuration.yaml file.
  • Commented out the “packages: !include_dir_named packages” the configuration.yaml file.
  • Put my animations in the animations.yaml file and deleted them from the exteriorleds.yaml file.
automation:
    initial_state: True
    hide_entity: False
      - platform: state
        data_template:
Configurator still throws this:
2018-01-21 16:58:23 ERROR (MainThread) [homeassistant.config] Invalid config for [homeassistant]: [automation old] is an invalid option for [homeassistant]. Check: homeassistant->automation old.
You can’t have the automation: inside the automations.yaml file you already stated it in the configuration file.
Also try it without the old, maybe hass.io doesn’t need it.
One other thing payload: should be payload_template:
Thanks for all your help Keith! Rock on man!
I removed the automation from automations.yaml as you suggested (still learning formatting)…
    initial_state: True
    hide_entity: False
      - platform: state
        data_template:
          payload_template: '{"transition":{{ trigger.to_state.state | int }}}'
That worked so tried and i repacked the lights in exteriorleds.yaml and uncommented the “packages: !include_dir_named packages”.
I reran the configurator and boom! Valid Config!
I had the “automation: !include automations.yaml” included in the homeassistant section and removed it to place in the bottom of the file.
homeassistant:
  latitude: redacted
  longitude: redacted
  elevation: 800
  unit_system: imperial
  time_zone: redacted
  customize: !include customize.yaml
introduction:
frontend:
config:
http:
updater:
discovery:
conversation:
history:
logbook:
map:
sun:
  - platform: yr
tts:
  - platform: google
cloud:
mqtt:
  broker: core-mosquitto
  username: redacted
  password: redacted
group: !include groups.yaml
script: !include scripts.yaml
Breakthrough!!!
Thank you for your help! I am glad i reached out to the community and you answered!!
-W
