I used esphomyaml to create a bruh multisensor on a nodemcu, it seems to be working, but I can’t get the temperature and humidity to show up in Home assistant. Checking mqtt I see the following messages:
ms1/sensor/ms1_temperature/state 21.4
ms1/sensor/ms1_humidity/state 29
this is how I’ve got the sensors setup:
- platform: mqtt
state_topic: "ms1/sensor/ms1_temperature/state"
unit_of_measurement: "C"
qos: 1
value_template: '{{value_json.temperature | round(1) }}'
- platform: mqtt
name: "Hallway Humidity"
state_topic: "ms1/sensor/ms1_humidity/state"
unit_of_measurement: "%"
qos: 1
What am I doing wrong? This is the configuration I used:
esphomeyaml:
platform: ESP8266
board: nodemcuv2
wifi:
ssid: wifi access
password: password
mqtt:
broker: 192.168.0.5
port: 1883
username:
password:
web_server:
port: 80
api:
# Enable logging
logger:
level: WARN
- platform: dht
pin: D7
temperature:
humidity:
binary_sensor:
- platform: gpio
pin: D5
device_class: motion
output:
- platform: esp8266_pwm
pin: D1
pin: D2
pin: D3
light:
- platform: rgb
red: redgpio
green: greengpio
blue: bluegpio
