Brultech Greeneye Energy Cost Sensor
No examples around here with Greeneye monitors so I thought I’d share an example configuration for calculating costs and accounting using utility_meter. Here is how to calculate the cost of my furnace and heat pump to build a gauge that shows today’s HVAC cost.
Here’s my Greeneye config:
greeneye_monitor:
  port: 8000
  monitors:
    - serial_number: XXXXXXXXX
      channels:
        - number: 3
        - number: 4
I’ve added an input_number to specify energy cost so you can change this easily from the UI.
input_number:
  energy_cost:
    unit_of_measurement: "$"
    icon: mdi:currency-usd
    mode: box
    min: 0
    max: 1
Now to convert from watt seconds to kwh. You can consider skipping this step if seeing kwh values isn’t useful for you and do this calculation in the final sensor.
  sensors:
    power_heatpump_kwh:
      friendly_name: 'Heat Pump kwH'
      unit_of_measurement: kwH
      value_template: "{{ state_attr('sensor.power_heatpump', 'watt_seconds') * 0.00000028 }}"
    power_furnace_kwh:
      friendly_name: 'Furnace kwH'
      value_template: "{{ state_attr('sensor.power_furnace', 'watt_seconds') * 0.00000028 }}"
You’ll need to use the utility_meter system to do accounting.
utility_meter:
  meter_hvac_daily:
    source: sensor.power_heatpump_kwh
    cycle: daily
  meter_furnace_daily:
    source: sensor.power_furnace_kwh
    cycle: daily
Now the sensor (template) to calculate the cost. Note that instead of rounding I use a different way to format the price so that there are always 2 digits after the decimal point.
    hvac_daily_cost:
      friendly_name: 'HVAC Daily Cost'
      value_template: >
        {{ "%.2f" | format(((states('sensor.meter_hvac_daily') | float)+(states('sensor.meter_furnace_daily')|float)) * states('input_number.energy_cost')|float) }}
      icon_template: mdi:gauge
      unit_of_measurement: '$'
Thanks for sharing this, I used this to set up the energy dashboard for our small office building. We include electricity in rent but need to be able to track if someone is going way over. This works great.
