Hello community,
I installed BSB-LAN (GitHub - fredlcore/BSB-LAN: LAN/WiFi interface for Boiler-System-Bus (BSB) and Local Process Bus (LPB) and Punkt-zu-Punkt Schnittstelle (PPS) with a Siemens(TM) controller used by Elco Thision, Brötje and similar heating systems) on my heat pump and I can manage it under HA. Thanks Frederik
I wanted to know what you do for those who have a probe. Currently I have wired the probe in bypass with the BSB-LAN. The probe (Atlantic qaa55.11x) is poorly placed (too close to the garage) and I was not planning to move it elsewhere. Is it recommended to unplug the probe and manage the temperature via HA and how do you do it?
Thanks in advance,
Sincerely
