BT Home Hub 5
I came across a way to get the uptime of a BT Home Hub very easily which is useful given the device does not support SNMP.
  - platform: scrape
    resource: http://192.168.1.254/nonAuth/wan_conn.xml
    select: 'sysuptime'
    attribute: 'value'
The returned sensor Up time is in seconds and I then use a template sensor to convert to days/hours/mins. I suspect there is additional useful information that can be pulled off the device in a similar manner.
