After spending countless hours chasing red-herrings, I’ve narrowed down my issue to including BT Proxy in my YAML. Sharing this to maybe help someone else and to see if anyone has ideas on the root cause.
I’m currently on ESPHome 2024.4.2, but I assume the issue has been there for a while and I didn’t notice it as I tested things out (I also excluded BT Proxy for a while, to speed up compiling while building things out). The issue I was experiencing was that various entities that have binary states (switches, lights) on my ESPHome device would randomly but consistently not appear to respond to changes from within HA (I’d tell it to turn on, it would stay off indefinitely). I finally realized that if I simply reloaded the ESPHome integration for the device it would show the state that I had commanded it to (and would usually work for a couple cycles before having the same issue) which ultimately led me to realize it was simply an issue of the correct state not being passed on to HA (I also left the device overnight after having issues and the state would never update to the correct one on it’s own). So I’d tell a switch to go off, it would but HA didn’t know and only gave me the option to keep telling it to go off. I’ll mention that the logs showed no issues, but it also appeared to not show the state changes I was trying to effect (which was a large part of why I kept chasing red-herrings).
Here’s my YAML, but it’s QUITE long and I don’t think there’s anything really unique or particularly complex about it, mainly it’s a lot of duplication (it’s for a Keezer and I have 5 taps, so 5x a bunch of things).
esphome:
friendly_name: Keezer
esp32:
board: esp32dev
framework:
# type: arduino
type: esp-idf
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
ota:
password: "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Keezer Fallback Hotspot"
password: "xxxxxxxxxxxxxxxxxx"
#Removed for Bluetooth Proxy feature
#captive_portal:
bluetooth_proxy:
active: true
esp32_ble_tracker:
status_led:
pin:
number: GPIO2
# inverted: true
button:
- platform: restart
- platform: safe_mode
name: Restart (Safe Mode)
# Keg 1 Pulse Counter Reset Button
name: Keg 1 Reset Pulse Counter Total
on_press:
- pulse_meter.set_total_pulses:
value: 0
# Keg 2 Pulse Counter Reset Button
name: Keg 2 Reset Pulse Counter Total
on_press:
value: 0
# Keg 3 Pulse Counter Reset Button
name: Keg 3 Reset Pulse Counter Total
on_press:
value: 0
# Keg 4 Pulse Counter Reset Button
name: Keg 4 Reset Pulse Counter Total
on_press:
value: 0
# Keg 5 Pulse Counter Reset Button
name: Keg 5 Reset Pulse Counter Total
on_press:
value: 0
number:
#REMOVED RESTORE VALUES TO KEEP FROM WEARING OUT THE FLASH WHILE TESTING
# Keg 1 Full Volume
name: Keg 1 Full
optimistic: true
icon: mdi:gauge-full
device_class: volume_storage
unit_of_measurement: gal
max_value: 6
min_value: 0
step: 0.01
initial_value: 5
mode: box
# restore_value: true
# Keg 2 Full Volume
name: Keg 2 Full
optimistic: true
max_value: 6
min_value: 0
step: 0.01
initial_value: 5
mode: box
# Keg 3 Full Volume
name: Keg 3 Full
optimistic: true
max_value: 6
min_value: 0
step: 0.01
initial_value: 5
mode: box
# Keg 4 Full Volume
name: Keg 4 Full
optimistic: true
max_value: 6
min_value: 0
step: 0.01
initial_value: 5
mode: box
# Keg 5 Full Volume
name: Keg 5 Full
optimistic: true
max_value: 6
min_value: 0
step: 0.01
initial_value: 1.5
mode: box
# Keg 1 Consumed (Only updated on Keezer Shutdown)
name: Keg 1 Consumed LTS
optimistic: true
icon: mdi:gauge
max_value: 6
min_value: 0
step: 0.01
initial_value: 0
mode: box
# Keg 2 Consumed (Only updated on Keezer Shutdown)
name: Keg 2 Consumed LTS
optimistic: true
icon: mdi:gauge
max_value: 6
min_value: 0
step: 0.01
initial_value: 0
mode: box
# Keg 3 Consumed (Only updated on Keezer Shutdown)
name: Keg 3 Consumed LTS
optimistic: true
icon: mdi:gauge
max_value: 6
min_value: 0
step: 0.01
initial_value: 0
mode: box
# Keg 4 Consumed (Only updated on Keezer Shutdown)
name: Keg 4 Consumed LTS
optimistic: true
icon: mdi:gauge
max_value: 6
min_value: 0
step: 0.01
initial_value: 0
mode: box
# Keg 5 Consumed (Only updated on Keezer Shutdown)
name: Keg 5 Consumed LTS
optimistic: true
icon: mdi:gauge
max_value: 6
min_value: 0
step: 0.01
initial_value: 0
mode: box
# Keg 1 Pulse Conversion
name: Keg 1 Pulse Conversion
optimistic: true
icon: mdi:pulse
unit_of_measurement: pulses/gal
max_value: 5000
min_value: 0
step: 1
initial_value: 2566
mode: box
# Keg 2 Pulse Conversion
name: Keg 2 Pulse Conversion
optimistic: true
icon: mdi:pulse
max_value: 5000
min_value: 0
step: 1
initial_value: 2566
mode: box
# Keg 3 Pulse Conversion
name: Keg 3 Pulse Conversion
optimistic: true
icon: mdi:pulse
max_value: 5000
min_value: 0
step: 1
initial_value: 2566
mode: box
# Keg 4 Pulse Conversion
name: Keg 4 Pulse Conversion
optimistic: true
icon: mdi:pulse
max_value: 5000
min_value: 0
step: 1
initial_value: 2566
mode: box
# Keg 5 Pulse Conversion
name: Keg 5 Pulse Conversion
optimistic: true
icon: mdi:pulse
max_value: 5000
min_value: 0
step: 1
initial_value: 2566
mode: box
switch:
# Keezer Switch
icon: mdi:glass-mug-variant
optimistic: true
turn_on_action:
# - if:
# condition:
# - light.is_off: keezer_lights
# then:
#Tap 1 LEDs
# - light.turn_on:
# id: tap_1_leds
# brightness: 100%
# red: 95%
# green: 37%
# blue: 71%
#Tap 3 LEDs
# - light.turn_on:
# id: tap_3_leds
# brightness: 100%
# red: 0%
# green: 69%
# blue: 31%
#Tap 4 LEDs
# - light.turn_on:
# id: tap_4_leds
# brightness: 100%
# red: 50%
# green: 50%
# blue: 50%
# else:
#Tap 1 LEDs
# - light.turn_on:
# id: tap_1_leds
# brightness: 100%
# red: 95%
# green: 37%
# blue: 71%
#Tap 3 LEDs
# - light.turn_on:
# id: tap_3_leds
# brightness: 100%
# red: 0%
# green: 69%
# blue: 31%
#Tap 4 LEDs
# - light.turn_on:
# id: tap_4_leds
# brightness: 100%
# red: 50%
# green: 50%
# blue: 50%
- light.turn_on:
brightness: 100%
red: 0%
green: 5%
blue: 100%
- switch.turn_on: keg_valves
value: 0
value: 0
value: 0
value: 0
value: 0
turn_off_action:
# - light.turn_off:
# id: tap_1_leds
# - light.turn_off:
# id: tap_2_leds
# - light.turn_off:
# id: tap_3_leds
# - light.turn_off:
# id: tap_4_leds
# - light.turn_off:
# id: tap_5_leds
- light.turn_off:
- switch.turn_off: keg_valves
- number.set:
value: !lambda "return (id(keg_1_consumed_value_lts).state + (id(keg_1_poured_volume).state * 0.0078125));"
- number.set:
value: !lambda "return (id(keg_2_consumed_value_lts).state + (id(keg_2_poured_volume).state * 0.0078125));"
- number.set:
value: !lambda "return (id(keg_3_consumed_value_lts).state + (id(keg_3_poured_volume).state * 0.0078125));"
- number.set:
value: !lambda "return (id(keg_4_consumed_value_lts).state + (id(keg_4_poured_volume).state * 0.0078125));"
- number.set:
value: !lambda "return (id(keg_5_consumed_value_lts).state + (id(keg_5_poured_volume).state * 0.0078125));"
value: 0
value: 0
value: 0
value: 0
value: 0
# Keg Valves
- platform: gpio
pin: GPIO19
device_class: switch
icon: mdi:pipe-valve
# Freezer Relay
- platform: gpio
pin: GPIO26
icon: mdi:snowflake-thermometer
text_sensor:
- platform: wifi_info
ip_address:
# Send WiFi signal strength & uptime to HA
- platform: wifi_signal
update_interval: 60s
disabled_by_default: true
- platform: uptime
# Keg 1 Pulse Meter
- platform: pulse_meter
pin: GPIO4
name: Keg 1 Pulse Meter
internal_filter: 20us #Default is 13us. Used 20, 10, 5, 2 with Pulse and no noise.
internal_filter_mode: PULSE
timeout: 1s
total:
name: Keg 1 Total Pulses
# Keg 2 Pulse Meter
pin: GPIO13
name: Keg 2 Pulse Meter
timeout: 1s
total:
name: Keg 2 Total Pulses
# Keg 3 Pulse Meter
pin: GPIO16
name: Keg 3 Pulse Meter
timeout: 1s
total:
name: Keg 3 Total Pulses
# Keg 4 Pulse Meter
pin: GPIO17
name: Keg 4 Pulse Meter
timeout: 1s
total:
name: Keg 4 Total Pulses
# Keg 5 Pulse Meter
pin: GPIO18
name: Keg 5 Pulse Meter
timeout: 1s
total:
name: Keg 5 Total Pulses
# Keg 1 Percent Full
name: Keg 1 Percent Full
state_class: measurement
unit_of_measurement: "%"
icon: mdi:keg
lambda: |-
if (id(keezer_switch).state and (id(keg_1_pulse_meter_total).state > 10)) {
return (((id(keg_1_full_value).state - (id(keg_1_consumed_value_lts).state + (id(keg_1_pulse_meter_total).state * (1 / id(keg_1_pulse_conversion).state)))) / (id(keg_1_full_value).state)) * 100);
} else {
return (((id(keg_1_full_value).state - id(keg_1_consumed_value_lts).state) / (id(keg_1_full_value).state)) * 100);
update_interval: 1s
# Keg 2 Percent Full
name: Keg 2 Percent Full
icon: mdi:keg
lambda: |-
if (id(keezer_switch).state and (id(keg_2_pulse_meter_total).state > 10)) {
return (((id(keg_2_full_value).state - (id(keg_2_consumed_value_lts).state + (id(keg_2_pulse_meter_total).state * (1 / id(keg_2_pulse_conversion).state)))) / (id(keg_2_full_value).state)) * 100);
} else {
return (((id(keg_2_full_value).state - id(keg_2_consumed_value_lts).state) / (id(keg_2_full_value).state)) * 100);
update_interval: 1s
# Keg 3 Percent Full
name: Keg 3 Percent Full
icon: mdi:keg
lambda: |-
if (id(keezer_switch).state and (id(keg_3_pulse_meter_total).state > 10)) {
return (((id(keg_3_full_value).state - (id(keg_3_consumed_value_lts).state + (id(keg_3_pulse_meter_total).state * (1 / id(keg_3_pulse_conversion).state)))) / (id(keg_3_full_value).state)) * 100);
} else {
return (((id(keg_3_full_value).state - id(keg_3_consumed_value_lts).state) / (id(keg_3_full_value).state)) * 100);
update_interval: 1s
# Keg 4 Percent Full
name: Keg 4 Percent Full
icon: mdi:keg
lambda: |-
if (id(keezer_switch).state and (id(keg_4_pulse_meter_total).state > 10)) {
return (((id(keg_4_full_value).state - (id(keg_4_consumed_value_lts).state + (id(keg_4_pulse_meter_total).state * (1 / id(keg_4_pulse_conversion).state)))) / (id(keg_4_full_value).state)) * 100);
} else {
return (((id(keg_4_full_value).state - id(keg_4_consumed_value_lts).state) / (id(keg_4_full_value).state)) * 100);
update_interval: 1s
# Keg 5 Percent Full
name: Keg 5 Percent Full
icon: mdi:keg
lambda: |-
if (id(keezer_switch).state and (id(keg_5_pulse_meter_total).state > 10)) {
return (((id(keg_5_full_value).state - (id(keg_5_consumed_value_lts).state + (id(keg_5_pulse_meter_total).state * (1 / id(keg_5_pulse_conversion).state)))) / (id(keg_5_full_value).state)) * 100);
} else {
return (((id(keg_5_full_value).state - id(keg_5_consumed_value_lts).state) / (id(keg_5_full_value).state)) * 100);
update_interval: 1s
# Keg 1 Poured Volume
name: Keg 1 Poured Volume
unit_of_measurement: fl. oz.
accuracy_decimals: 1
icon: mdi:beer
lambda: |-
return ((id(keg_1_pulse_meter_total).state * (1 / id(keg_1_pulse_conversion).state)) * 128);
} else {
return 0;
update_interval: 1s
# Keg 2 Poured Volume
name: Keg 2 Poured Volume
icon: mdi:beer
lambda: |-
return ((id(keg_2_pulse_meter_total).state * (1 / id(keg_2_pulse_conversion).state)) * 128);
} else {
return 0;
update_interval: 1s
# Keg 3 Poured Volume
name: Keg 3 Poured Volume
icon: mdi:beer
lambda: |-
return ((id(keg_3_pulse_meter_total).state * (1 / id(keg_3_pulse_conversion).state)) * 128);
} else {
return 0;
update_interval: 1s
# Keg 4 Poured Volume
name: Keg 4 Poured Volume
icon: mdi:beer
lambda: |-
return ((id(keg_4_pulse_meter_total).state * (1 / id(keg_4_pulse_conversion).state)) * 128);
} else {
return 0;
update_interval: 1s
# Keg 5 Poured Volume
name: Keg 5 Poured Volume
icon: mdi:beer
lambda: |-
return ((id(keg_5_pulse_meter_total).state * (1 / id(keg_5_pulse_conversion).state)) * 128);
} else {
return 0;
update_interval: 1s
# Keg 1 Flowrate
name: Keg 1 Flowrate
device_class: volume_flow_rate
unit_of_measurement: gal/min
accuracy_decimals: 2
icon: mdi:water-pump
lambda: |-
if (id(keezer_switch).state) {
return ((id(keg_1_pulse_meter).state * (1 / id(keg_1_pulse_conversion).state)));
} else {
return 0;
update_interval: 1s
# Keg 2 Flowrate
name: Keg 2 Flowrate
lambda: |-
return ((id(keg_2_pulse_meter).state * (1 / id(keg_2_pulse_conversion).state)));
} else {
return 0;
update_interval: 1s
# Keg 3 Flowrate
name: Keg 3 Flowrate
lambda: |-
return ((id(keg_3_pulse_meter).state * (1 / id(keg_3_pulse_conversion).state)));
} else {
return 0;
update_interval: 1s
# Keg 4 Flowrate
name: Keg 4 Flowrate
lambda: |-
return ((id(keg_4_pulse_meter).state * (1 / id(keg_4_pulse_conversion).state)));
} else {
return 0;
update_interval: 1s
# Keg 5 Flowrate
name: Keg 5 Flowrate
lambda: |-
return ((id(keg_5_pulse_meter).state * (1 / id(keg_5_pulse_conversion).state)));
} else {
return 0;
update_interval: 1s
# Gas Weight RAW Sensor
- platform: hx711
# name: Gas Value RAW
# id: gas_value_raw
name: Gas Percent Full
dout_pin: GPIO21
clk_pin: GPIO22
update_interval: 1s #Used 0.1s for Beehive
filters:
# Used this avergae for the Beehive
- sliding_window_moving_average:
window_size: 600
send_every: 15
send_first_at: 15
# From Particle Code
# Gas_Empty_Calibration=7213399;
# Gas_Full_Calibration=7335977;
# Actual readings are showing as negative
- calibrate_linear:
method: least_squares
datapoints:
- -7213399 -> 0
- -7335977 -> 100
# Temperature Sensor
- platform: dallas
address: 0xff3190d4454bfa28
name: Keezer Temperature
# Pressure Transducer
- platform: adc
pin: GPIO39
icon: mdi:gas-cylinder
unit_of_measurement: psi
device_class: pressure
update_interval: 1s
attenuation: auto
filters:
# - median:
# window_size: 11
# send_every: 11
# send_first_at: 11
window_size: 15
send_every: 15
send_first_at: 15
- calibrate_linear:
datapoints:
# Sensor advertises 0.5V=0psi & 4.5V=100psi. These values are from testing (using the analog gauge on the gas tank):
- 0.28 -> 0
- 1.98 -> 40
- clamp:
min_value: 0
max_value: 100
ignore_out_of_range: false #This determines whether it just ignores out of range values or treats them as a max/min value
binary_sensor:
# Lid Sensor
- platform: gpio
pin:
number: GPIO23
inverted: true
mode:
input: true
pullup: true
device_class: door
on_press:
then:
- light.turn_on: interior_lights
on_release:
then:
- light.turn_off: interior_lights
light:
# Interior Lights
- platform: binary
icon: mdi:led-strip
output: interior_lights_output
# Keezer Lights
# - platform: neopixelbus
# type: GRB
# variant: WS2812
# pin: GPIO27
# num_leds: 37
# name: Keezer Lights
# id: keezer_lights
# icon: mdi:wall-sconce-flat
- platform: partition
name: "Tap #1 LEDs"
segments:
- id: keezer_lights
to: 7
name: "Tap #2 LEDs"
segments:
- id: keezer_lights
to: 14
name: "Tap #3 LEDs"
segments:
- id: keezer_lights
to: 21
name: "Tap #4 LEDs"
segments:
- id: keezer_lights
to: 28
name: "Tap #5 LEDs"
segments:
- id: keezer_lights
to: 36
- platform: esp32_rmt_led_strip
rgb_order: GRB
is_rgbw: False
pin: GPIO27
num_leds: 37
rmt_channel: 0
chipset: WS2812
max_refresh_rate: 200ms #16ms ~= 60Hz # 100ms seemed to help quite a bit, but still got some flicker at times
effects:
- addressable_color_wipe:
colors:
- red: 100%
green: 0%
blue: 0%
white: 0%
num_leds: 15
- red: 0%
green: 100%
blue: 0%
white: 0%
num_leds: 15
add_led_interval: 200ms
reverse: false
colors:
- red: 100%
green: 0%
blue: 0%
white: 0%
num_leds: 15
- red: 100%
green: 87%
blue: 0%
white: 0%
num_leds: 15
reverse: false
- random:
transition_length: 5s
update_interval: 7s
- addressable_rainbow:
speed: 10
width: 50
name: Random Color Wipe
colors:
- random: true
num_leds: 15
reverse: false
output:
# Interior Lights
- id: interior_lights_output
platform: gpio
pin: GPIO25
# Freezer Temperature Controller
climate:
- platform: thermostat
sensor: keezer_temperature
visual:
min_temperature: 32 °F
max_temperature: 60 °F
temperature_step: 0.5 °F
min_cooling_off_time: 300s
min_cooling_run_time: 120s
min_idle_time: 300s
cool_action:
- switch.turn_on: freezer_relay
idle_action:
- switch.turn_off: freezer_relay
default_preset: Beer
on_boot_restore_from: memory
preset:
- name: Beer
mode: COOL
default_target_temperature_high: 40 °F
dallas:
- pin: GPIO32
update_interval: 15s
Simply commenting out the BT Proxy part and it’s been working flawlessly for days and countless cycles of switching things on/off trying to get it to break again:
bluetooth_proxy:
active: true
esp32_ble_tracker:
Anything jump out? This was a situation where I really had no specific need for BT Proxy, and getting rid of it ultimately allowed me to switch to the Arduino framework which then allowed me to use the Neopixel library, which is SOOOO much better than the alternative.
