As far as I can see both are connected to esphome and working but if I unplug the first esp32 and leave only the second one plugged in, nothing works (I have some switchbot curtains which go unavailable when just the 2nd bt proxy is plugged in)
For this second esp32, in the log I can see it finding all sorts of devices however nothing is being passed to HA:
[15:34:31][C][ota:089]: Over-The-Air Updates:
[15:34:31][C][ota:090]: Address: bt-proxy.local:3232
[15:34:31][C][api:138]: API Server:
[15:34:31][C][api:139]: Address: bt-proxy.local:6053
[15:34:31][C][api:143]: Using noise encryption: NO
[15:37:58][V][bluetooth_proxy:026]: Proxying packet from - 5D:6D:F0:xxxx. RSSI: -86 dB
[15:37:59][V][bluetooth_proxy:026]: Proxying packet from Smart Tag - 5F:4D:0D:xxxx. RSSI: -54 dB
[15:38:01][V][bluetooth_proxy:026]: Proxying packet from - 4D:35:E6:xxxx. RSSI: -72 dB
[15:38:02][V][bluetooth_proxy:026]: Proxying packet from - 5D:6D:F0:xxxx. RSSI: -77 dB
As far as I can tell the 2nd BT proxy doesn’t send anything to HA even though it is working correctly?
I would have assumed that any BT proxy in the vicinity can control the switchbot curtains for example or once connected to the first one they will only respond to that BT proxy? Silly if that’s the case
The esp32s were created using the BTproxy online tool: ESPHome Bluetooth Proxy
So that code above was added by the online tool, I just added the logger to see what it is doing.
One works, the one second doesn’t, same code.
Am I missing something?
Switchbot curtains, which have been paired ok with one esp32 device so maybe it only works with that esp32 now not with others which I have around the house?
I thought any BT proxy would be able to send commands to any of the added integrations but maybe not?
Depends when you did it as they have updated ESPHome and changed the code. See
If you have the correct code then you should check it by using ESPHome in HA. Using the online tool only installs the Firmware at the time of install. They could be out of date.
Assume you have the latest ESPHome (Current version: 2022.10.0) and you have updated the devices. That is important… you need to make sure you have update the devices (ESP32) with the latest firmware. Try clean build files and install again.
Once you have done that and you are still having problems then check connectivity of your Wi-Fi to the ESP32. You may want to get a Olimex ESP32 Power-over-Ethernet ISO.
It doesn’t work like that it finds the best Bluetooth connection. There is no pairing. I think Switchbot works better with Olimex ESP32 Power-over-Ethernet ISO… or a ESP32 with direct Ethernet connection.
Yes it can.
You could also try getting a ZEXMTE BT-505 adapter with -63 RSSI and a USB extension cable.
this also may help
also have a look at troubleshooting & interference
So it turns out both devices do in fact work. I was able to use ibeacon integration with the second esp32 just fine but what does not work is the second esp32 to control switchbot, as soon as the first esp32 is unplugged switchbot integration goes unavailable so it must be paired to just one device or something?
Using Esphome 2022.10 and latest FW builds, cleaned them a few times.
Swtichbot works flawlessly only when the first esp32 device is switched on
Are they the same ESP32 or is one a ESP32-C3?. ESP32-C3 don’t work.
Maybe if they are different ESP32 it could be just that one ESP32.
Can the switchbolt reach the second esp32
I think they are having issues with switchbot.
Some BT devices only like to be connected to one thing at a time but if you disconnect it from the ESP32 it should connect to the other one so long as it is within range. It must be a switchbot thing.
Yeah I was going to go for a few atoms lite but running out of IPs in my network with everything being smart now so I am hoping to do a bit of 2-in-1 with the BT proxy and multi sensor ESP device.
