Btcino Classe 300 / 344622
Hi there,
I have the below ring and it seems to me there’s no connectivity / wifi. I for sure don’t have separate wifi controller from Btcino. The issue I have is that I don’t register the ring while being far from ring. That being said I thought it shall be possible to add some ESP32 into the device and integrate into ZHA? Me not being electrician this is a bit above my expertise but I though it might be simple enough solution that I could handle with some guidance knowing how to plug it inside the device.
There’s not a lot you can do with indoor unit. But you have contact for external ringer if hearing is the only problem. To have a control of your system with esphome you should interface with door unit.
and this external ringer contact is there something I could leverage to put ESP32 there and register the ringing? I would very much like to stay out of doing something with door unit as it would be probably far to catch zigbee signal anyway.
One way or another yes. I don’t know what that ringer contact outputs. Do you have multimeter?
I don’t but I can buy one, some tips on Aliexpress for instance? Thanks!
No tips for that.
Anyway for your task almos any multimeter is fine. You can find some 20eur ones in Amazon. I personally like UNI-T brand.
