How can I disable adding new entities (effectively autodiscovery) in BTHOME? HA 2023.7 removed the cog menu in Services and devices, meaning there’s no apparent way to do this. I can only access this setting for each discovered/added device but not the BThome integration in general.
Auto discovery of bluetooth devices is handled by the bluetooth: integration, which is provided by default config. You can click ignore on each item, or disable them. If you delete them, it will come back… just like every other integration.
