Hi.
I’m very interested to BTHome project and I’ve learned to create a custom sensor on ESP32 board that reads voltage values on pin 32 ad send it in the BLE payload.
Here is the code:
Based on Neil Kolban example for IDF: https://github.com/nkolban/esp32-snippets/blob/fe3d318acddf87c6918944f24e8b899d63c816dd/cpp_utils/tests/BLE%20Tests/SampleScan.cpp
Ported to Arduino ESP32 by pcbreflux
Modified to work with NimBLE
Modified for V2 by Chreece
Modified by countrysideboy: Code cleanups, Chop Data, Encryption
BLE advertisement format from https://bthome.io/
#include "BTHome.h"
#define DEVICE_NAME "DIY-pin32_Voltage_1" // The name of the sensor
#define ENABLE_ENCRYPT // Remove this line for no encryption
String BIND_KEY = "F39E4007E76F4E56C4CE4A0DDD64E1C2"; // Change this key with a string containing 32 of: a-f and 0-9 characters (hex) this will be asked in HA
BTHome bthome;
void setup() {
Serial.begin(115200);
//set the resolution to 12 bits (0-4096)
analogReadResolution(12);
#ifdef ENABLE_ENCRYPT
bthome.begin(DEVICE_NAME, true, BIND_KEY, false);
#else
bthome.begin(DEVICE_NAME, false, "", false);
#endif
void loop() {
// read the analog / millivolts value for pin 2:
float analogValue = analogRead(32);
float analogVolts = analogReadMilliVolts(32);
// print out the values you read:
Serial.printf("ADC analog value = %f\n",analogValue);
Serial.printf("ADC millivolts value = %.*f\n",1,analogVolts);
delay(1000); // delay in between reads for clear read from serial
//MEASUREMENT_MAX_LEN = 23, ENABLE_ENCRYPT will use extra 8 bytes, so each Measurement should smaller than 15
// 1st method: just addMeasurement as much as you can, the code will split and send the adv packet automatically
// each adv packet sending lasts for 1500ms
bthome.resetMeasurement();
// bthome.addMeasurement(sensorid, value) you can use the sensorids from the BTHome.h file
// the Object ids of addMeasurement have to be applied in numerical order (from low to high) in your advertisement
bthome.addMeasurement(ID_VOLTAGE, analogVolts);//3
bthome.sendPacket();
bthome.stop();
//Object ids by order
#if 0
#define ID_PACKET 0x00
#define ID_BATTERY 0x01
#define ID_TEMPERATURE_PRECISE 0x02
#define ID_HUMIDITY_PRECISE 0x03
#define ID_PRESSURE 0x04
#define ID_ILLUMINANCE 0x05
#define ID_MASS 0x06
#define ID_MASSLB 0x07
#define ID_DEWPOINT 0x08
#define ID_COUNT 0x09
#define ID_ENERGY 0x0A
#define ID_POWER 0x0B
#define ID_VOLTAGE 0x0C
#define ID_PM25 0x0D
#define ID_PM10 0x0E
#define STATE_GENERIC_BOOLEAN 0x0F
#define STATE_POWER_ON 0x10
#define STATE_OPENING 0x11
#define ID_CO2 0x12
#define ID_TVOC 0x13
#define ID_MOISTURE_PRECISE 0x14
#define STATE_BATTERY_LOW 0x15
#define STATE_BATTERY_CHARHING 0x16
#define STATE_CO 0x17
#define STATE_COLD 0x18
#define STATE_CONNECTIVITY 0x19
#define STATE_DOOR 0x1A
#define STATE_GARAGE_DOOR 0x1B
#define STATE_GAS_DETECTED 0x1C
#define STATE_HEAT 0x1D
#define STATE_LIGHT 0x1E
#define STATE_LOCK 0x1F
#define STATE_MOISTURE 0x20
#define STATE_MOTION 0x21
#define STATE_MOVING 0x22
#define STATE_OCCUPANCY 0x23
#define STATE_PLUG 0x24
#define STATE_PRESENCE 0x25
#define STATE_PROBLEM 0x26
#define STATE_RUNNING 0x27
#define STATE_SAFETY 0x28
#define STATE_SMOKE 0x29
#define STATE_SOUND 0x2A
#define STATE_TAMPER 0x2B
#define STATE_VIBRATION 0x2C
#define STATE_WINDOW 0x2D
#define ID_HUMIDITY 0x2E
#define ID_MOISTURE 0x2F
#define EVENT_BUTTON 0x3A
#define EVENT_DIMMER 0x3C
#define ID_COUNT2 0x3D
#define ID_COUNT4 0x3E
#define ID_ROTATION 0x3F
#define ID_DISTANCE 0x40
#define ID_DISTANCEM 0x41
#define ID_DURATION 0x42
#define ID_CURRENT 0x43
#define ID_SPD 0x44
#define ID_TEMPERATURE 0x45
#define ID_UV 0x46
#define ID_VOLUME1 0x47
#define ID_VOLUME2 0x48
#define ID_VOLUMEFR 0x49
#define ID_VOLTAGE1 0x4A
#define ID_GAS 0x4B
#define ID_GAS4 0x4C
#define ID_ENERGY4 0x4D
#define ID_VOLUME 0x4E
#define ID_WATER 0x4F
#endif
The problem is that even if the voltage value on pin 32 is correctly showed in the Arduino IDE monitor:
It is showed in a very different way on the HA’s dashboard:
Any idea?
Thanks in advance.
