⚪ Bubble Card - A minimalist card collection for Home Assistant with a nice pop-up touch
This is exactly what im hoping for.
Whats the code for your helper?
Have you see this?
I have no idea where to find the code for helpers (created via GUI), it is just a simple input_number helper:
This solution is quick’n dirty, if you would like a clean solution you should consider MrBearPresidens link.
I have not. This is awesome. Thanks.
I found the error:
Instead of the curly bracket I had a normal bracket at the end of the “.bubble-sub-button-container”.
Here is the working code:
type: vertical-stack
cards:
  - type: custom:bubble-card
    card_type: button
    button_type: name
    card_layout: large
    icon: mdi:bathtub
    show_state: false
    button_action:
      action: navigate
      navigation_path: Badezimmer
      tap_action:
        action: navigate
    sub_button:
      - entity: sensor.raumklima_bad_co2
        show_background: false
        show_state: true
        icon: mdi:molecule-co2
        tap_action: more-info
        hold_action:
          action: more-info
      - entity: sensor.raumklima_bad_luftfeuchtigkeit
        show_state: true
        hold_action:
          action: more-info
      - entity: sensor.raumklima_bad_temperatur
        show_state: true
        hold_action:
          action: more-info
    styles: |
      .bubble-button-card-container,
      .bubble-button-card {
        height: 80px !important;
        background: transparent !important;
        font-size: 15px !important;
      .bubble-icon-container,
      .bubble-name-container {
        top: -25px;
      .bubble-sub-button-container {
         position: absolute !important;
         bottom: 0px !important;
         justify-content: left !important;
         width: calc(100% - 20px) !important;
         right: inherit !important;
         margin: 10px !important;
         height: 30px !important;
      .bubble-feedback-element {
         height: 200% !important;
      .bubble-name {
      .bubble-sub-button-1 {
        background-color: ${hass.states['sensor.raumklima_bad_co2'].state >= 1250 ? 'tomato' :
                          hass.states['sensor.raumklima_bad_co2'].state >= 750 ? '#FFB347' :
                          hass.states['sensor.raumklima_bad_co2'].state >= 100 ? 'transparent' :
                          'transparent'} !important;
      .bubble-sub-button-2 {
        background-color: ${hass.states['sensor.raumklima_bad_luftfeuchtigkeit'].state >= 80 ? 'tomato' :
                          hass.states['sensor.raumklima_bad_luftfeuchtigkeit'].state >= 60 ? '#FFB347' :
        color: ${hass.states['sensor.raumklima_bad_luftfeuchtigkeit'].state >= 60 && hass.states['sensor.raumklima_bad_luftfeuchtigkeit'].state <= 80 ? '#383838' : 'inherit'} !important;
      .bubble-sub-button-3 {
        background-color: ${hass.states['sensor.raumklima_bad_temperatur'].state >= 28 ? 'tomato' :
                          hass.states['sensor.raumklima_bad_temperatur'].state >= 23 ? '#FFB347' :
                          hass.states['sensor.raumklima_bad_temperatur'].state >= 17 ? 'transparent' :
                          'LightSkyBlue'} !important;
        color: ${hass.states['sensor.raumklima_bad_temperatur'].state < 17 ? '#383838' : 'inherit'} !important;
    tap_action:
      action: navigate
    show_icon: false
    force_icon: false
    scrolling_effect: false
Hello, serched this thread, but with no luck and decided to ask.
It is possible to add frame around Bubble button and change frame color?
So bubble button have the same frame as other button on screenshot.
If it is possible whats style name/code to add that frame?
frame
What are you looking for? A progress bar button card like this?
Schermopname 2024-12-22 om 11.27.17
Any chance of sharing the code for these? Look great!
That progress bar (timer for switch) is in totaly different card, but i want add the thin light golden border line/frame around that card to Bubble card so both cards look the same.
Not sure if see good, but in your cards there is white border line around cards or its just added shadow effect? (hard to say when its white on white). But if its white border like it could work.
When you look on turned off switch, there is just dark background, and i want to add that bordel line around button.
gg
