Thanks it looks great. But still working on nice pulsing color for Bubble switch when doors are open. My old parents got same eye problem and understanding technology. For them could be the best nice pulsing color for open sensor. Anymation is realy cool and it will become a permanent part of my HA sensor
If you set it up through the UI on the integrations page you can setup a sensor for most formated date objects. So you need to use the one for Time and you can add that entity to the header of the Bubble-Card header.
I’ve got 12 different popups that are triggered by buttons–all good there.
I can have a popup close after a certain amount of time–good there as well.
How can I get a popup to open after a certain amount of time? Say I have a popup open and I am done with it and manually close it or it closes after ‘x’ amount of time. I now want another popup to open automatically. And maybe a bit fancier: open a certain popup when ‘y’ condition is met and another when it isn’t met.
Any ideas? Basically, I don’t know how to tell when there is no popup selected and use that as a trigger.
Has anyone tried the cover button. There is a weird behavior of open and close icon. The default changes to close and open shapes but the custom icon doesn’t maintain the shape. As you can see the window is open, the default icon appears unfilled but the the custom icon doesn’t change… it changes momentarily to the one provided but then immediately falls back to close icon. The close icon is correct when its closed.
How can I reduce the size of the entire bubble card? I have a few separator cards that I am using as titles for sections and they are much larger than the actual content itself. Would like them to essentially be as small in height as possible to ensure the content is presented correctly.
How it looks today below. As you can see there is quite a big gap between the card above and the title, can confirm it is the height of the title not the bottom of the card above causing the issue.
