My open and close icons for the window are not working…for your blinds…is that the open icon?
I used the same for my open window but what I showed from the pics is that @Cloos default open and close icons work showing the state of the window/cover/blinds as fill and unfill icon, while my optional icons of closed and open are not working.
How did you manage to display the list as friendly names as well…for me the entire select list shows all names as discharge.Dishwasher.xx instead of Normal 45, Intensive 60
This is the cover card. And you see in the screenshot that the upwards icon is greyed out, as the cover is already open. This also works with the custom buttons that I have defined, which you can also see in the screenshot.
I’m not referring to up down icons…instead the cover state icons. They are supposed to be what I have specified in open and close states.
I have duplicated the instance, the default window coverings icons work fine for open and closed states but not the optional ones as I have set in UI editor. It appears to me a code bug.
The question came here (and on Github) already to have a dropdown for scenes.
Here I wrote down a system that achieves this.
Ok, but also the custom icon changes for me:
Here it is closed, see my posting from this morning, there it is open and has a different icon.
Ive been struggling with this too. I tried to re-size the card but didnt seem to work. The separator seems to be aligned with the top of the card container.
My guess is you have to resize both the card, and the card container.
Settings > Devices & Services > Helpers
- Create Helper, Then select Group > Light Group
Going round in circles here and was hoping could point me in the right direction, so have a pop up in a media bubble and would like to change the background based on the state of the switch (on/off). I’ve tried the following code but can’t get the “off “ colour to match the rest of my dash.
.bubble-button-background {
background-color: ${state === 'on' ? 'rgba(63,91,102,0.75)' : 'rgba(0,0,0,0.75)'} !important;
So the offending switch button is the top “tv on/off”
The lower two are how I would like the top one to look off and on
Hoping someone can guide me on n resolving this
Many thanks
I use an edited version of the Bubble theme by Cloos:
I forked it and edited it here on GitHub:
Some more colors I used on the custom CSS of the cards:
green:
.bubble-button-card-container {
--bubble-main-background-color: #244e3f;
--bubble-button-icon-background-color: #23302d;
.bubble-range-fill {
--bubble-accent-color: #009e73;
.bubble-icon {
color: white;
opacity: 0.8 !important;
red:
--bubble-main-background-color: #b32e4a;
--bubble-button-icon-background-color: #412329;
.bubble-icon {
color: white;
purple:
--bubble-main-background-color: #765fbb;
--bubble-button-icon-background-color: #30274c;
.bubble-icon {
color: white;
Hoping I’ve sorted,
Changed opacity of on colour to 1
opacity: 1 !important;
background-color: ${state === 'on' ? 'rgba(63,91,102,1.0)' : 'black'} !important;
Next mystery hoping someone can help with
I have a bubble card embedded in a picture elements card to use as a room card. The issue I have is that the states of the sub buttons aren’t updating in real time for some reason when they are in the picture elements card, unless I refresh the page. They update fine on their own but when I add it as an element it doesn’t update. Looks like the main entity for the bubble card does however, which is the temperature.
I could probably solve this using a button card instead of a picture elements but the picture elements card is much more straightforward to configure.
Any ideas what might be causing this to not update?
type: picture-elements
card_mod:
style: |
ha-card {
border-radius: 36px;
image: /local/Rumpus.png
aspect_ratio: "16:9"
elements:
- type: custom:mod-card
style:
top: 13%
left: 91%
width: 10%
card_mod:
style: |
ha-card {
-webkit-backdrop-filter: blur(4px) !important;
card:
type: custom:button-card
style: |
ha-card {
entity: {}
icon: mdi:arrow-top-right
color: rgba(0,0,0,0.8)
color_type: card
tap_action:
action: navigate
navigation_path: "#rumpus"
styles:
card:
- height: 45px
- width: 45px
- border-radius: 80px
style:
top: 85%
left: 50%
width: 96%
card_mod:
style: |
ha-card {
card:
type: custom:bubble-card
card_type: button
button_type: state
entity: sensor.rumpus_sensor_temperature
icon: mdi:desk
show_state: true
tap_action:
action: navigate
button_action:
tap_action:
action: navigate
styles: |-
.bubble-button-card {
opacity: 1.0;
background: rgba(0,0,0,0.1) !important;
-webkit-backdrop-filter: blur(2px) !important;
background-color: rgba(0,0,0,0) !important;
filter: blur(50%) !important;
background-color: var(--card-background-color) !important;
.bubble-icon {
color: var(--google-teal) !important;
opacity: 1.0 !important;
.bubble-icon-container {
border-style: solid !important;
border-width: 2px;
.bubble-name {
font-size: auto !important;
.bubble-sub-button-1{
background-color: ${hass.states['light.lounge_lamp'].state === 'on' ? 'var(--google-yellow)' : ''} !important;
opacity: ${hass.states['light.lounge_lamp'].state === 'on' ? '1.0' : '0.6'} !important;
.bubble-sub-button-2{
background-color: ${hass.states['light.lounge_downlights'].state === 'on' ? 'var(--google-yellow)' : ''} !important;
opacity: ${hass.states['light.lounge_downlights'].state === 'on' ? '1.0' : '0.6'} !important;
.bubble-sub-button-3{
background-color: ${hass.states['binary_sensor.rumpus_sliding_door'].state === 'on' ? 'var(--google-violet)' : ''} !important;
opacity: ${hass.states['binary_sensor.rumpus_sliding_door'].state === 'on' ? '1.0' : '0.6'} !important;
.bubble-sub-button-4{
background-color: ${hass.states['cover.lounge_blind'].state === 'open' ? 'var(--google-violet)' : ''} !important;
opacity: ${hass.states['cover.lounge_blind'].state === 'open' ? '1.0' : '0.6'} !important;
sub_button:
- entity: light.lounge_lamp
icon: mdi:floor-lamp
state_background: false
show_background: false
tap_action:
action: toggle
- entity: light.lounge_downlights
show_background: true
tap_action:
action: toggle
- entity: binary_sensor.rumpus_sliding_door
tap_action:
action: more-info
- entity: button.go_to_preset_1
icon: mdi:desk
tap_action:
action: toggle
Wow! Thank you very much!
Where can I get Bubble Card Theme (the same as is used by @Cloos ) ?
I am looking for ideas on how to control the colors of a HUE lamp within a card using the Button Card. How do you implement this?
I am imagining something like this.
knows someone why my bubble card popup always popup automatically when i startup the side, on them the popup is?
type: vertical-stack
cards:
- type: custom:bubble-card
card_type: pop-up
hash: "#Licht"
trigger_entity: light.mqtt_licht_buero
trigger_close: true
trigger_state: "on"
button_type: name
entity: person.penthouse
slide_to_close_distance: "400"
show_header: true
card_layout: large-2-rows
width_desktop: 80%
hide_backdrop: false
close_by_clicking_outside: true
icon: mdi:lightbulb-on
show_icon: true
scrolling_effect: true
show_name: true
sub_button: []
- type: custom:auto-entities
card:
square: false
type: grid
columns: 2
card_param: cards
filter:
include:
- domain: light
options:
type: custom:mushroom-light-card
exclude:
- entity_id: light.lichter
show_empty: true
sort:
method: friendly_name
numeric: false
reverse: false
ignore_case: false
ip: false
@Cloos thank you for a great work on making it easy for us to have beautiful dashboards.
I want to have selector card for my hue lights and be able to select the scene as selectors for that light, however I have not been able to find a way to do that since I use Hue Hub in addition to my HA, so the lights and the scenes are setup in the Hue and are just available in HA.
I have been trying for few days and searched this topic as well as others, but I wonder has anyone been able to use bubble cards with Hue hub in HA.
Thank you all in advance.
Cheers,
Armen
How would I add icon here for motion? Next to the temperature under the title
I have tried so many different ways but cant work it out
Thanks!
It would also be helpful if it cant be done that someone tell me
card_type: button
button_type: state
name: Den Music Room
sub_button:
- entity: light.den_lights_group_z2m
show_last_changed: false
show_attribute: false
show_state: false
tap_action:
action: toggle
- entity: media_player.den_speaker_ma
show_state: false
show_name: false
tap_action:
action: toggle
- entity: vacuum.ragamuffin
tap_action:
action: toggle
double_tap_action:
action: more-info
hold_action:
action: more-info
button_action:
tap_action:
action: navigate
navigation_path: "#den2025"
tap_action:
action: navigate
styles: >
.card-content {
width: 100%;
margin: 0 !important;
.large .bubble-button-card-container {
height: 175px !important;
overflow: hidden !important;
color: #261f06
display: grid;
grid-template-areas:
'n n n b'
'l l l b'
'i i . b'
'i i . b';
grid-template-columns: 1fr 1fr 1fr 1fr;
grid-template-rows: 1.5fr 0.5fr 1fr 1fr;
justify-items: center;
background-color: #dce9f5
grid-area: i;
border-radius: 50% !important;
width: 150% !important;
height: 150% !important;
max-width: none !important;
max-height: none !important;
position: absolute !important;
# left: -33% !important;
# top: -33% !important;
# transform: translate(-50%, -50%) !important;
# margin-top: 25% !important;
# margin-left: -25% !important;
place-self: center !important;
margin: 0px 0px 0px 0px !important;
padding: 0px, 0px, 0px, 0px !important;
background-color: rgba(var(--color-jojoba), 0.75) !important;
.bubble-entity-picture {
background-image: url("/local/icons/den.png") !important;
display: block !important;
background-position: center center;
background-size: 40%;
background-repeat: no-repeat;
.bubble-icon {
width: 40%;
position: relative !important;
--mdc-icon-size: 100px !important;
opacity: 0.5 !important;
.bubble-name-container {
# width: 100%;
grid-area: n;
justify-self: start;
margin-left: 20px;
max-width: calc(100% -(12px + 0px));
.bubble-name {
font-weight: bold;
font-size: 16px;
.bubble-state {
font-weight: bold;
font-size: 14px;
.rows-2 .bubble-sub-button-container {
grid-area: b;
display: flex !important;
flex-wrap: wrap;
flex-direction: column;
justify-content: flex-start;
# width: 40px;
# grid-template-columns: min-content;
# grid-template-rows: repeat(5, 1fr);
width: auto !important;
padding-right: 0px;
height: 100% !important;
margin-top: 25px;
.bubble-sub-button {
min-width: 36px !important;
.bubble-sub-button-1 {
# color: rgba(var(${hass.states['light.den_lights_group_z2m'].state === 'on' ? '--color-yellow' : ''}), 1) !important;
# background-color: rgba(var(${hass.states['light.den_lights_group_z2m'].state === 'on' ? '--color-yellow' : ''}), 0.3) !important;
.bubble-sub-button-2 {
color: rgba(var(${hass.states['media_player.den_speaker_ma'].state != 'playing' ? '' : '--color-green'}), 1) !important;
background-color: rgba(var(${hass.states['media_player.den_speaker_ma'].state != 'playing' ? '' : '--color-green'}), 0.3) !important;
.bubble-sub-button-3 {
color: rgba(var(${hass.states['vacuum.ragamuffin'].state === 'cleaning' ? '--color-purple' : ''}), 1) !important;
background-color: rgba(var(${hass.states['vacuum.ragamuffin'].state === 'cleaning' ? '--color-purple' : ''}), 0.3) !important;
.rows-2 .bubble-sub-button {
height: 36px !important;
${subButtonIcon[0].setAttribute("icon",
'mdi:lightbulb-group' : 'mdi:lightbulb-off')}
${subButtonIcon[1].setAttribute("icon",
hass.states['media_player.den_speaker_ma'].state === 'playing' ? 'mdi:speaker'
: 'mdi:speaker-off')}
${subButtonIcon[2].setAttribute("icon", hass.states['vacuum.ragamuffin'].state
=== 'cleaning' ? 'mdi:robot-vacuum' : 'mdi:robot-vacuum-off')}
layout_options:
grid_columns: 2
grid_rows: 3
entity: sensor.den_current_temperature_helper
show_name: true
show_icon: true
show_state: true
hold_action:
action: navigate
navigation_path: family-room
icon: none
add following styling:
styles: |2-
.bubble-close-button {
background: #922724 !important;
