what could be the cause of this:
There is a much newer (and up to date) version of Kiosk Mode (GitHub - NemesisRE/kiosk-mode: 🙈 Hides the Home Assistant header and/or sidebar). Is there a good way to make it work with that?
You are welcome!
There is no variable available right now, but maybe for the next release!
@Cloos - is it possible to unhide the side/top bar on mobile with the Bubble Card theme? If so, can you tell me how? I like the theme, but not sure about the hidden side and top bar just yet.
I am unable to find these cards in HACS. When I try custom repository I am told it is already in the store.
Searching the store comes up with nothing. Any advise?
Is anyone running into an issue where the dashboard keeps refreshing itself at random intervals? Trying to determine if there is a setting for the cards that prompts this. I built a new dashboard for use on my mounted ipad, but multiple times a day it seems as if my HA app crashes due to the dashboard refreshing.
My other dashboard doesn’t result in the same issue, so I am at a loss for trying to determine what is causing it on my Bubbles dashboard. I do have it set up to auto-close pop-ups after 15 seconds, but I am not using the dynamic horizontal bar at the bottom (changing order based on motion detected).
Any ideas? Thank you in advance!
Had the same issue and uninstalled the beautiful cards again ![]()
That is what I was considering. I like the look of this, but I guess I’ll just circle back and see what it looks like in a few months.
Thank you
@sebbaT
I would be interested in all of the code to recreate your example if you still had it…
Sure! Here’s the Menu Bubble-Card along with the two popup cards.
Bubble Card ‘Menu’ Footer
type: custom:bubble-card
card_type: horizontal-buttons-stack
1_name: testpop
1_icon: mdi:account
1_link: '#testpop'
1_entity: light.upstairs_bathroom
rise_animation: false
Main Popup Card
type: vertical-stack
cards:
- type: custom:bubble-card
card_type: pop-up
hash: '#testpop'
icon: mdi:cog
margin_top_desktop: 50%
margin_top_mobile: 50%
is_sidebar_hidden: true
width_desktop: 50%
styles: |
#root {
opacity: 1;
auto_close: '5000'
margin: 0px
back_open: false
- type: custom:mushroom-media-player-card
entity: media_player.toms_bedroom
use_media_info: false
show_volume_level: false
media_controls:
- play_pause_stop
- next
- previous
collapsible_controls: false
fill_container: true
layout: horizontal
volume_controls:
- volume_set
- show_name: true
show_icon: false
type: button
tap_action:
action: call-service
service: browser_mod.javascript
device_id:
- THIS
code: history.pushState(null, null, "#testpop2");
entity: light.8bc0abaa_120febac_screen
show_state: false
Secondary ‘more’ Popup Card (with back button)
cards:
card_type: pop-up
hash: '#testpop2'
width_desktop: 50%
styles: |
#root {
opacity: 1;
card_mod:
style: |
ha-card {
display: none !important;
margin: 0px
back_open: false
- type: custom:mushroom-chips-card
chips:
- type: back
icon: mdi:arrow-left
card_mod:
style: |
ha-card {
padding: -20px !important;
ha-card > div {
justify-content: flex-end !important;
entity: media_player.kitchen
media_controls:
- play_pause_stop
- next
- previous
layout: horizontal
volume_controls:
- volume_set
Hi! I’m aware of this issue and I can confirm that it will be fixed in 1.6.0 ![]()
Seeing an issue when mixed with layout card. I use layout card for my tablets and try to have a fixed size. Each vertical stack card is showing on the bottom of my dashboard making it scrollable. Thoughts?
Will the next version fix the tap_action issue? If not, I may have to switch to another card unfortunately.
Yes, it will be, and it’s already fixed on my side.
I apologize for not responding to all of you, but I’m currently in a significant battle against bugs (and I’m winning!). Here are some issues that have already been fixed in the upcoming v1.6.0:
- Fixed the issue of empty columns in the dashboard caused by hidden pop-ups.
- All tap actions on iOS are now functioning correctly.
- Fixed the icon glitch that occurred when a slider was moving on Safari and iOS.
- Fixed the entity picture when set as an icon. E.g.,
icon: /local/image.jpg. - Fixed the entity picture (album cover) of a media player. If an icon is defined, it will now switch automatically.
- Increased the line opacity in the separator for better visibility.
- Fixed the ‘Reload UI’ issue.
- Fixed all errors with some cards when the pop-ups were closed.
- Cameras inside pop-ups now load faster.
- Made some minor style adjustments.
- Fixed the issue where pop-ups would disappear when the connection was lost or on a mobile device coming out of sleep mode (and probably in all cases).
- Improved pop-ups in regular mode.
- Fixed the pop-ups still showing when the editor was closed.
- Adding
bubble-pop-up.jsto theconfiguration.yamlshould not trigger thecustom element doesnt exist: bubble-pop-uperror anymore
- I’ve refactored the entire code, and it’s much smoother on low-end devices (and it will be a lot easier to maintain!)
And more to come really soon in beta (just to be sure).
@sebbaT
Got this all in my test dashboard… but looks like you are also using a custom JS script?
I see this mentioned, which throws an error since I do not have it.
Could you post this also please?
NM, I found it in hacs, couldn’t find it in the frontend… it was in the integrations area
UPDATE: Holy cow, browser-mod is a world of its own. I like the double popup, but unsure what I have exactly enabled by enabling this new integration (browser-mod). Appreciate the code!
Got to say this card has literally made me use the HA companion app again!
I now have a mobile dashboard with one page using the pop-ups for navigating my smart home for my use case. Amazing stuff and great work @Cloos ![]()
This is cool - do you mind posting your YAML?
The war against bugs and instability continues
v1.6.0-beta.1 :
Hello! I’m excited to announce that the v1.6.0 update of Bubble Card is finally here! This update is all about making Bubble Card work the way it should. I’ve worked really hard to fix almost all known bugs that were affecting Bubble Card’s performance, usability and stability.
In this update, I also made a major change. The entire code has been refactored, which makes Bubble Card run smoother on low-end devices and easier for me (and everyone) to maintain!
Can’t wait to hear what you think! And remember, a bug-free software is like a unicorn, some say it doesn’t exist, but with this update, we’re one step closer to finding it!
And here is the biggest Bubble Card changelog of all times:
Bug fixes
- Corrected the entity picture when set as an icon. E.g.,
- Resolved the ‘Reload UI’ issue.
- Made some minor style adjustments for smaller devices.
- Fixed the issue where pop-ups would disappear when the connection was lost or on a mobile device coming out of sleep mode.
- Fixed the pop-ups not opening in some cases.
- Fixed the pop-ups background color for some custom themes.
- Fixed the pop-ups background color that was not changing when switching themes.
- Fixed when scrolling inside a pop-up and that the content behind it was scrolling too.
- Fixed the top gradient for pop-ups without an entity.
- Refactored the entire code, and it’s much smoother on low-end devices.
New features
- Haptic feedback has been added for the HA companion app users (the slider button is the coolest one).
- Added an option to highlight the current hash / view in the horizontal buttons stack with a soft animation.
- You now have the ability to show or hide the state of covers (default is
show_state: false).
Thank you all once again for your continued support! ![]()
Haven’t seen it hit yet (the latest release)…
Curious what would make the bubble cards to be off centered?
Started playing around with some card setups… everything is shifted to the right too much.
UPDATE: NM, I missed the “Beta” part.
Found it, downloaded it and now everything is centered correctly.
This is in beta, you need to toggle this feature in the Bubble Card page in HACS to get it.
And your issue should be already fixed in this version ![]()
