I’ve noticed this happening a lot since the update…
I have to refresh the edit page for the content to populate…
Glad you got it up and running!
Browser_mod is really powerful and useful for a huge amount of things in HA. Worth looking into.
It isn’t actually needed for this and you can simply use navigate in your tap action:
type: vertical-stack
cards:
- type: custom:bubble-card
card_type: pop-up
hash: '#testpop'
icon: mdi:cog
margin_top_desktop: 50%
margin_top_mobile: 50%
is_sidebar_hidden: true
width_desktop: 50%
styles: |
#root {
opacity: 1;
auto_close: '5000'
margin: 0px
back_open: false
- type: custom:mushroom-media-player-card
entity: media_player.toms_bedroom
use_media_info: false
show_volume_level: false
media_controls:
- play_pause_stop
- next
- previous
collapsible_controls: false
fill_container: true
layout: horizontal
volume_controls:
- volume_set
- show_name: true
show_icon: false
type: button
tap_action:
action: navigate
navigation_path: '#testpop2'
entity: light.8bc0abaa_120febac_screen
show_state: false
I did it this way:
Here you go mate. I added a “tag” starting with ‘ENTER_YOU_XXX’ where i could.
Repo:
Cloos Theme:
Get all the components listed in Cloos very detailed and easy to read guide(best I have seen so far by a contributing dev)
Bubble Card:
Again follow the guide and this forum post
Media card:
Sonarr:
Plex:
Enjoy!
Sweet! Thank you!
What are you using for the PS5 integration?
THis is what i use:
super easy to setup and works really well
ah brilliant. that’s what i’m using ![]()
Are you trying to make the background color dynamically change?
oh yes, that’s it, based on the track
@chintito4ever
Salut, j’utilise bubble-card cela fonctionne parfaitement sur pc mais sur mobile j’ai une erreur et je ne vois pas comment corriger cela. Si tu avais une piste à me donné.
En gros j’ai l’ensemble de mes cartes qui apparaît avec comme erreur “Custom element doesn’t exist: bubble-pop-up” cela me le fait avec le pop-up régulier ou optimisé.
Hi! Here is a new update that should fix all the new issues introduced in v1.6.0-beta.1. This new version was a huge challenge for me, as it involved a complete overhaul of the entire code structure. However, I sincerely hope that everything is working flawlessly now!
And given the uncertainty of getting another version out before the holidays, I’d like to take this opportunity to say Merry Christmas and Happy New Year to all of you! ![]()
Bug fixes
There is now a small issue with this fix from v1.6.0-beta.1 (but it works after a refresh):
Take a look here:
Hi @Cloos, congratulations on these cards! Do you know how to solve the problem described above?
Hi, I guess that it’s not possible (or pretty difficult to do) because that color is not just a color, it’s a gradient or a blurred image.
But I already did it for the background under the cover, but I can’t get it to work in the popup
Is there any way to have the popup button bar always be in front of the cards? When i open the first popup button it’s in front, but whenever i open any other card the bar is behind the card.
Hi! Just put your horizontal buttons stack at the last position of your dashboard to fix that ![]()
So I tried this so well understood:
But this was causing more trouble, because before I’d only had problems with the mobile version, but now it was doing it on the PC too. So I opted for the version with the added javascript resources, despite the advice you gave below, but there were no more problems. And I don’t think I have a big configuration because I don’t feel any slowdown.
Otherwise to be sure it is rather advised in the frontend to specify the version at the end of the url or not?
Otherwise thank you for this beautiful card.
Chakalis49 ![]()
Edit: I’m on a raspberry pi 4 2Go
Core: 2023.12.3
Supervisor: 2023.12.0
Operating System: 11.2
User Interface: 20231208.2
Alors j’ai essayer cela si bien compris:
Mais cela causais plus de soucis car avant j’avais des soucis que sur la version mobile mais là cela le faisait aussi sur pc. J’ai donc opté pour la version de l’ajouté en ressources javascript malgré que tu déconseillais un peu plus bas, mais là plus aucun soucis. Et je ne pense pas avoir une grosse configuration car je ressens aucun ralentissement.
Sinon pour être sur il est plutôt conseillé dans le frontend de précisé la version à la fin de l’url ou non ?
Sinon merci pour cette magnifique carte.
Chakalis49 ![]()
Edit: Je suis sur un raspberry pi 4 2Go
