Maybe I’m just blind, but I can’t seem find it. Could you write down the name it’s under?
After going over the whole GitHub page for the 8th time, I finally found it. Thanks for the help anyway.
Oh sorry! I meant to write Styling > Examples section.
Few quick questions… is there a way to limit scrolling and either wrap onto the next line and/or decrease the font size? Is there a way to shrink the whole size of the button and make it scale to the contents? I am trying to make a “chip” style header row, but I need to ability to use icons and text. Similar to mushroom chips (which is what I am currenlty using, but I would like to use bubble card so the style is more similar. Thanks
Hello, Can you please guide on how can we control (increase\decrease) the space between the sub-buttons?
I am kindly asking for suggestions.
How do I scale down an image, I used instead of an icon?
I have used following styling to put it in place
styles: |-
.bubble-button-2 {
background-image: url("/local/icons/custom_icons/robot-2.png");
background-size: cover;
I’ve had a strange situation since today. I have two cover buttons where the background color of the bubble button indicates the status. However, now the background color of one of the buttons is no longer changing. See the image and the code for the two cover buttons.
- type: custom:bubble-card
card_type: cover
entity: cover.rfy_010505_1
show_icon: false
icon_down: mdi:window-shutter
icon_up: mdi:window-shutter-open
modules:
- default
card_mod:
style: |
.bubble-button.bubble-open {
{% if states('cover.rfy_010505_1') == 'open' %}
background-color: rgb(103, 114,209,1) !important;
{% else %}
opacity: 1 !important;
{% endif %}
.bubble-button.bubble-close {
{% if states('cover.rfy_010505_1') == 'closed' %}
{% else %}
{% endif %}
card_type: cover
entity: cover.rfy_010509_1
show_icon: false
modules:
- default
card_mod:
styles: |
{% if states('cover.rfy_010509_1') == 'open' %}
{% else %}
{% endif %}
{% if states('cover.rfy_010509_1') == 'closed' %}
{% else %}
{% endif %}
Your 1st card is style and the 2nd is styles. I think styles is correct spelling.
Oh, thanks. style is the correct one. Problem solved. Overlooked that.
Hi andy do you mind sharing what you did? I am in the same pickle as you are ><
Hello guys,
Maybe someone know better if I can do this.
- it’s default select select card with an input select from different rooms.
- it’s a sub button editor to let me know which room it’s there.
top - select card
middle - separator with sub button
down - button text card with sub button
I want to use select card because everywhere I tap the button it’ll popup the dropdown to select what I want.
- Can I make the default select card with input select entity to show as others I already showed in screenshots ?
- If not, it’s there any action I can use on tap action on card to open the input select from the right? Right now I need to exactly click there.
It would be nice if I could maximize the blue round to the all card, so basically a full card with only 1 dropdown.
is there a way to chose the attributes used to populate the drop list menu of the Select type?
I have an entity that the attribute with the list of available choices is called “options” but it seems that bubble card select doesn’t use it. So clicking on the down arrow does nothing
I am trying to change the background colour of a sub-button icon container. Would ideally like to be able to set it by state object just struggling to theme this part.
card_type: button
card_layout: large
button_type: name
show_icon: false
show_name: false
sub_button:
- name: Mop Mode
icon: mdi:water-opacity
show_background: true
show_arrow: false
tap_action:
action: select
navigation_path: input_select.select_option
entity: select.roborock_qrevo_mop_intensity
- name: Mop Mode
icon: mdi:water
show_arrow: false
tap_action:
action: select
service: input_select.select_option
entity: select.roborock_qrevo_mop_mode
- name: DND Begin
icon: mdi:bell-cancel
entity: time.roborock_qrevo_do_not_disturb_begin
tap_action:
action: toggle
- name: DND Finish
icon: mdi:bell-ring
entity: time.roborock_qrevo_do_not_disturb_end
- name: DND Switch
show_icon: true
entity: switch.roborock_qrevo_do_not_disturb
tap_action:
action: toggle
card_mod:
style: |
ha-card {
margin-top: 5px;
margin-left: -10px;
width: 440px;
#padding-bottom: 20px;
#color: white;
styles: |
.card-content {
width: 100%;
#margin: 0 !important;
.bubble-button-background {
background-color: rgba(0, 128, 128, 0.4) !important; border-radius: 5px !important;
.bubble-button-card-container {
.bubble-sub-button {
height: 36px !important;
width: 26px !important;
.bubble-sub-button-container {
display: flex !important;
width: 100%;
justify-content: space-between !important;
.bubble-sub-button-icon {
--mdc-icon-size: inherit !important;
.bubble-name-container {
margin-right: 0px !important;
.bubble-sub-button-1 > ha-icon {
.bubble-sub-button-2 > ha-icon {
.bubble-sub-button-3 > ha-icon {
.bubble-sub-button-4 > ha-icon {
.bubble-sub-button-5 > ha-icon {
Here it is after a little experimentation and code… I don’t know what it’s for :), but it might help!!!
card_type: button
button_type: name
icon: mdi:liquor
scrolling_effect: false
sub_button:
- entity: sensor.terasa_termometar_temperature
show_state: true
modules: []
card_mod:
style: |
.bubble-icon-container {
overflow: visible;
.bubble-icon::after {
content: "Test";
position: absolute;
top: -15%;
right: -55%;
display: flex;
justify-content: center;
align-items: center;
font-size: 10px;
font-weight: 400;
color: white;
width: 30px;
height: 18px;
background: rgb(76, 175, 80);
border-radius: 25%;
.bubble-sub-button-1:after {
content: "{{states ('sensor.terasa_termometar_humidity')}}%";
position: absolute;
top: -15%;
right: -5%;
display: flex;
font-size: 10px;
font-weight: 400;
color: white;
width: 40px;
height: 18px;
border: 0px solid transparent;
border-color: rgb(76, 175, 80);
border-radius: 25%;
} !important;
More variations in the same style
card_type: button
card_layout: large
button_type: name
show_icon: false
show_name: false
sub_button:
- show_icon: true
state_background: true
show_background: false
tap_action:
action: navigate
navigation_path: "#brano"
styles: |
.card-content {
width: 100%;
margin: 0 10 0 10 !important;
background: none;
border: none;
height: 42px !important;
width: 42px !important;
width: 100%;
justify-content: center !important;
.bubble-sub-button-1 {
background-image: url(${hass.states['person.branislav'].attributes.entity_picture});
background-size: contain!important;
border-radius: 50px !important;
content: "";
position: absolute;
top: -2px;
left: -2px;
width: calc(80% + 4px);
height: calc(80% + 4px);
border: 4px solid transparent;
border-radius: 50%;
border-color: ${
hass.states['person.branislav'].state === 'home'
? "#008000" // Green
: "#FF0000" // Red
} !important;
I’m currently trying to setup my dashboard for mobile phones using this awesome Bubble Cards, but I’m struggling with some styling and dimensioning issues.
The setup I’m testing right now uses the module Room Card Module
The dimensions and proportions of the test-card I have designed are looking correct on my laptop dashboard, even if the big icon and the circle around is a bit too large for my understanding.
If I open this dashboard in the HA app on my iPhone the dimensions are messed up and the sub buttons are touching the edge of the button.
What is the right way to move the sub buttons slightly to the left that they do no longer interfere with the edge of the card itself? And how can I shrink the icon and the circle around the icon that it does not take that much space?
I know that there is possibility to modify the Code (CSS/JS template) of the Room Card Module, but can anybody tell me what variables and values need to be modified to achieve what im looking for?
thanks
Try it!
.large .bubble-sub-button-container {
position: absolute;
right: 20px; /* fiksna udaljenost od desne ivice */
top: calc((100% - 4 * 36px)/5); /* vertikalni razmak */
flex-direction: column;
gap: calc((100% - 4 * 36px)/5) !important;
justify-content: flex-start;
height: 100% !important;
padding-right: 0 !important;
An example of my custom Room card, maybe it will help someone
card_type: button
show_attribute: false
show_name: true
show_icon: true
scrolling_effect: true
show_state: false
card_layout: large-2-rows
tap_action:
action: none
button_type: name
icon: mdi:sofa
sub_button:
- name: Rasveta boravak
icon: mdi:lightbulb-group
tap_action:
action: navigate
navigation_path: "#rasveta_boravak"
entity: light.rasveta_boravak
- name: Media
icon: mdi:television-off
tap_action:
action: navigate
navigation_path: "#media_boravak"
entity: remote.android_tv
- name: Media
tap_action:
action: navigate
navigation_path: "#klima_boravak"
entity: climate.boravak_ac
styles: >-
overflow: visible;
.bubble-icon {
color: teal!important;
opacity: .5 !important;
background: var(--icon-Background-Color); !important;
position: absolute;
right: 10px; /* fiksna udaljenost od desne ivice */
.large .bubble-sub-button {
width: 36px !important;
border-radius: 10px !important;
--mdc-icon-size: 24px !important;
${subButtonIcon[1].setAttribute("icon", hass.states['remote.android_tv'].state
=== 'on' ? 'mdi:television' : 'mdi:television-off')}
${subButtonIcon[2].setAttribute("icon",
hass.states['climate.boravak_ac'].state === 'heat'
? 'mdi:fire'
: hass.states['climate.boravak_ac'].state === 'heat_cool'
? 'mdi:sun-snowflake'
: hass.states['climate.boravak_ac'].state === 'cool'
? 'mdi:snowflake'
: hass.states['climate.boravak_ac'].state === 'dry'
? 'mdi:water-percent'
: hass.states['climate.boravak_ac'].state === 'fan_only'
? 'mdi:fan'
: 'mdi:air-conditioner')}
card_mod:
style: |
content: "{{states ('sensor.boravak_termometar_temperature')}}°C/{{states ('sensor.boravak_termometar_humidity')}}%";
position: absolute;
top: -30px;
left: 30px;
color: var(--primary-text-color);
font-size: 12px;
{% if states('sensor.broj_osvetljenja_boravak') | int > 0 %}
content: "{{ states('sensor.broj_osvetljenja_boravak') }}";
position: absolute;
top: -5px;
left: 22px;
width: 18px !important;
height: 15px !important;
display: flex;
color: black;
background-color: orange;
border-radius: 20%;
font-size: 10px;
{% endif %}
{% if states('climate.boravak_ac') !='off' %}
.bubble-sub-button-3:after {
content: "{{ state_attr('climate.boravak_ac', 'temperature') }}";
position: absolute;
top: -5px;
left: 22px;
display: flex;
color: black;
background-color: var(--primary-color);
border-radius: 20%;
font-size: 10px;
{% endif %}
grid_options:
columns: 6
rows: 3
modules:
- room_card
Here’s the title, I like it, but it doesn’t discuss tastes…Maybe it will help someone
type: custom:vertical-stack-in-card
cards:
card_type: separator
sub_button:
- entity: sensor.time
show_name: false
show_icon: false
show_state: true
state_background: false
- tap_action:
action: perform-action
perform_action: input_boolean.toggle
entity_id: input_boolean.notifications
icon: ""
entity: sensor.alarm_stan
visibility:
- condition: state
state: Alarm
styles: >-
.card-content {
width: 100%;
} .bubble-button-card-container {
background: none;
border: none;
} .bubble-name:before { color: red; content: attr(data-before);
padding-right: 0.5em } .bubble-line { background-color: #ccae99; }
.bubble-sub-button-1 { font-weight: bold !important; font-size: 1.2em
!important; }
.bubble-sub-button-2 {
color: ${
hass.states['input_boolean.notifications'].state ==='on'
? "red"
: ""// Red
} !important;
height: 26px !important;
${card.querySelector('.bubble-name').setAttribute('data-before', new
Date().toLocaleDateString('sr-Latn-SR', {weekday:
'long'}).toUpperCase())}; ${card.querySelector('.bubble-name').innerText =
new Date().toLocaleDateString('sr-Latn-SR', {day: 'numeric', month:
'long'}).toUpperCase()};
rows: "0.8"
modules:
- home-assistant-default
- type: conditional
conditions:
- entity: input_boolean.notifications
state: "on"
card:
card_type: button
modules:
sub_button:
- entity: sensor.voda_stan
tap_action:
action: navigate
navigation_path: "#voda"
visibility:
- condition: state
state_not: "0"
- entity: sensor.otvorena_vrata_stan
show_state: true
tap_action:
action: navigate
navigation_path: "#vrata"
visibility:
- condition: state
state_not: "0"
- entity: sensor.baterija_broj_uredjaj_sa_niskim_nivoom
show_state: true
show_icon: true
tap_action:
action: navigate
navigation_path: "#baterija"
visibility:
- condition: state
state_not: "0"
- entity: binary_sensor.ulaz_posta_occupancy
show_state: false
icon: mdi:email-newsletter
tap_action:
action: navigate
navigation_path: null
visibility:
- condition: state
state: "on"
- entity: sensor.broj_osvetljenja_stan
show_state: true
tap_action:
action: navigate
navigation_path: "#rasveta"
visibility:
- condition: state
state_not: "0"
- entity: alarm_control_panel.home_alarm
show_state: false
tap_action:
action: navigate
navigation_path: "#alarm"
button_type: name
icon: ""
use_accent_color: false
styles: |-
.card-content {
width: 100%;
background: none;
border: none;
width: 100%;
justify-content: right !important;
width: 46px !important;
animation: ${hass.states['sensor.voda_stan'].state>0? 'fade-animate 3s ease-in-out infinite' : '' };
color: ${
hass.states['sensor.voda_stan'].state > 0
? "red"
: "white"
} !important;
@keyframes fade-animate {
0%, 100% {
opacity: 1;
50% {
opacity: 0;
animation: ${hass.states['sensor.otvorena_vrata_stan'].state>0? 'fade-animate 3s ease-in-out infinite' : '' };
color: ${
hass.states['sensor.otvorena_vrata_stan'].state > 0
? "red"
: "white"
} !important;
0%, 100% {
opacity: 1;
50% {
opacity: 0;
.bubble-sub-button-3 {
color: ${
hass.states['sensor.baterija_broj_uredjaj_sa_niskim_nivoom'].state > 0
? "red"
: "white"
} !important;
.bubble-sub-button-5 {
color: ${
hass.states['sensor.broj_osvetljenja_stan'].state >0
? "orange"
: "none" // Red
} !important;
.bubble-sub-button-6 {
animation: ${hass.states['alarm_control_panel.home_alarm'].state == 'arming' ? 'fade-animate 3s ease-in-out infinite' : '' };
color: ${
hass.states['alarm_control_panel.home_alarm'].state == 'disarmed'
? "blue"
: hass.states['alarm_control_panel.home_alarm'].state == 'armed_home'
? "green"
: hass.states['alarm_control_panel.home_alarm'].state == 'armed_away'
? "teal"
: hass.states['alarm_control_panel.home_alarm'].state == 'arming'
? "orange"
: "#FF0000" // Red
} !important;
0%, 100% {
opacity: 1;
50% {
opacity: 0;
${subButtonIcon[5].setAttribute("icon",
? 'mdi:shield-off'
? 'mdi:shield-home'
? 'mdi:shield-lock'
? 'mdi:shield'
: "#FF0000" // Red
show_icon: false
show_name: false
rows: "0.8"
alignment: justify
card_mod:
style: |
ha-card{
background: transparent;
border:none;
Here is a copy of the Alarm card
card_type: button
button_type: switch
show_attribute: true
show_state: true
force_icon: false
show_icon: true
show_name: true
sub_button:
- entity: script.alarm_aktivan_van_kuce
icon: mdi:shield-lock
tap_action:
action: toggle
double_tap_action:
action: none
visibility:
- condition: state
state_not: armed_away
- icon: mdi:shield-home
tap_action:
action: toggle
double_tap_action:
action: none
visibility:
- condition: state
state_not: armed_home
entity: script.alarm_aktivan_u_kuci
- icon: mdi:shield-off
tap_action:
action: toggle
visibility:
- condition: state
state_not: disarmed
entity: script.alarm_neaktivan
tap_action:
action: none
double_tap_action:
action: none
hold_action:
action: none
modules:
- subbutton_colors
subbutton_colors:
subbutton1:
color: teal
condition:
- condition: state
state: armed_away
entity_id: alarm_control_panel.home_alarm
subbutton2:
color: green
condition:
- condition: state
state: armed_home
subbutton3:
color: indigo
condition:
- condition: state
state: disarmed
card_layout: large-sub-buttons-grid
button_action:
tap_action:
action: none
hold_action:
action: none
styles: |-
animation: ${state === 'arming' ? 'fade-animate 3s ease-in-out infinite' : '' };
background: ${
state == 'disarmed'
? "blue"
: state == 'armed_home'
? "green"
: state == 'armed_away'
? "teal"
: state == 'arming'
? "orange"
: "#FF0000" // Red
} !important;
border-radius: 25%!important;
color: white!important;
0%, 100% {
opacity: 1;
50% {
opacity: 0;
${card.querySelector('.bubble-state').innerText =
state == 'armed_home' ? "Alarm aktiviran (Kod kuće)"
: state == 'armed_away' ? "Alarm aktiviran (Odsutan)"
: state == 'disarmed' ? "Alarm deaktiviran"
: "Aktiviranje alarma"
${state == 'armed_home' ? icon.setAttribute("icon", 'mdi:shield-home')
: state == 'armed_away' ? icon.setAttribute("icon", 'mdi:shield-lock')
: state == 'disarmed' ? icon.setAttribute("icon", 'mdi:shield-off')
:icon.setAttribute("icon", 'mdi:shield')};
thank you… I played around a bit and ended up with this
.large .bubble-icon-container {
margin: 5px;
z-index: 1;
min-width: ${this.config.room_card?.square_icon ? '110px' : '120px'};
max-width: ${this.config.room_card?.square_icon ? '110px' : '120px'};
min-height: ${this.config.room_card?.square_icon ? '110px' : '120px'};
max-height: ${this.config.room_card?.square_icon ? '110px' : '120px'};
border-radius: ${this.config.room_card?.square_icon ? '0px' : '80px'};
border-top-right-radius: ${this.config.room_card?.square_icon ? '12px' : '80px'};
transform: ${this.config.room_card?.square_icon ? 'translate(0px,37px)' : 'translate(-16px,50px)'};
