⚪ Bubble Card - A minimalist card collection for Home Assistant with a nice pop-up touch
Any reason this separator not working for me?
Rounded theme
Try custom instead of customs ?
:man_facepalming: thanks, it was it
I test removing the horizontal-stack and create it again but issue still here.
I test on mobile only.
On all cards if i have a horizontal-stack button if not it is ok.
Would be nice if a subbutton color could change based on the value.
Like you could with mini graph card
example:
    color_thresholds:
      - value: 100
        color: '#a3ff00'
      - value: 500
        color: '#e3ff00'
      - value: 1000
        color: '#ffa300'
      - value: 1500
        color: '#ff4d00'
      - value: 2000
        color: '#ff0000'
Hi! I’ve just released a new Bubble Card 2 beta that should fix all the latest issues. Well… fingers crossed again! :crossed_fingers:
Bubble Card 2 - The True Final Beta?
Version 2.0.0-beta.6
:bulb: New features
  • Added the possibility to change the icon in a custom style template, you can now do this: ${state === 'on' ? icon.setAttribute("icon", "mdi:lightbulb") : icon.setAttribute("icon", "mdi:lightbulb-off")};
:heavy_check_mark: Bug fixes and optimizations
  • Fixed an issue with the custom icons of the cover buttons
  • Fixed an issue on the button slider when the entity is an input_number
  • Changed last_updated to last_changed for the states
  • Removed scrolling effect in the sub-buttons editor (it was unused)
  • Fixed some color issues in the editor
  • Fixed the horizontal button stack errors
  • Fixed the pop-up default color on some themes
  • Changed pop-up z-index to 5
Thanks for the great card!!
Just one question - font family cannot be adjusted via “font-family: font-type;” or is there a different way to consider this in the styling options ?
Many thanks @Cloos
Loving all the updates! Just updated to beta 6 now and looking smooth…
So Cloos… can we get the code for your set up yet? Keen to see how you’ve gone about it.
Also eager to see his setup, hopefully also a tablet setup with bubbles :slight_smile:
I have a strange thing when I save a code.
2 buttons horizontal with a call service.
The 2nd button call service is working.
When I want to save this code to the first button I automatically sets the target: {}
Example 2 identical buttons:
type: horizontal-stack
cards:
  - type: custom:bubble-card
    card_type: button
    show_state: true
    show_last_updated: false
    tap_action:
      action: none
    hold_action:
      action: call-service
      service: lock.unlock
        entity_id: lock.danalock
    entity: lock.danalock
    button_type: switch
    icon: mdi:shield-lock
    card_type: button
    show_state: true
    tap_action:
      action: none
    hold_action:
      service: lock.lock
    button_type: switch
But after saving it changes only the first button target
target: {}
This way the call service is not working, the second button works and is not changed.
cards:
    card_type: button
    show_state: true
    tap_action:
      action: none
    hold_action:
      target: {}
    button_type: switch
    card_type: button
    show_state: true
    tap_action:
      action: none
    hold_action:
      service: lock.lock
    button_type: switch
Nothing to do with latest beta, already in there previous verions
Thanks for the feedback, I will check that!
I will… one day… I’m working so much on Bubble Card that I haven’t worked on my dashboard since the first release of the project, I’ve just added two sub-buttons in a pop-up… That’s not really impressive :eyes:
But I’m working on a new and clearer documentation, and I’m planning to add more advanced examples.
Have you tried adding !important; at the end of your CSS declaration?
Like this:
  font-family: Arial, Helvetica, sans-serif !important;
Brilliant. I’ll wait…
In the latest beta release (2.0b6), or a recent one anyway, something must have changed with how colors render on lights. This has led to the buttons becoming completely unreadable with bright white text on a very light orange backdrop.
Nothing to do with the theme, it happens with the default theme also. I don’t have any custom CSS or styling and again am using the default theme here.
Can this be fixed?
Screenshot 2024-04-29 184216
Thank you for pointing me this, indeed I’ve changed something. I will fix that.
I have a setup with grid-layout, however, I need to define for each bubble popup a grid position (otherwise the popup won’t show up in the defined layout). Unfortunately, the (invisible) popups take up space in my layout with this setup, even if I put the popup cards in the first position of my dashboard.
Is there a chance you could fix this also for grid layouts?
Take a look at this, this looks like the solution to your issue:
Hello, thanks for last beta.
I Still have my issue when editing on mobile once there is the button horizontal-stack.
Regarding the diez of the screen too wide
Nb my code.
  - title: Home
    cards:
      - type: vertical-stack
        cards:
            card_type: pop-up
            button_type: slider
            entity: light.salon_lumieres
            hash: '#salon'
            show_state: true
            show_attribute: false
            force_icon: false
            card_type: button
            button_type: state
            entity: person.olivier
            card_type: media-player
            entity: media_player.piece_a_vivre
            card_type: button
            button_type: state
            entity: sensor.porte_podposition
            sub_button:
              - icon: ''
                entity: button.porte
            styles: >-
              ha-card > div > div > div.bubble-button-card.switch-button >
              div.bubble-icon-container.icon-container::after {
              #ha-icon {
                  color: {% if is_state('sensor.porte_podposition','LOCK') %} green !important {% endif %} {% if is_state('sensor.porte_podposition','CLOSE') %} white !important {% endif %} {% if is_state('sensor.porte_podposition','OPEN') %} red !important {% endif %};
            attribute: templates
          - type: horizontal-stack
            cards:
                primary: 'Porte entrée '
                secondary: |
                  Verrouillée
                  {% endif %}
                  Fermée
                  {% endif %}
                  Ouverte
                  {% endif %}
                icon: |
                  kuf:fts_door_locked
                  {% endif %}
                  kuf:fts_door
                  {% endif %}
                  kuf:fts_door_open
                  {% endif %}
                tap_action:
                  action: more-info
                badge_icon: |
                  mdi:lock
                  {% endif %}
                  mdi:lock-off
                  {% endif %}
                  mdi:lock
                  {% endif %}
                icon_color: |-
                  green
                  {% endif %}
                  white
                  {% endif %}
                  red
                  {% endif %}
                badge_color: |
                  green
                  {% endif %}
                  green
                  {% endif %}
                  red
                  {% endif %}
                fill_container: true
                hold_action:
                  action: more-info
                double_tap_action:
                  service: button.press
                    entity_id: button.porte
        cards:
            card_type: pop-up
            button_type: state
            hash: '#meteo'
            show_state: true
            force_icon: false
            entity: weather.pontoise
            show_icon: false
          - type: custom:meteofrance-weather-card
            cloudCoverEntity: sensor.pontoise_cloud_cover
            rainChanceEntity: sensor.pontoise_rain_chance
            freezeChanceEntity: sensor.pontoise_freeze_chance
            snowChanceEntity: sensor.pontoise_snow_chance
            uvEntity: sensor.pontoise_uv
            rainForecastEntity: sensor.pontoise_next_rain
            alertEntity: sensor.95_weather_alert
            number_of_forecasts: '5'
            current: true
            details: false
            one_hour_forecast: true
            alert_forecast: true
            forecast: true
          - type: custom:hourly-weather
            show_wind: speed
            num_segments: '24'
            label_spacing: '4'
            show_date: 'false'
            show_precipitation_amounts: false
            icons: true
            show_precipitation_probability: false
          - type: custom:weather-chart-card
            show_main: false
            show_temperature: true
            show_current_condition: true
            show_attributes: true
            show_time: false
            show_time_seconds: false
            show_day: false
            show_date: false
            show_humidity: true
            show_pressure: true
            show_wind_direction: true
            show_wind_speed: true
            show_sun: true
            show_feels_like: false
            show_dew_point: false
            show_wind_gust_speed: false
            show_visibility: false
            show_last_changed: false
            use_12hour_format: false
            icons_size: 25
            animated_icons: true
            icon_style: style2
            forecast:
              precipitation_type: rainfall
              show_probability: false
              labels_font_size: '11'
              precip_bar_size: '100'
              style: style2
              show_wind_forecast: true
              condition_icons: true
              round_temp: false
              type: daily
              number_of_forecasts: '0'
              disable_animation: false
            units:
              pressure: ''
              speed: ''
          - type: custom:weather-radar-card
            show_zoom: true
            square_map: false
            show_recenter: false
            show_scale: true
            show_range: false
            extra_labels: false
            static_map: false
            show_marker: true
            zoom_level: 10
            map_style: Voyager
        card_type: horizontal-buttons-stack
        1_link: '#salon'
        1_icon: mdi:sofa
        2_link: '#meteo'
        2_icon: mdi:weather-partly-cloudy
Is there currently anyway to make a button without a state indicator?
Currently buttons change to another color when pressed, but I don’t want that to be the case for something like a wake on lan button, where it isnt on, but rather just a single event.
