⚪ Bubble Card - A minimalist card collection for Home Assistant with a nice pop-up touch
This is intended, the best way to create a pop-up is to create a vertical stack first then to add the pop-up card inside of it (your way to do it works too), but in @alexandrechoske’s code you can see that it is already in a vertical stack and that’s why I’m clueless for now.
take my code and try to insert it into your HA to see what happens…
type: vertical-stack
cards:
  - type: custom:bubble-card
    card_type: pop-up
    icon: mdi:television
    entity: group.sala_geral
    state: sensor.temperatura_e_humidade_sala
    state_unit: °C
    width_desktop: 600px
    margin_top_mobile: 18px
    margin_top_desktop: 74px
    is_sidebar_hidden: false
    hash: '#psala'
  - square: false
    type: grid
    columns: 3
    cards:
        card_type: button
        entity: binary_sensor.sala_porta_contact
        icon: mdi:door
        card_mod:
          style: |
            .switch-button {
                {% if is_state(config.entity, 'on') %}
                  background-color: #990000 !important
                {% else %}
                  background-color: green !important
                {% endif %}
    card_type: separator
    icon: mdi:lightbulb-group
  - square: false
    type: grid
    columns: 2
    cards:
        card_type: button
        button_type: switch
        entity: light.luz_sala_meio
        card_type: button
        button_type: switch
        entity: light.luz_sala_spots
        icon: mdi:spotlight
        card_type: button
        button_type: slider
        entity: light.ambilight_sala
        icon: mdi:led-strip-variant
    icon: mdi:play
  - square: false
    type: grid
    columns: 2
    cards:
        card_type: button
        button_type: slider
        entity: media_player.2_cast_sala
        icon: mdi:google-chrome
Maybe I discovered.
When I disabled the entity, it fixed…
Maybe an conflict with “group” entities?
But on my tests
and then I re-write the same entity group as before, and worked fine ( in GUI, but if I insert it with editor, it broke again )
this is very interesting hahahha
@Cloos check the video here in my Drive, for you to understand better…
This is what I get… only changes i made were to my entities
veeery weird hahahha
I really dont understand, maybe a cache problem…
I’ve never tried with the group type, I didn’t even knew that it was a thing haha. My light groups are starting with light., I will try that type and see what I can do but I will be really busy for 3 or 4 days.
I would like to do something like this too, but I don’t see that it is possible. Maybe it’s just a bunch of examples together in one image.
Hey All,
I might have missed it but is there a way to always start with the same pop-up card?.
At this point, when i load the app it shows the bottom bar but the page is empty untill i select a card from the bottom.
Is it possible to change the Backgroundcolor of the horizontal-buttons-stack buttons?
Hi! Yes you can, just add this in YAML mode:
styles: |
  .button {
    /* The color you want */
    background: blue !important;
Yes, now in beta 8 you can just add your hash to the url of your view, like this and this pop-up (#kitchen) will always open when you open this view:
Thanks, IT works.
Another question.
Is it possible to use the horizontal-buttons-stack only with the icons (without text)?
Yes, it’s now possible in the new beta.
Hi there!
Great job! I’m sure it will make a big impact on HS soon :smiley:
I have a question: I changed the background color of a light button to white, but now when I turn on the light, it doesn’t change the color and stays white.
As a result, I can’t tell whether my lights are on or off.
Can you tell me how to resolve this ?
sorry for disturb you guys
amazing;) its really usefull to use inside another dashboard… a question, how you use the styles: |
#root {
opacity: 0.5;
im unable to make the popup more “transparent” where do you put that code?
PNG image
style needs to be in the pop-up card.
cards:
    card_type: pop-up
    hash: '#tor'
    icon: mdi:gate
    state: binary_sensor.tor_garten_schloss
    state_unit: null
    styles: |
      #root {
        opacity: 0.5;
  - type: entities
    entities:
      - entity: switch.tor_garten_relay_open
last question… anyway to change the color of the popup button?PNG image
Maybe I too am doing something wrong. When I tried the code it makes everything “transparent “. I was looking to make only the background of the popup transparent and have the other cards or entities normal.
Anybody using the pop-up with sucess in an “all yaml” dashboard? I got it working, but it takes more than 20 seconds to load, plus a few extra presses here and there. It never loads fully by itself.
Isn’t enough to set in the same dashboard, also you must to set inside same view, in my case I have a different views in the same dashboard, and I was try to set the pop-up launcher button on different view and it was not possible until I added all in same view (the trigger button and full bubble view)
