⚪ Bubble Card - A minimalist card collection for Home Assistant with a nice pop-up touch
Have you tried placing this card at the last position on your view?
Thanks for taking the time and effort to reply - much appreciated. I’ll try those items out.
Thanks - I’ll try that too.
Would like to know how to change color by using conditioning state like :
type: custom:bubble-card
card_type: button
button_type: state
card_layout: large-2-rows
entity: person.XxX
icon: mdi:human-male
show_state: true
styles: |
  .bubble-button-card-container {
    background-color: ${state === 'home' ? 'green' : 'red'} !important;
  .bubble-sub-button-1 {
    display: ${hass.states['sensor._wifi_connection'].state === 'connected' ? '{hass.states['sensor._wifi_connection'].state' : ${hass.states['sensor._wifi_connection'].state === 'not connected' ? 'none'} !important;
  .bubble-sub-button-2 {
    background-color: ${hass.states['person.XxX'].state === 'home' ?  'green' : 'red'} !important;
  .bubble-sub-button-3 {
  .bubble-sub-button-4 {
sub_button:
  - entity: sensor._wifi_connection
    icon: mdi:wifi
    show_background: false
    show_state: true
    tap_action:
      action: more-info
    show_last_changed: true
    show_attribute: false
    show_name: false
  - entity: sensor._battery_level
    icon: mdi:battery
    show_state: true
    tap_action:
      action: more-info
  - entity: sensor._next_alarm
    icon: mdi:alarm
    show_state: true
    tap_action:
      action: more-info
  - entity: sensor.home__distance
    icon: mdi:map-marker-distance
    show_state: true
    tap_action:
      action: more-info
Hi Cloos,
what theme are you using. Can you share it with us?
looks fantastic :slight_smile:
I tried all the options suggested - putting the card at the very bottom of the dashboard yaml worked apart from the horizontal button stack which still appears on top and not under the overlay. I did try this but no idea if the z-index is supported in the horizontal button stack? - it didn’t work and I tried various z-indicies.
      - type: custom:bubble-card
        transform: none !important
        z-index: 999 !important
        card_type: horizontal-buttons-stack
        1_link: '#lights'
        1_name: ''
        1_icon: hue:bulb-classic
        1_entity: null
        hide_gradient: true
        is_sidebar_hidden: false
        2_name: ''
        2_icon: mdi:cctv
        2_link: '#cameras'
        3_link: '#weather'
        3_name: ''
        3_icon: mdi:weather-hail
        5_link: '#alarm'
        5_icon: mdi:alarm
        rise_animation: true
        4_name: ''
        4_icon: mdi:music
        4_link: '#music'
        card_mod:
          style: |
            .bubble-background {
              background-color: transparent;
many thanks.
Hi, this my own theme, it is available on GitHub here:
Take a look at this section in the documentation, this is absolutely not how you can do this :sweat_smile: Read the “Tip” part to understand what you need to change in the CSS.
I’m not sure to understand, your YAML should works, isn’t it?
Thanks - I’d not seen that section in the docs - really very useful :slight_smile:
So I see that the horizontal button card is set with z-index: 6 any idea why my element with a higher z-index won’t appear over the top? I’ve tried the rediculously high numbers and just 7 etc to be over the top of the horizontal button stack. Is there anything else going on that would break the stacking order?
Thanks.
So your card is at the very last position? After your horizontal buttons stack?
If yes it might be because of the CSS positioning of your card but I’m not sure.
Yes, this is the full dashboard code - the ‘overlay’ is at the very bottom. The rest of the elements play nicely, it’s just the horizontal buttons stack that resolutely shows on top.
kiosk_mode:
  user_settings:
    - users:
        - Paul
      ignore_entity_settings: true
  entity_settings:
    - entity:
        input_boolean.kiosk_hide_header_and_sidebar: 'on'
      hide_sidebar: true
      hide_header: true
    - entity:
        input_boolean.kiosk_hide_header_and_sidebar: 'off'
      hide_sidebar: false
      hide_header: false
  - title: Home
    path: bedside-table
    background: >-
      center / cover no-repeat fixed
      url('/local/images/backgrounds/leaf-darker-background.png')
    type: custom:vertical-layout
    cards:
      - type: custom:digital-clock
        dateFormat: cccc dd LLLL yyyy
        timeFormat: HH:mm
        card_mod:
          style: |
            ha-card {
              border-color: transparent;
              box-shadow: none;
            span.first-line
            font-size: 10em;
            margin-top:-5px;
            margin-bottom:10px;
            span.second-line
            font-size: 2em;
            margin-bottom:5px;
      - show_current: true
        show_forecast: false
        type: weather-forecast
        entity: weather.forecast_home
        forecast_type: daily
        card_mod:
          style: |
            ha-card {
              box-shadow: none;
      - type: conditional
        conditions:
          - condition: state
            entity: binary_sensor.kitchen_sink_water_leak_moisture
            state: 'on'
        card:
          type: custom:mushroom-template-card
          primary: Kitchen sink leak detected!
          secondary: null
          icon: mdi:water
          tap_action:
            action: none
          hold_action:
            action: none
          double_tap_action:
            action: none
          badge_color: white
          card_mod:
            style:
              mushroom-shape-icon$: |
                .shape {
                  --shape-color: transparent !important;
                ha-state-icon {
                  color: white;
                  --icon-symbol-size: 40px;
                ha-card {
                  background-color: #732629;
                  --card-primary-color: white;
                  --card-secondary-color: white;
      - type: conditional
        conditions:
          - condition: state
            entity: input_boolean.front_door_letterbox_opened
            state: 'on'
        card:
          primary: Something posted through letterbox
          secondary: null
          icon: mdi:email
          tap_action:
            action: call-service
            service: input_boolean.turn_off
              entity_id: input_boolean.front_door_letterbox_opened
          hold_action:
            action: none
          double_tap_action:
            action: none
          badge_color: white
          card_mod:
            style:
                .shape {
                ha-state-icon {
                  color: white;
                ha-card {
                  background-color: #e3af46;
      - square: false
        type: grid
        cards:
            primary: Paul's Alarm
            icon: mdi:alarm
            entity: input_boolean.paul_s_alarm_clock_on_off
            tap_action:
              service: input_boolean.toggle
                entity_id: input_boolean.paul_s_alarm_clock_on_off
            hold_action:
              action: navigate
              navigation_path: '#alarm'
            double_tap_action:
              action: none
            icon_color: >-
              {{ 'light-green' if
              states('input_boolean.paul_s_alarm_clock_on_off') == 'on' else
              'dark-grey' }}
            card_mod:
              style:
                  .shape {
                    --icon-symbol-size: 35px;
                    --icon-size: 50px;
                  ha-card {
                    box-shadow: none;
                    --card-primary-font-size: 1.2em;
            primary: Simon's Alarm
            icon: mdi:alarm
            entity: input_boolean.simon_s_alarm_clock_on_off
            tap_action:
                entity_id: input_boolean.simon_s_alarm_clock_on_off
            hold_action:
              action: navigate
            double_tap_action:
              action: none
            icon_color: >-
              {{ 'light-green' if
              states('input_boolean.simon_s_alarm_clock_on_off') == 'on' else
              'dark-grey' }}
            secondary_info: none
            card_mod:
              style:
                  .shape {
                    --icon-size: 50px;
                  ha-card {
                    box-shadow: none;
        columns: 2
      - square: false
        type: grid
        cards:
            primary: Day
            secondary: Scene
            icon: hue:bulb-filament
            entity: scene.office_office_day
            icon_color: >-
              {{ 'light-green' if states('switch.office_day_stateful_scene') ==
              'on' else 'dark-grey' }}
            fill_container: false
            card_mod:
              style:
                mushroom-state-info$: |
                  .container {
                   --card-primary-font-size: 18px;
                   --card-secondary-font-size: 13px;
            primary: Night
            secondary: Scene
            entity: scene.office_office_night
            icon_color: >-
              {{ 'light-green' if states('switch.office_night_stateful_scene')
              == 'on' else 'dark-grey' }}
            card_mod:
              style:
                  .container {
            primary: Lights
            secondary: 'OFF'
            icon: mdi:lightbulb-group-off
            entity: scene.office_lights_off
            icon_color: dark-grey
            card_mod:
              style:
                  .container {
        columns: 3
      - square: false
        type: grid
        cards:
            card_type: button
            button_type: slider
            entity: light.bedroom_pauls_lamp
            show_state: false
            tap_action:
              action: toggle
            double_tap_action:
              action: none
            hold_action:
              action: none
            card_layout: large
            styles: ''
            card_type: button
            button_type: slider
            entity: light.bedroom_simons_lamp
            show_state: false
            tap_action:
              action: toggle
            double_tap_action:
              action: none
            hold_action:
              action: none
            card_layout: large
        columns: 2
      - type: vertical-stack
        cards:
            card_type: pop-up
            hash: '#lights'
            hide_backdrop: false
            state: null
            text: null
            margin_top_desktop: 20px
            margin_top_mobile: '-56px'
            shadow_opacity: 20
            bg_opacity: 10
            bg_blur: 10
            button_type: slider
            show_icon: true
            show_name: true
            close_on_click: false
            background_update: false
            trigger_close: false
            tap_action:
              action: toggle
            double_tap_action:
              action: none
            hold_action:
              action: none
            icon: hue:bulb-group-classic-hung-3-alt
            force_icon: false
            show_state: true
            show_last_updated: true
            show_attribute: true
            card_type: separator
            card_type: button
            button_type: slider
            name: Paul's bedside lamp
            show_state: true
            show_last_updated: false
            sub_button: []
            card_type: button
            button_type: slider
            name: Simon's bedside lamp
            show_state: true
            sub_button: []
            card_type: button
            button_type: slider
            show_state: true
            sub_button: []
            entity: light.bedroom_table
            card_type: button
            button_type: slider
            entity: light.bedroom_ceiling
            show_state: true
            sub_button: []
            icon: hue:bulb-classic-hung
            card_type: button
            entity: light.bedroom_fan
            icon: mdi:fan
            card_type: button
            entity: input_boolean.en_suite_auto_fan_bypass
            icon: mdi:fan
            name: En-Suite extract fan
        cards:
            card_type: pop-up
            hash: '#cameras'
            trigger_entity: input_boolean.camera_thinksmart_full_screen_popup
            trigger_state: 'on'
            trigger_close: true
            state: null
            text: null
            shadow_opacity: 20
            bg_opacity: 10
            bg_blur: 10
          - camera_view: live
            type: picture-glance
            entities: []
            camera_image: camera.192_168_0_10
            tap_action:
              action: none
            hold_action:
              action: none
        cards:
            card_type: pop-up
            hash: '#weather'
            show_name: false
            show_icon: false
            hide_backdrop: true
          - type: iframe
            url: >-
              https://embed.windy.com/embed.html?type=map&location=coordinates&metricRain=default&metricTemp=default&metricWind=default&zoom=8&overlay=radar&product=radar&level=surface&lat=51.509&lon=-1.994
            aspect_ratio: 135%
        cards:
            card_type: pop-up
            hash: '#music'
            state: null
            text: null
            shadow_opacity: 20
            bg_opacity: 10
            bg_blur: 10
            button_type: name
            'false': []
            show_icon: false
            scrolling_effect: false
          - type: iframe
            url: https://music.siliconpixel.com/#/home
            aspect_ratio: 140%
        cards:
            card_type: pop-up
            hash: '#alarm'
            margin_top_desktop: 0px
            margin_top_mobile: '-57px'
            name: Turn alarms on/off
          - square: false
            type: grid
            cards:
                icon: mdi:alarm
                tap_action:
                hold_action:
                  action: navigate
                double_tap_action:
                  action: none
                icon_color: >-
                  {{ 'light-green' if
                  'dark-grey' }}
                card_mod:
                  style:
                      .shape {
                        --icon-size: 50px;
                      ha-card {
                        box-shadow: none;
                icon: mdi:alarm
                tap_action:
                hold_action:
                  action: navigate
                double_tap_action:
                  action: none
                icon_color: >-
                  {{ 'light-green' if
                  else 'dark-grey' }}
                card_mod:
                  style:
                      .shape {
                        --icon-size: 50px;
                      ha-card {
                        box-shadow: none;
            columns: 2
            name: Set alarm times
          - type: custom:time-picker-card
            entity: input_datetime.paul_s_alarm
            hour_mode: 24
            hour_step: 1
            minute_step: 5
            layout:
              hour_mode: double
              align_controls: right
              embedded: true
              thin: false
            hide:
              seconds: true
            link_values: false
            name: Paul's Alarm Clock
            tap_action:
              - service: input_boolean.toggle
                metadata: {}
                data: {}
            entity: input_datetime.simon_s_alarm
            hour_mode: 24
            hour_step: 1
            minute_step: 5
            layout:
              hour_mode: double
              embedded: true
            hide:
              seconds: true
        1_link: '#lights'
        1_name: ''
        1_entity: null
        hide_gradient: true
        2_name: ''
        2_icon: mdi:cctv
        2_link: '#cameras'
        3_link: '#weather'
        3_name: ''
        5_link: '#alarm'
        5_icon: mdi:alarm
        4_name: ''
        4_icon: mdi:music
        4_link: '#music'
        styles: 'z-index: 6'
      - type: custom:mod-card
        style: |
          ha-card {
            position: fixed;
            top: 0;
            left: 0;
            width: 100vw;
            height: 100vh;
            background: rgba(0, 0, 0, {{ states('input_number.bedside_table_device_overlay_brightness') }});  # Use the variable here
            z-index: 7 !important;
            pointer-events: none;  # Make overlay non-interactive
            display: flex;
            justify-content: center;
            align-items: center;
          ha-card > div {
            pointer-events: auto;  # Make the inner elements interactive
    theme: M3-D07-DarkOliveGreen
title: Office Panel
Actually, viewing the layers in Chrome (great 3D layer visualisation), I can see that the mod-card overlay is on top but if I show internal layers, .bubble-backdrop.backdrop.is-hidden and another element shows over the top. In the stack order, the ha-card.horizontal-buttons-stack-card.type-custom-bubble-card shows under but in the visualisation, it shows on top - which is the issue. No idea how to get that to behave :frowning: The popups are all on the top too.
Thank you @cloos and your team for all the hard work on this. Amazing. I am curious if you might consider changing the occupancy sensor and the color sensor on the horizontal button stack to allow any on/off entity, including media players, switches, and input booleans for example. I have found this card to be a perfect solution for remote control popups, where those sensors are a reference to the TV’s that are currently turned on. It does work perfectly fine coding those entities manually in yaml, but it would be nice if those fields weren’t coded as binary_sensor’s only as a selection option in the GUI.
Code
cards:
    card_type: pop-up
    hash: '#living_room'
    icon: mdi:remote
    entity: script.living_room_tv_power_toggle
    show_state: false
    show_last_changed: false
    attribute: friendly_name
    show_icon: false
    force_icon: false
    tap_action:
      action: none
    double_tap_action:
      action: none
    hold_action:
      action: none
    sub_button:
      - entity: script.living_room_tv_power_toggle
        icon: mdi:power
        show_icon: true
        tap_action:
          action: toggle
        hold_action:
          action: more-info
    show_name: false
    card_layout: normal
    bg_opacity: '40'
  - type: conditional
    conditions:
      - condition: state
        entity: media_player.living_room_tv
        state: 'on'
    card:
      cards:
        - type: custom:gap-card
          height: 3
        - type: custom:android-tv-card
          title: ''
          keyboard_id: media_player.fire_tv_living_room
          keyboard_mode: FIRE TV
          slider_id: media_player.living_room_sonos
          rows:
            - - tv_source
              - channel_up
              - info
              - channel_down
            - - jellyfin
              - youtube
              - primevideo
              - tv
            - - volume_slider
            - - touchpad
            - - back
              - home
              - keyboard
            - - rewind
              - play_pause
              - fast_forward
          custom_actions:
            slider:
              range:
                - 0
                - 1
              step: 0.01
            tv_source:
              icon: mdi:video-input-hdmi
              tap_action:
                service: media_player.select_source
                  entity_id: media_player.living_room_tv
                  source: HDMI
            up:
              tap_action:
                service: script.turn_on
                  entity_id: script.adb_fire_tv_living_room_up
                data: {}
            down:
              tap_action:
                  entity_id: script.adb_fire_tv_living_room_down
                data: {}
            left:
              tap_action:
                  entity_id: script.adb_fire_tv_living_room_left
                data: {}
            right:
              tap_action:
                  entity_id: script.adb_fire_tv_living_room_right
                data: {}
            center:
              tap_action:
                  entity_id: script.adb_fire_tv_living_room_center
                data: {}
            back:
              tap_action:
                  entity_id: script.adb_fire_tv_living_room_back
                data: {}
            home:
              tap_action:
                  entity_id: script.adb_fire_tv_living_room_home
                data: {}
            tv:
              tap_action:
                service: script.select_fire_tv_source_tv
                data: {}
            jellyfin:
              icon: mdi:jellyfish
              tap_action:
                  entity_id: script.select_fire_tv_source_jellyfin
                  variables:
                    entity_id: media_player.fire_tv_living_room
            primevideo:
              tap_action:
                  entity_id: script.select_fire_tv_source_primevideo
                  variables:
            youtube:
              tap_action:
                  entity_id: script.select_fire_tv_source_youtube
                  variables:
            play_pause:
              tap_action:
                  entity_id: script.adb_fire_tv_living_room_play_pause
                data: {}
            rewind:
              tap_action:
                  entity_id: script.adb_fire_tv_living_room_rw
                data: {}
            fast_forward:
              tap_action:
                  entity_id: script.adb_fire_tv_living_room_ff
                data: {}
  - type: conditional
    conditions:
      - condition: state
        state_not: 'on'
    card:
      cards:
          height: 100
        - type: tile
          color: red
          vertical: true
          icon: mdi:power
          name: Power the TV on.
          hide_state: true
          tap_action:
            action: toggle
          icon_tap_action:
            action: toggle
          card_mod:
            style: |
              ha-card {
                #font-family: 'Courier New';
                box-shadow: none;
                border: 0px;
                --tile-color: green !important;
              ha-tile-icon {
                --mdc-icon-size: 40px;
This is still not the way to change the z-index, you need to target the element, here is how you can change it:
styles: |
  .horizontal-buttons-stack-card {
        z-index: 5 !important;
Indeed, any entity type that has a last_changed time is supported (so basically every entities), I will change that in the next release :ok_hand:
Just add opacity: 1 !important; to change that :slightly_smiling_face:
Thanks but it doesn’t help unfortunately - the bubble card buttons and popups are still on top of everything else, no matter what z-index I use for the button stack or the mod-card. There must be something in there that’s breaking the order maybe.
How i set this at bottom?
Hi, i have some problems with the pop up card and my theme. I use the rounded theme (🟣 Rounded - Dashboard guide) and cant get the background color for the pop up in dark/light mode right.
i have it set to var(–black1) in the picture.
