How to have different colors for light and switches. The code helps to apply color to light.x domain. Is there a way to apply the changes to swithc.x domain as well
at theme level.
Thank you very much. I have watched the video. Wile I like the effect, the setup is actually very fiddly, with way more yaml and card stacking than I expected. Therefore I am still hesitating on building that in.
Somehow this also has to work simpler with less copy and paste of code and manual adjustments everywhere.
Here is a standard way with using the visibility option and a helper, just a drop-down instead of tabs, but therefore all via UI.
Can someone explain to me where I can make the global CSS entries so that they are used for the entire dashboard?
I can make the CSS changes in the individual cards via the style options. But if it can be done globally, then that would be the better way. Unfortunately I don’t know where to enter them.
Does anyone know how to make fan ON/OFF correct transition?
I tried to make it, but it doesn’t look correct as it fades through white colour and it doesn’t look like it was implemented in Mushroom cards.
Hello dear fellow bubblers
I was wondering if there’s a way to change the style of a button in the moment it’s being clicked?
What style do I need to change?
I was hoping to add:
@ciddi89, I am very sorry for disturbing, but I think that I have some sort of a bug.
Touch screen:
When I use the phone (touchscreen), all the items in all bubble cards are being activated by the press of the finger (not by the release).
Basically, when I want to scroll and touch an active area of any bubble card, it gets activated. It’s very annoying as I need to carefully press where nothing could be activated. With other cards (Mushroom, standard HA cards etc.) activation is only on the release of the finger.
Slider:
Due to similar issue as mentioned above, when I use finger to change slider position, it sends many commands and gets the device hanged up. I don’t see anything like that with Mushroom sliders as the command is sent once I release finger at certain position of the slider.
Please advise if it is the way the card should work or it’s a bug. I am presently using v2.3.0-beta.2.
One question, or suggestion. I am currently using the horizontal card as navigation on mobile. Every bubble points to a page in my dashboard. Is there any chance, that we can hide the bubble, on which page i am currently. Like, when I am on the Main Page, the bubble should be hidden or leave out. Best would be dynamiclly
Hello, I want to remove the white border from my horizontal button stack. And is it possible to adjust the gradient color instead of gray? Does anyone have any more examples of custom styling for the horizontal button stack?
