⚪ Bubble Card - A minimalist card collection for Home Assistant with a nice pop-up touch
Does this go in the individual bubble card itself? I haven’t tackled the css customizations yet because they seem a little intimidating.
Yes indeed.
I understand .css can be intimidating but you can start with something easy.
Like just copy-pasting the code presented here.
If you find this to be to much you can wait a couple of days/weeks until I have finished the new code and Cloos accepts it.
The new code will look something like this. (depending on if Cloos agreas)
For the icon, you could use a small hack. Just fill in “no-icon” where it asks for a custom icon, then it will not find it and leave it blank.
For the sub-button, add cover, like this.
.bubble-sub-button-1{
  background-image: url("https://community.home-assistant.io/user_avatar/community.home-assistant.io/mrbearpresident/48/585054_2.png") !important;
  display: block !important;
  background-size: cover;
Thanks, I don’t mind waiting for the bugs to be ironed out.
The current implementation using the css snippet you gave ends up with buttons outside of the bubble. I guess I’ll just wait, looking forward to this fix.
Are you using sections already?
If not I’ll advice you switch to it.
Then in the layout tab from HA choose: 2 rows.
You can also choose (in the bubble-card under “styling options”) the “card layout”: Large with 2 sub-button rows.
This will make the sub-buttons smaller.
hmmm.
This code:
.bubble-button-card-container {
 border-radius: 10px !important;
.bubble-icon {
 color: ${parseFloat(hass.states['sensor.solar_watt'].state) > 100 ? '#9EBE51' : '#7F7F7F'} !important;
living here in the editor:
gives me this:
I can change the value to 5px and immediately see the change in the preview.
Thanks, that works, the combination of background-size and display did it, the official example in the documentation just has one, which leads to the picture being not centered and resized properly. :+1:
vidn
@Cloos Please check the video. I don’t know if this is a bug or I am doing something wrong.
Whenever I try to change the volume, the text disappears from the media player card.
type: custom:bubble-card
card_type: media-player
entity: media_player.speaker
card_layout: large-2-rows
cover_background: true
Kindly guide how to fix this.
Thank you.
Maybe a dumb question:
Does anybody know, how to achive the same background color as the regular HA theme, when switching from dark to bright mode?
I want to integrate the cards visually into the standard behavior and look from HA (almost white during day, dark gray during night, preferably with a contour).
Thanks!
I am also really keen for this.
He is using the climate card. Guess that has a different container name, like also the media player requires another code:
.bubble-media-player-container {
I do not use the climate card, needs to be looked up in the styles file on github.
Now, i think i’ve found it :slight_smile:
.bubble-climate-container {
This should do the trick for you. :slight_smile:
@flobidan was on the right track there.
:host{
  --bubble-border-radius: 12px;
  --bubble-select-list-width: 200px;
  --bubble-icon-border-radius: 200px;
.bubble-button-card-container{
  height: calc( var(--row-height) * var(--row-size) + var(--row-gap) * ( var(--row-size) - 1 )) !important;
  border-style: solid;
  border-width: var(--ha-card-border-width,1px) !important;
  border-color: var(--ha-card-border-color,var(--divider-color,#e0e0e0));
.bubble-button-background{
  background: var(--ha-card-background,var(--card-background-color,#fff));
Hello, After the last update, after partially lowering the blind, I can no longer lower the blind. Is there a way to make these two icons always active?
Maciej
Thanks, but it doesn’t, as I wrote in my first post :wink: That’s why I’ve asked…
Edit: ok, copied your code and it worked,then noticed, that I’ve missed the “!” in my code… thanks for pointing me in the right direction…
@RKCKBN Sorry, did miss this. :man_with_probing_cane:
Nevertheless, i tried this with a climate card by myself and it works as expected.
Did you try this on an individual card? This is what i did for testing (not in the source style file)… Just to confirm that it works at all on your side…
Thank you, this looks promising, although it get this (background is not 10px rounded):
Edit:
Got something in the wrong place, now it works great. Thanks again.
What a great card collection! and so open to customisation.
I found that one can even change the background color of a sub-button as well as the icon depending on the state of an emtity :slight_smile:
Closed lock
2024-12-04 00_09_32-Propelllergatan – Home Assistant
Open lock
2024-12-04 00_09_55-Propelllergatan – Home Assistant
YAML code:
styles: >
    .bubble-sub-button-4 { background-color: ${hass.states['lock.main_door'].state
     === 'unlocked' ?  'red' : 'rgba(92, 83, 103, 1)' } !important;
    ${subButtonIcon[3].setAttribute("icon", hass.states['lock.main_door'].state
     === 'locked' ? 'mdi:lock-outline' : 'mdi:lock-open-outline')} }
one cn as well change the color of the icon in the sub button:
  #.bubble-sub-button-4 > ha-icon {color: ${hass.states['lock.main_door'].state
  === 'unlocked' ? 'green' : 'white'} !important;
Sharing a silly card I made for my Go Lamps to call scripts that change the colors.
card_type: button
button_type: switch
sub_button:
  - entity: script.lights_turn_lightcoral
    show_state: false
    show_name: false
    show_attribute: false
    show_last_changed: false
    icon: mdi:square
    state_background: false
    show_background: false
    tap_action:
      action: toggle
  - entity: script.lights_turn_yellowgreen
    show_state: false
    show_name: false
    icon: mdi:square
    tap_action:
      action: toggle
  - entity: script.lights_turn_ghostwhite
    show_state: false
    show_name: false
    icon: mdi:square
    tap_action:
      action: toggle
  - entity: script.lights_turn_chocolate
    show_state: false
    show_name: false
    icon: mdi:square
    tap_action:
      action: toggle
  - entity: script.lights_turn_cyan
    show_state: false
    show_name: false
    icon: mdi:square
    tap_action:
      action: toggle
  - entity: script.lights_turn_crimson
    show_state: false
    show_name: false
    icon: mdi:square
    tap_action:
      action: toggle
  - entity: script.lights_turn_darkorchid
    show_state: false
    show_name: false
    icon: mdi:square
    tap_action:
      action: toggle
  - entity: script.lights_turn_peachpuff
    show_state: false
    show_name: false
    icon: mdi:square
    tap_action:
      action: toggle
    show_state: false
    show_name: false
    icon: mdi:square
    tap_action:
      action: toggle
  - entity: script.lights_turn_midnightblue
    show_state: false
    show_name: false
    icon: mdi:square
    tap_action:
      action: toggle
name: Go Lamp Colors
double_tap_action:
  action: none
hold_action:
  action: none
entity: script.lights_turn_random
icon: mdi:bulb
show_state: false
tap_action:
  action: toggle
button_action:
  double_tap_action:
    action: none
  hold_action:
    action: none
  tap_action:
    action: none
styles: |2-
    .icon {
      background-image: url("/local/images/colors/randomcolor.png");
    .bubble-sub-button-1 {
      background-color: lightcoral !important;
    .bubble-sub-button-2 {
      background-color: yellowgreen !important;
      .bubble-sub-button-3 {
      background-color: ghostwhite !important;
      background-color: chocolate !important;
      .bubble-sub-button-5 {
      background-color: cyan !important;
      .bubble-sub-button-6 {
      background-color: crimson !important;
      .bubble-sub-button-7 {
      background-color: darkorchid !important;
      .bubble-sub-button-8 {
      background-color: peachpuff !important;
      .bubble-sub-button-9 {
      background-color: yellow !important;
      .bubble-sub-button-10 {
      background-color: midnightblue !important;
    .bubble-sub-button-icon {
      display: none;
show_icon: true
show_name: true
May I ask, why do you do this with a script and not with a scene?
