Dear community,
I am trying to build my very first dashboard and I do like the bubble a LOT. So I wanna keep it mostly bubbly.
I have shutters that operate via IR. I have a boradlink device and captured all the signals, saved it in scripts and if I run them manually they work.
To operate the shutters I went down 2 roads.
- The not orange one: I used a dummy entity (helper) for the main button and tried to run a script from each of the sub buttons from a different entity. Doesn’t work.
type: custom:bubble-card
card_type: button
tap_action:
action: none
service: script.shutter_kitchen_down
entity_id: script.shutter_kitchen_down
entity: input_select.helper_window_state_1_3
icon: mdi:window-shutter-cog
hold_action:
action: none
double_tap_action:
action: none
button_action:
tap_action:
action: none
double_tap_action:
action: none
hold_action:
action: none
card_layout: large
sub_button:
- entity: script.shutter_kitchen_up
show_name: true
tap_action:
action: call-service
entity_id: script.shutter_kitchen_up
- entity: input_select.helper_window_state_1_3
icon: mdi:window-shutter-alert
show_name: true
tap_action:
entity_id: script.shutter_kitchen_stop
- entity: script.shutter_kitchen_down
show_name: true
tap_action:
- The orange version: I use the broadlink device (this sends out the IR codes) and launch a send command in each of the sub buttons (only added code for the close part, but the other 2 should be very similar in my mind). Doesn’t work and turns orange.
card_type: button
entity: remote.broadlink_kitchen_2
force_icon: false
show_attribute: false
show_last_changed: false
show_state: false
tap_action:
action: none
double_tap_action:
action: none
hold_action:
action: more-info
button_action:
tap_action:
action: none
double_tap_action:
action: none
hold_action:
action: none
card_layout: large
sub_button:
- entity: remote.broadlink_kitchen_2
icon: mdi:window-shutter-open
show_name: true
show_background: true
tap_action:
service: remote.send_command
entity_id: remote.broadlink_kitchen_2
device: 1-3_Window
command: Open all kitchen shutters
show_state: false
show_name: true
tap_action:
device: 1-3_Window
command: stop all kitchen shutters
show_name: true
tap_action:
device: 1-3_Window
command: close all kitchen shutters
How can I get them to work?
Any help is much appreciated!
