R32 is measuring 10.03K across the resistor and same across the two pins. That said, i think i found the answer. U5 is not happy… and it is likely my fault as I may have plugged the board in the wrong slot at first and blew a fuse. I plugged it into KL2 instead of KL4 on the M292 daughter board. that said, after the fuse blew and i took things apart, KL3 had some sever corrosion under it and that may have been the main cause of everything. I ended up buying a new R2107 thinking that was the only damaged thing but looks like the surge that blew the fuse could have also killed U5.
I ordered another board from you and will try again.
it is kinda hard to tell in the photo but the left side of U5 has a bubble on it.
I am also thinking it might not have been pluging it in the wrong slot that did it but rather the pre-existing corrosion on the board that previously had no load all of the sudden getting a load and arcing across thing that then killed the fuse and U5. This is probably more likely the case.
Daniel, i tried unseccsfully several time to connect to hotspot, from different phones and windows laptop… same result, unable to connect. So I decided to try different thing, I pulled module from 2105 changed jumper to USB power supply, connected to USB charger and retried using WiFi in my mac Pro. Voila! Mac instantly connected to module and ESP home recognized it. I clicked on Adoption and lots of things happened (i hope it was OK, this is my first ESP device ever). So for reference here is the log (trunkated, as was exceeding the forum post characters) limit:
INFO ESPHome 2024.4.1
INFO Reading configuration /config/esphome/km271-for-friends-21c160.yaml...
INFO Updating https://github.com/the78mole/esphome_components.git@main
WARNING GPIO2 is a strapping PIN and should only be used for I/O with care.
Attaching external pullup/down resistors to strapping pins can cause unexpected failures.
See https://esphome.io/guides/faq.html#why-am-i-getting-a-warning-about-strapping-pins
INFO Generating C++ source...
INFO Core config or version changed, cleaning build files...
INFO Compiling app...
Processing km271-for-friends-21c160 (board: esp32dev; framework: arduino; platform: platformio/[email protected])
Platform Manager: Installing platformio/espressif32 @ 5.4.0
INFO Installing platformio/espressif32 @ 5.4.0
Downloading [####################################] 100%
Unpacking [####################################] 100%
Platform Manager: [email protected] has been installed!
INFO [email protected] has been installed!
Tool Manager: Installing espressif/toolchain-xtensa-esp32 @ 8.4.0+2021r2-patch5
INFO Installing espressif/toolchain-xtensa-esp32 @ 8.4.0+2021r2-patch5
Tool Manager: [email protected]+2021r2-patch5 has been installed!
INFO [email protected]+2021r2-patch5 has been installed!
Tool Manager: Installing platformio/framework-arduinoespressif32 @ ~3.20005.0
INFO Installing platformio/framework-arduinoespressif32 @ ~3.20005.0
Tool Manager: [email protected] has been installed!
Tool Manager: Installing platformio/tool-esptoolpy @ ~1.40400.0
INFO Installing platformio/tool-esptoolpy @ ~1.40400.0
Tool Manager: Installing platformio/tool-scons @ ~4.40600.0
INFO Installing platformio/tool-scons @ ~4.40600.0
Library Manager: Installing esphome/AsyncTCP-esphome @ 2.1.3
INFO Installing esphome/AsyncTCP-esphome @ 2.1.3
Library Manager: [email protected] has been installed!
Library Manager: Installing esphome/ESPAsyncWebServer-esphome @ 3.1.0
INFO Installing esphome/ESPAsyncWebServer-esphome @ 3.1.0
Library Manager: Resolving dependencies...
INFO Resolving dependencies...
Library Manager: Installing esphome/noise-c @ 0.1.4
INFO Installing esphome/noise-c @ 0.1.4
Library Manager: Installing esphome/libsodium @ 1.10018.1
INFO Installing esphome/libsodium @ 1.10018.1
HARDWARE: ESP32 240MHz, 320KB RAM, 4MB Flash
- toolchain-xtensa-esp32 @ 8.4.0+2021r2-patch5
Dependency Graph
|-- AsyncTCP-esphome @ 2.1.3
|-- WiFi @ 2.0.0
|-- FS @ 2.0.0
|-- Update @ 2.0.0
|-- ESPAsyncWebServer-esphome @ 3.1.0
|-- DNSServer @ 2.0.0
|-- ESPmDNS @ 2.0.0
|-- noise-c @ 0.1.4
Compiling .pioenvs/km271-for-friends-21c160/src/esphome/components/adc/adc_sensor.cpp.o
Compiling .pioenvs/km271-for-friends-21c160/src/esphome/components/api/api_connection.cpp.o
Compiling .pioenvs/km271-for-friends-21c160/src/esphome/components/api/api_frame_helper.cpp.o
Compiling .pioenvs/km271-for-friends-21c160/src/esphome/components/api/api_pb2.cpp.o
Compiling .pioenvs/km271-for-friends-21c160/src/esphome/components/api/api_pb2_service.cpp.o
Compiling .pioenvs/km271-for-friends-21c160/src/esphome/components/api/api_server.cpp.o
Compiling .pioenvs/km271-for-friends-21c160/src/esphome/components/api/list_entities.cpp.o
Compiling .pioenvs/km271-for-friends-21c160/src/esphome/components/api/proto.cpp.o
Compiling .pioenvs/km271-for-friends-21c160/src/esphome/components/api/subscribe_state.cpp.o
Compiling .pioenvs/km271-for-friends-21c160/src/esphome/components/api/user_services.cpp.o
Compiling .pioenvs/km271-for-friends-21c160/src/esphome/components/binary_sensor/automation.cpp.o
Compiling .pioenvs/km271-for-friends-21c160/src/esphome/components/binary_sensor/binary_sensor.cpp.o
Compiling .pioenvs/km271-for-friends-21c160/src/esphome/components/binary_sensor/filter.cpp.o
Compiling .pioenvs/km271-for-friends-21c160/src/esphome/components/button/button.cpp.o
Compiling .pioenvs/km271-for-friends-21c160/src/esphome/components/captive_portal/captive_portal.cpp.o
Compiling .pioenvs/km271-for-friends-21c160/src/esphome/components/dashboard_import/dashboard_import.cpp.o
Compiling .pioenvs/km271-for-friends-21c160/src/esphome/components/esp32/core.cpp.o
Compiling .pioenvs/km271-for-friends-21c160/src/esphome/components/esp32/gpio.cpp.o
Compiling .pioenvs/km271-for-friends-21c160/src/esphome/components/esp32/preferences.cpp.o
Compiling .pioenvs/km271-for-friends-21c160/src/esphome/components/gpio/binary_sensor/gpio_binary_sensor.cpp.o
... trunkated
Compiling .pioenvs/km271-for-friends-21c160/FrameworkArduino/wiring_pulse.c.o
Compiling .pioenvs/km271-for-friends-21c160/FrameworkArduino/wiring_shift.c.o
Archiving .pioenvs/km271-for-friends-21c160/libFrameworkArduino.a
Linking .pioenvs/km271-for-friends-21c160/firmware.elf
RAM: [= ] 12.6% (used 41416 bytes from 327680 bytes)
Flash: [===== ] 53.7% (used 986209 bytes from 1835008 bytes)
Building .pioenvs/km271-for-friends-21c160/firmware.bin
Creating esp32 image...
Successfully created esp32 image.
esp32_create_combined_bin([".pioenvs/km271-for-friends-21c160/firmware.bin"], [".pioenvs/km271-for-friends-21c160/firmware.elf"])
Wrote 0x1022f0 bytes to file /data/build/km271-for-friends-21c160/.pioenvs/km271-for-friends-21c160/firmware-factory.bin, ready to flash to offset 0x0
======================== [SUCCESS] Took 107.56 seconds ========================
INFO Successfully compiled program.
INFO Resolving IP address of km271-for-friends-21c160.local
INFO -> 192.168.52.148
INFO Uploading /data/build/km271-for-friends-21c160/.pioenvs/km271-for-friends-21c160/firmware.bin (991984 bytes)
Uploading: [============================================================] 100% Done...
INFO Upload took 30.73 seconds, waiting for result...
INFO OTA successful
INFO Successfully uploaded program.
INFO Starting log output from km271-for-friends-21c160.local using esphome API
INFO Successfully connected to km271-for-friends-21c160 @ 192.168.52.148 in 8.230s
INFO Successful handshake with km271-for-friends-21c160 @ 192.168.52.148 in 0.243s
[16:42:39][I][app:100]: ESPHome version 2024.4.1 compiled on Apr 28 2024, 16:41:36
[16:42:39][I][app:102]: Project the78mole.km271-wifi version 1.0
[16:42:39][C][status_led:019]: Status LED:
[16:42:39][C][status_led:020]: Pin: GPIO21
[16:42:39][C][wifi:580]: WiFi:
[16:42:39][C][wifi:408]: Local MAC: A0:A3:B3:21:C1:60
[16:42:39][C][wifi:413]: SSID: [redacted]
[16:42:39][C][wifi:416]: IP Address: 192.168.52.148
[16:42:39][C][wifi:420]: BSSID: [redacted]
[16:42:39][C][wifi:421]: Hostname: 'km271-for-friends-21c160'
[16:42:39][C][wifi:423]: Signal strength: -39 dB ▂▄▆█
[16:42:39][C][wifi:427]: Channel: 8
[16:42:39][C][wifi:428]: Subnet: 255.255.255.0
[16:42:39][C][wifi:429]: Gateway: 192.168.52.1
[16:42:39][C][wifi:430]: DNS1: 192.168.52.21
[16:42:39][C][wifi:431]: DNS2: 192.168.52.21
[16:42:39][C][logger:166]: Logger:
[16:42:39][C][logger:167]: Level: DEBUG
[16:42:39][C][logger:169]: Log Baud Rate: 115200
[16:42:39][C][logger:170]: Hardware UART: UART0
[16:42:39][C][uart.arduino_esp32:137]: UART Bus 1:
[16:42:39][C][uart.arduino_esp32:138]: TX Pin: GPIO2
[16:42:39][C][uart.arduino_esp32:139]: RX Pin: GPIO4
[16:42:39][C][uart.arduino_esp32:141]: RX Buffer Size: 256
[16:42:39][C][uart.arduino_esp32:143]: Baud Rate: 2400 baud
[16:42:39][C][uart.arduino_esp32:144]: Data Bits: 8
[16:42:39][C][uart.arduino_esp32:145]: Parity: NONE
[16:42:39][C][uart.arduino_esp32:146]: Stop bits: 1
[16:42:39][C][gpio.binary_sensor:015]: GPIO Binary Sensor 'USER 2'
[16:42:39][C][gpio.binary_sensor:016]: Pin: GPIO27
[16:42:39][C][gpio.output:010]: GPIO Binary Output:
[16:42:39][C][gpio.output:011]: Pin: GPIO23
[16:42:39][C][gpio.output:011]: Pin: GPIO25
[16:42:39][C][switch.gpio:068]: GPIO Switch 'LED2_Green'
[16:42:39][C][switch.gpio:091]: Restore Mode: always OFF
[16:42:39][C][switch.gpio:031]: Pin: GPIO22
[16:42:39][C][km271:153]: Dump Config was called
[16:42:39][C][km271:156]: Sensor Versionsnummer NK enabled
[16:42:39][C][km271:156]: Sensor Versionsnummer VK enabled
[16:42:39][C][km271:156]: Sensor Brennerlaufzeit 2 Minuten 0 enabled
[16:42:39][C][km271:156]: Sensor Brennerlaufzeit 2 Minuten 1 enabled
[16:42:39][C][km271:156]: Sensor Brennerlaufzeit 2 Minuten 2 enabled
[16:42:39][C][km271:156]: Sensor Brennerlaufzeit 1 Minuten 0 enabled
[16:42:39][C][km271:156]: Sensor Brennerlaufzeit 1 Minuten 1 enabled
[16:42:39][C][km271:156]: Sensor Brennerlaufzeit 1 Minuten 2 enabled
[16:42:39][C][km271:156]: Sensor Gedaempfte Aussentemperatur enabled
[16:42:39][C][km271:156]: Sensor Aussentemperatur enabled
[16:42:39][C][km271:156]: Sensor Abgastemperatur enabled
[16:42:39][C][km271:156]: Sensor Brennerausschalttemperatur enabled
[16:42:39][C][km271:156]: Sensor Brennereinschalttemperatur enabled
[16:42:39][C][km271:156]: Sensor Kesselvorlaufisttemperatur enabled
[16:42:39][C][km271:156]: Sensor Kesselvorlaufsolltemperatur enabled
[16:42:39][C][km271:156]: Sensor WW Isttemperatur enabled
[16:42:39][C][km271:156]: Sensor WW Solltemperatur enabled
[16:42:39][C][km271:156]: Sensor Heizkennlinie HK2 bei - 10 Grad enabled
[16:42:39][C][km271:156]: Sensor Heizkennlinie HK2 bei 0 Grad enabled
[16:42:39][C][km271:156]: Sensor Heizkennlinie HK2 bei + 10 Grad enabled
[16:42:39][C][km271:156]: Sensor Mischerstellung HK2 enabled
[16:42:39][C][km271:156]: Sensor Pumpenleistung HK2 enabled
[16:42:39][C][km271:156]: Sensor Raumisttemperatur HK2 enabled
[16:42:39][C][km271:156]: Sensor Raumsolltemperatur HK2 enabled
[16:42:39][C][km271:156]: Sensor Vorlaufisttemperatur HK2 enabled
[16:42:39][C][km271:156]: Sensor Vorlaufsolltemperatur HK2 enabled
[16:42:39][C][km271:156]: Sensor Heizkennlinie HK1 bei - 10 Grad enabled
[16:42:39][C][km271:156]: Sensor Heizkennlinie HK1 bei + 10 Grad enabled
[16:42:39][C][km271:156]: Sensor Mischerstellung HK1 enabled
[16:42:39][C][km271:156]: Sensor Pumpenleistung HK1 enabled
[16:42:39][C][km271:156]: Sensor Raumisttemperatur HK1 enabled
[16:42:39][C][km271:156]: Sensor Raumsolltemperatur HK1 enabled
[16:42:39][C][km271:156]: Sensor Vorlaufisttemperatur HK1 enabled
[16:42:39][C][km271:156]: Sensor Vorlaufsolltemperatur HK1 enabled
[16:42:39][C][km271:156]: Sensor CFG_WW_Zirkulationspumpenintervall enabled
[16:42:39][C][km271:156]: Sensor CFG_WW_Betriebsmodus enabled
[16:42:39][C][km271:156]: Sensor CFG_HK2_Heizsystem enabled
[16:42:39][C][km271:156]: Sensor CFG_HK2_Absenkungsart enabled
[16:42:39][C][km271:156]: Sensor CFG_HK1_Heizsystem enabled
[16:42:39][C][km271:156]: Sensor CFG_HK1_Absenkungsart enabled
[16:42:39][C][km271:156]: Sensor CFG_WW_Temperatur enabled
[16:42:39][C][km271:156]: Sensor CFG_HK1_Heizprogramm enabled
[16:42:39][C][km271:156]: Sensor CFG_HK1_Urlaubstage enabled
[16:42:39][C][km271:156]: Sensor CFG_HK2_Raumtemperatur Offset enabled
[16:42:39][C][km271:156]: Sensor CFG_HK2_Auslegungstemperatur enabled
[16:42:39][C][km271:156]: Sensor CFG_HK2_Heizkreistemperatur Maximal enabled
[16:42:39][C][km271:156]: Sensor WW Fehler Anode enabled
[16:42:39][C][km271:156]: Sensor WW Fehler WW bleibt kalt enabled
[16:42:39][C][km271:156]: Sensor WW Fehler Fuehler enabled
[16:42:39][C][km271:156]: Sensor WW Fehler Desinfektion enabled
[16:42:39][C][km271:156]: Sensor WW Ferien enabled
[16:42:39][C][km271:156]: Sensor WW Nachladung enabled
[16:42:39][C][km271:156]: Sensor WW Desinfektion enabled
[16:42:39][C][km271:156]: Sensor WW Automatik enabled
[16:42:39][C][km271:156]: Sensor HK2 Externer Stoereingang enabled
[16:42:39][C][km271:156]: Sensor HK2 Maximaler Vorlauf enabled
[16:42:39][C][km271:156]: Sensor HK2 Fehler Vorlauffuehler enabled
[16:42:39][C][km271:156]: Sensor HK2 FB fehlerhaft enabled
[16:42:39][C][km271:156]: Sensor HK2 Keine Kommunikation mit FB enabled
[16:42:39][C][km271:156]: Sensor HK2 Tag-Modus enabled
[16:42:39][C][km271:156]: Sensor HK2 Sommer-Modus enabled
[16:42:39][C][km271:156]: Sensor Solarpumpe Absenkung enabled
[16:42:39][C][km271:156]: Sensor Zirkulationspumpe enabled
[16:42:39][C][km271:156]: Sensor Ladepumpe enabled
[16:42:39][C][km271:156]: Sensor HK1 Manuell enabled
[16:42:40][C][km271:156]: Sensor HK1 Frostschutz enabled
[16:42:40][C][km271:156]: Sensor HK1 Ferien enabled
[16:42:40][C][km271:156]: Sensor HK1 Estrichtrocknung enabled
[16:42:40][C][km271:156]: Sensor HK1 Warmwasservorrang enabled
[16:42:40][C][km271:156]: Sensor HK1 Automatik enabled
[16:42:40][C][km271:156]: Sensor HK1 Einschaltoptimierung enabled
[16:42:40][C][km271:156]: Sensor HK1 Ausschaltoptimierung enabled
[16:42:40][C][km271:156]: Sensor HK1 Externer Stoereingang enabled
[16:42:40][C][km271:156]: Sensor HK1 Maximaler Vorlauf enabled
[16:42:40][C][km271:156]: Sensor HK1 Fehler Vorlauffuehler enabled
[16:42:40][C][km271:156]: Sensor HK1 FB fehlerhaft enabled
[16:42:40][C][km271:156]: Sensor HK1 Keine Kommunikation mit FB enabled
[16:42:40][C][km271:156]: Sensor HK1 Tag-Modus enabled
[16:42:40][C][km271:156]: Sensor HK1 Sommer-Modus enabled
[16:42:40][C][km271:156]: Sensor HK2 Manuell enabled
[16:42:40][C][km271:156]: Sensor HK2 Frostschutz enabled
[16:42:40][C][km271:156]: Sensor HK2 Ferien enabled
[16:42:40][C][km271:156]: Sensor HK2 Estrichtrocknung enabled
[16:42:40][C][km271:156]: Sensor HK2 Warmwasservorrang enabled
[16:42:40][C][km271:156]: Sensor HK2 Automatik enabled
[16:42:40][C][km271:156]: Sensor HK2 Einschaltoptimierung enabled
[16:42:40][C][km271:156]: Sensor HK2 Ausschaltoptimierung enabled
[16:42:40][C][km271:156]: Sensor WW Vorrangschaltung enabled
[16:42:40][C][km271:156]: Sensor WW Nachbereitung enabled
[16:42:40][C][km271:156]: Sensor WW Tag Modus enabled
[16:42:40][C][km271:156]: Sensor WW Einschaltoptimierung enabled
[16:42:40][C][km271:156]: Sensor WW Ausschaltoptimierung enabled
[16:42:40][C][km271:156]: Sensor WW Nachladen enabled
[16:42:40][C][km271:156]: Sensor WW Manuell enabled
[16:42:40][C][km271:156]: Sensor WW Laden enabled
[16:42:40][C][km271:156]: Sensor Fehler Externe Stoerung enabled
[16:42:40][C][km271:156]: Sensor Fehler Sicherungskette ausgeloest enabled
[16:42:40][C][km271:156]: Sensor Fehler Abgas ueber Grenzwert enabled
[16:42:40][C][km271:156]: Sensor Fehler Abgasfuehler enabled
[16:42:40][C][km271:156]: Sensor Fehler Kessel bleibt kalt enabled
[16:42:40][C][km271:156]: Sensor Fehler Zusatzfuehler enabled
[16:42:40][C][km271:156]: Sensor Fehler Kesselfuehler enabled
[16:42:40][C][km271:156]: Sensor Fehler Brennerstoerung enabled
[16:42:40][C][km271:156]: Sensor Kessel Betrieb 2.Stufe enabled
[16:42:40][C][km271:156]: Sensor Kessel Leistung hoch enabled
[16:42:40][C][km271:156]: Sensor Kessel Leistung frei enabled
[16:42:40][C][km271:156]: Sensor Kessel unter Betrieb enabled
[16:42:40][C][km271:156]: Sensor Kessel Schutz enabled
[16:42:40][C][km271:156]: Sensor Kessel Betrieb 1.Stufe enabled
[16:42:40][C][km271:156]: Sensor Kessel Abgastest enabled
[16:42:40][C][km271:156]: Sensor Brenneransteuerung enabled
[16:42:40][C][km271:156]: Sensor Alarm HK2 Vorlauffuehler enabled
[16:42:40][C][km271:156]: Sensor Alarm Brenner enabled
[16:42:40][C][km271:156]: Sensor Alarm Kesselvorlauffuehler enabled
[16:42:40][C][km271:156]: Sensor Alarm Abgasfuehler enabled
[16:42:40][C][km271:156]: Sensor Heizkennlinie HK1 bei 0 Grad enabled
[16:42:40][C][km271:156]: Sensor CFG_HK1_Raumtemperatur Offset enabled
[16:42:40][C][km271:156]: Sensor CFG_Frost Umschalttemperatur enabled
[16:42:40][C][km271:156]: Sensor CFG_HK1_Betriebsart enabled
[16:42:40][C][km271:156]: Sensor CFG_HK1_Sommer_Winter Umschalttemperatur enabled
[16:42:40][C][km271:156]: Sensor CFG_HK1_Urlaubstemperatur enabled
[16:42:40][C][km271:156]: Sensor CFG_HK1_Raumsolltemperatur Tag enabled
[16:42:40][C][km271:156]: Sensor CFG_HK1_Raumsolltemperatur Nacht enabled
[16:42:40][C][km271:156]: Sensor CFG_HK1_Auslegungstemperatur enabled
[16:42:40][C][km271:156]: Sensor CFG_HK1_Heizkreistemperatur Maximal enabled
[16:42:40][C][km271:156]: Sensor CFG_HK1_Heizprogramm enabled
[16:42:40][C][km271:156]: Sensor CFG_HK1_Urlaubstage enabled
[16:42:40][C][km271:156]: Sensor CFG_HK2_Betriebsart enabled
[16:42:40][C][km271:156]: Sensor CFG_HK2_Sommer_Winter Umschalttemperatur enabled
[16:42:40][C][km271:156]: Sensor CFG_HK2_Urlaubstemperatur enabled
[16:42:40][C][km271:156]: Sensor CFG_HK2_Raumsolltemperatur Tag enabled
[16:42:40][C][km271:156]: Sensor CFG_HK2_Raumsolltemperatur Nacht enabled
[16:42:40][C][restart.button:017]: Restart Button 'KM271-WiFi Restart'
[16:42:40][C][adc:097]: ADC Sensor 'KM217 5V Supply'
[16:42:40][C][adc:097]: Device Class: 'voltage'
[16:42:40][C][adc:097]: State Class: 'measurement'
[16:42:40][C][adc:097]: Unit of Measurement: 'V'
[16:42:40][C][adc:097]: Accuracy Decimals: 2
[16:42:40][C][adc:107]: Pin: GPIO36
[16:42:40][C][adc:119]: Attenuation: 6db
[16:42:40][C][adc:142]: Update Interval: 5.0s
[16:42:40][C][captive_portal:088]: Captive Portal:
[16:42:40][C][mdns:115]: mDNS:
[16:42:40][C][mdns:116]: Hostname: km271-for-friends-21c160
[16:42:40][C][ota:096]: Over-The-Air Updates:
[16:42:40][C][ota:097]: Address: km271-for-friends-21c160.local:3232
[16:42:40][C][ota:103]: OTA version: 2.
[16:42:40][C][api:139]: API Server:
[16:42:40][C][api:140]: Address: km271-for-friends-21c160.local:6053
[16:42:40][C][api:142]: Using noise encryption: YES
[16:42:40][C][wifi_signal.sensor:009]: WiFi Signal 'KM217 WiFi Signal Sensor'
[16:42:40][C][wifi_signal.sensor:009]: Device Class: 'signal_strength'
[16:42:40][C][wifi_signal.sensor:009]: State Class: 'measurement'
[16:42:40][C][wifi_signal.sensor:009]: Unit of Measurement: 'dBm'
[16:42:40][C][wifi_signal.sensor:009]: Accuracy Decimals: 0
[16:43:25][D][sensor:094]: 'KM217 5V Supply': Sending state 44.10342 V with 2 decimals of accuracy
[16:43:36][D][sensor:094]: 'KM217 WiFi Signal Sensor': Sending state -42.00000 dBm with 0 decimals of accuracy
[16:44:25][D][sensor:094]: 'KM217 5V Supply': Sending state 44.20206 V with 2 decimals of accuracy
[16:44:36][D][sensor:094]: 'KM217 WiFi Signal Sensor': Sending state -44.00000 dBm with 0 decimals of accuracy
Automatically created configuration file for device looks following:
So I guess it might be ready to be reinserted to control unit… but I have some serious doubt here; when I was removing the card from control unit, I noticed that display went completely blank in meantime (I was not visiting basement for past few days) and also after turning the heater back on date and time were reset and needed to be set up (could be result of some internal wire being disconnected to make space for card movement). I checked this still being in basement, and after reinsterting card display was looking like it would run on nerly empty battery, very bleak. Though after that date and date were ok. Could be that card is draining some extra power from control unit? Can it be checked somehow? Or this might be result of card not being fully configured yet? Anyone experienced something similar?
please double check, if you populated the right slot. Another user killed his module recently (one of the Level-Shifters U4/U5). I have never heard about a control unit that has a wrong slot the KM271 fit’s into.
Another possibility is, that the power supply of your buderus is a “monday-model”. Try supplying it with USB and look, if it works then.
Daniel, I’ll test this today for sure! I have 2105 unit, so there is only one slot, cannot make mistake. So I understand that suplemental powering via USB is possibile and hould not cause any issues with 2 power supplies connected to unit? Frankly speaking I was hoping for such solution being possible, while I noticed these symtoms
My bad !!! I was blind, so much focused on the first full length slot I’ve seen, that I did not noticed the second one, a bit hidden from the point I was looking at device. Anyhow, I inserted the card (previously and now) luckily into the right slot,according to this picture: picture
Now the card started, connected to network and ESP home and now I can see tons of sensor populated with some information. I even can see them reacting in real time to changes in settings I make on heater (like target room temperature). GREAT ! ! !
The problem is, obviously that there is way too much infomration for start and that it is German. Is there any easier way to get this translated than renaming sensors one by one from UI? For now I’m scarry to change any paramenetrs
Also I do see the same problem that @righeouskill100 reported with reported KM271 5V Supply voltage being 42.54V… I guess this is not the true, since card would be burned out… You mentioned in your reply that some calibration needs to be done for this, how can I make it?
And last thing; seems the log file is not loading in device view - it spins the waiting wheel endlesly. Though I can see some log enries, when checking properties of individual entities.
“Unfortunately”, about 95% of the users are german… But you could easily find the english stuff in the sources const.py. For the sensors (inputs), you can not do any damage. For the numbers and selects, the danger is more due to accidentially changing the UI widget, as soon as it is available there. So, I would not hesitate to change the config. It will not by itself change values on the Buderus, when you just “link” it to Homeassistant. If you put in code (lambdas), for sure this is another thing.
But always keep a copy of a working YAML. Some errors/typos are really hard to find. And do not delete the section headings (number:, sensor:,…) even if they do not contain any entity. The component implementation is a bit picky in this regard and will refuse to compile.
Example:
In your YAML is still the multiplier from the default config:
Multiplier: 28.1826
Voltage from UI: 42.54V
Measured supply voltage with multimeter: 4.90V
28.1826 / 42.54 * 4.9 = 3.246
Put this new number into the YAML as the multiply: 3.246 and start the update of the device.
If you can not/don’t want to measure the Voltage, you could just assume, it is 5V. This way, you can not rely on the absolute value, but you will see the changes.
I don’t know what is about the log, I also see the spinner. No Idea how this can be changed. Maybe too much data for the log viewer
PS: Now it shows something Seems to take some time.
maybe some of my english speaking users already translated the config (sensor names) to english and would do me a great favor? I would then add it to my GitHub repo for others to be used
Daniel, so if I add to my config lines below row 113 in your config and replace the names with English (or Polish ) ones and then update the formware, I should get updated/translated names in HA?
One question (since ESPhome is new to me); if I do not need all these sensors or sliders related to secondary heating zone, can I just remove them from the fine, not to be created in HA?
I have the same problem, not being a native english speaker. Usually, my english is quite good, but not with heating systems
Perfect is the enemy of good I’ll add it to my repo.
Yes, just remove what you don’t need. It will disappear also from HA. But keep the section headings. My component implementation can not deal with it, when it is missing and it is not so easy for me to fix…
So, a minimalistic configuration would look like this:
Finaly have some more time to fiddle with and have few observations:
reloading config seems to duplicate entities in HA. Now I have some old, German entities and new, English one visible in the Device Info page. Here example of Room Temperature Offset:
Strangely, the same with some English entities:
What would be the right way to remediate? Delete device from ESPhome and add it again?
Another finding is related to translation; I think not all of options were listed in sample config. Not sure if I did not mess this up with not removed German sensors, though… One that are for sure missing are names of options from drop down lists:
Finally when I tried to upload whole configuration file I got some errors related to duplicate entries (even if these were defined only once in my file). I guess it might have something to do with generic configuration you enforce on the device (or whatever terminology for ESPhome would be)? here are the I found:
and here is sample error I get while trying to install this:
INFO ESPHome 2024.4.2
Failed config
sensor.adc: [source /data/packages/040b63aa/components/km271_wifi/km271-for-friends.yaml:453]
Pin 36 is used in multiple places.
platform: adc
pin:
number: 36
mode:
input: True
output: False
open_drain: False
pullup: False
pulldown: False
inverted: False
ignore_strapping_warning: False
drive_strength: 20.0
unit_of_measurement: V
name: KM217 5V Supply
accuracy_decimals: 2
update_interval: 5s
attenuation: 6db
filters:
- multiply: 28.1826
- throttle_average: 60s
disabled_by_default: False
force_update: False
device_class: voltage
state_class: measurement
raw: False
sensor.adc: [source /config/esphome/km271-for-friends-21c160.yaml:348]
platform: adc
pin:
number: 36
mode:
input: True
output: False
open_drain: False
pullup: False
pulldown: False
inverted: False
update_interval: 5s
attenuation: 6db
filters:
- multiply: 3.3125
force_update: False
raw: False
I had to remove these from config file, though afterwards everything seems to work fine, that’s why assume these are defined elsewhere.
And this raise the question for voltage multiplier; how can I adjust it, if I have to remove entire section for pin 36?
EDIT: figured out duplicated English entities! These are new English and original German ones, that I previously renamed directly in HA UI to English.
usually, entites removed from YAML should just disappear in HA. If not, you can remove them on HA side.
In the component itself, I do not use and GPIOs that have not been explicitly defined in the YAML file. Even the UART pins need to be defined in the UART section.
For the select drop-down, it is way more complicated to change their name, since this is defined in the code. I could rename it in code, but it will break the “legacy users” automations, if they defined some. I’m not sure, if I can somehow create “hidden” entries, so the component does not break for other users… I’m not sure, if I should touch it, since it could result in some support hell, when people update the component
I would also not suggest to delete the ESPhome device itself. I had strange problems doing this some time ago. Resolving it again took me hours crawling through the forums, many other websites and restarting HA multiple times.
Actually I already deleted device few times yesterday, hoping for being able to update configuration file before adopting device and potentially creating only English version of sensor first time. But no success, wehatever I did I always come up with first German version being created and only then adding English sensors. So I think the best option to not duplicate would be to just rename entities directly in HA, though it is time consuming process Perhaps once I stop fiddling with configuration and will treat installation as long term stable, this would be the route to go. Or translate using new config and delete old German entities…
So, for hardcoded selection text; in this scenario I think the easiest solution would be to create input_select helper with English selections and then use some automation to sync values (both ways) between original German selection and their translations in helper. I’ll try to work on this in coming days. For now I’m trying to figure out how to make sort of Buderus specific card to include in dashboard, by trying to make out of this the climate entity
BTW; I did not noticed screen bleaking again, so there had to be something different that module installation at my first try… perhaps I did not reconnected strong enough cables I had to disconnect to insert the module.
This also means that you can change the post title; it also works perfectly with R2105 S0
EDIT: perhaps I found the reason behind lost date/time setting of 2105; today I had ~15 minutes power outage and afterwards 2105 again lost time settings. Seems RTC lost power supply. Could be, that ESP is drawing enough power to drain battery to the level, that RTC looses settings? I’ve never experienced such situation before and power outages are happening ~once a quaret in my area, some lasting for few hours.
Another observation due to this power outage; afterwards card did not returnet to on-line state. I think it might due to not being able to obtain IP from DHCP, as it boots faster than AP it connects to. Could it be the case? Would it be the possible to either assign static IP in configuration or to retry obtaining lease until succesfull, after cold boot? Or am I misinterpetting situation?
Received my unit. Thank you @the78mole , great work! Playing around with it now.
Discussion above was helpful. A few remarks of my own, who knows it may help some-one else.
Before installing:
I ‘bench tested’ the unit before installing it. Just connected it to a USB supply (I had to dig deep in the left-over USB cables box to find that connector ).
I have a few dozen ESPHome devices in my HA setup, so some experience. It was easy to ‘adopt’ the preprogrammed unit into HA. I changed the .yaml file to include the English entity names. And I made some other updates to the .yaml file to reflect my personal best practice.
Installation:
I installed it in the correct slot (thanks for the heads up @mirekmal). And … it didn’t work. Just got a glowing red LED (what does that indicate?), no boot. Measured the 3.3V on the debug connector pads and that was fine. And yes I had changed the power select jumpers as needed.
Took it out the heater, connected USB power, all good.
Put it back in the heater, with USB power and … it didn’t work. Then I pushed the boot button and it booted!
So I changed to Buderus power again and it powered up without needing to push the button. Don’t know what going on there. Left it for now. Probably a dirty power up of the Buderus supply.
Wrapping up:
I have same issue as mentioned above, the German named entities do not go away. Everything is duplicated. I take it that the ‘name:’ statements in the English .yaml file only create an alias rather than change the friendly name of the entities.
I am disabling all the German named entities (there is a bunch of them) in HA, to clean up the installation a bit.
This one is interesting; putting calibration multiplier into configuration.yaml file causes error during compilation due to duplicated antry. So seems it is already hardcoded in original firmware. probably secondary template sensor will be required.
