Buffer I/O error on device sda8 [proxmox VM]
I’ve installed HAOS on proxmox VM, it is working OK, however recently I had two crashes (HA stopped working and VM was stuck on high CPU usage), and now I noticed the console is filled with these errors:
Where do I begin debugging this?
I had exactly the same issue after a reboot of the host.
Have you solved it? Seeing the same issue currently on my installation.
Thanks.
It probably means the disk is failing. Replace it.
in my case, my proxmox lvm went completely full which unfortunately corrupted the whole haos… I had two snapshots, which caused this issue.
I deleted one (older) snaphost, reverted to the newest, and also restored the most recent backup.
All working correctly afterwards.
Thanks a lot. I had the same issue and root cause. Deleting old stuff on local-lvm solved it.
Thank you @fraintt ! :slightly_smiling_face:
