I don’t know if this could be the right place to post it.
I found a bug in the temperature chart.
After many days of work the chart is frozen to a single value even thought the current temperature is different from what the chart shows.
I’ve this problem with both DHT sensor chart and Climate (using a DHT sensor).
As I said the temperature is displayed correctly and the climate sensor works good but when I click to see the chart it’s wrong…
This happened with the versinoe 0.57.1 and It happened today with 0.58.1
