Issue – After updating to the new core, the system automatically imported my Honeywell credentials and such from the config.yaml into the integration. However, I have 2 units and they are both controlled with the Connect comfort system. Only 1 unit is displayed and it will not find the other.
I have manually removed the integration and then added the integration back via the GUI. Same exact results.
I am rolling back the update in the meantime until we can figure this kink out.
Please let me know if you need any extra information from me.
To be clear, my issue is with the US Honeywell integration. I had been using the native HA integration, nothing to install or configure in the UI. I just included these lines in configuration.yaml:
I ended up restoring my pre-update snapshot, back to core-2021.7.4, and it’s again showing all three thermostats. Much as I’d like to keep current, this bug is a show stopper for me.
When I was (briefly) at core-2021.8.1, it did notify me that the config settings were deprecated and the Honeywell integration showed up among the integrations. Now I wish I’d taken some screen shots.
