Bug hunt: template sensor Time Online
hi,
stripping all bugs, im puzzled: this template sensor shows Unknown, or nothing as in ‘-’.
    since_last_boot_template:
      friendly_name: 'Since Last Boot'
      value_template: >
        {%- set s = states.sensor.since_last_boot.state.split('.')[0] -%}
        {{ s }}
Anyone see the error??
Cheers and thanks for looking,
Marius
Dev tools says it works fine, however I can’t see any error otherwise, assuming you have - platform: sensors: above it.
yes sure, its in an include file with all other small templates:
# Template Sensor
# https://home-assistant.io/components/sensor.template/
  sensors:
    day_night:
      friendly_name: "Day/Night"
      value_template: >-
        {% if is_state('sun.sun', 'above_horizon') %}
          Day
        {% else %}
          Night
        {% endif %}
      entity_picture_template: >-
          /local/day.png
        {% else %}
          /local/night.png
        {% endif %}
    dag_nacht:
      friendly_name: "Dag/Nacht"
      value_template: >-
          Day
        {% else %}
          Night
        {% endif %}
      icon_template: >-
          mdi:weather-sunny
        {% else %}
          mdi:weather-night
        {% endif %}
    solar_angle:
      friendly_name: "Sun Angle"
      unit_of_measurement: '°'
      value_template: "{{ '%+.1f'|format(states.sun.sun.attributes.elevation) }}"
    sun_state:
      friendly_name: "Sun State"
      value_template: >-
          up
        {% else %}
          down
        {% endif %}
    nextsunrise:
      friendly_name: Next Sunrise
      value_template: '{{ as_timestamp(states.sun.sun.attributes.next_rising) | timestamp_custom("%H %M %D") }}'
    nextsunset:
      friendly_name: Next Sunset
      value_template: '{{ as_timestamp(states.sun.sun.attributes.next_setting) | timestamp_custom("%H %M %D") }}'
    dayofyear:
      friendly_name: 'Day Number'
      value_template: '{{ now().strftime("%j") }}'
    weekofyear:
      friendly_name: 'Week Number'
      value_template: '{{ now().strftime("%U") }}'
    time_template:
      friendly_name: 'Time'
      value_template: '{{ as_timestamp(now()) | timestamp_custom("%d/%m   %H:%M", True) }}'
      value_template: >
        {{ s }}
    battery_telefoon:
      friendly_name: Marijns telefoon battery
      entity_id: device_tracker.telefoon
      unit_of_measurement: '%'
      value_template: >-
          {%- if states.device_tracker.telefoon.attributes.battery %}
              {{ states.device_tracker.telefoon.attributes.battery|round }}
          {% else %}
              {{ states.sensor.battery_telefoon.state }}
          {%- endif %}
      icon_template: >
          {% set battery_level = states.sensor.battery_telefoon.state|default(0)|int %}
          {% set battery_round = (battery_level / 10) |int * 10 %}
          {% if battery_round >= 100 %}
            mdi:battery
          {% elif battery_round > 0 %}
            mdi:battery-{{ battery_round }}
          {% else %}
            mdi:battery-alert
          {% endif %}
my dev tools say:
1104
In the states table in dev tools search for since_last_boot use ctrl-f and type that in, see if there is another one under sensors?
nope there isn’t. Ive found a missing - behind the >, but adding that doesn’t change it.
Strangely enough the sensor in the detailed view says its up for 3 hours. just rebooted, and also states uptime in minutes. Nothing in the badge though. Might that be because of the custom ui?
sensor.since_last_boot_template:
  icon: mdi:av-timer
  state_card_mode: badges
  friendly_name: 'Up'
Seems a likely candidate :), I can’t comment as I don’t use it.
apparently that is not the culprit ;-(((
4956
What if you just try:
value_template: {{ states.sensor.since_last_boot.state.split('.')[0] }}
Mine shows the above, with the exact code you posted :slight_smile:
EDIT: Just realised that might be from system monitor :frowning: - retrying with that commented out
@VDRainer in dev tools it doesn’t like states however I’ve not tried doing it that way in the code :slight_smile:
EDIT: 2 this now works, so system monitor was causing it to not work.
In the above remove _template and see what that gives.
What I think is happening is that sensor.since_last_boot is not defined in the first place, I could only get the template to work if system monitor was defined, which in turn creates sensor.since_last_boot
If you put the above in dev-tools->templates what happens?
of course i had the system monitor declared, but not with type since_last_boot… duh, sometimes
rebooting now, see what gives
–edit–
Bingo! 27
So this sensor template isn’t a sensor in itself, it is a sensor that reads the output from another entity. Hence the template… tss
what does that do actually? seen it before even copied it with succes :slight_smile: not sure what is does to be honest.
even made the custom ui:
59
its showing the time of the last boot, not the time since last boot though…
and its an hour off :wink:
happy tweaking.
