I found that a automation had not been running as it should. A value template to check that the current month is not december or january fails. If I test the template in developer tools, it shows true. But in my automation template, it is false.
I also tried via developer tools to show current month and it shows ‘4’. Both expressions below (I also now tried a simpler version) will show true in developer tools. But not in automation.
Just to illustrate @TheFes’s answer for anyone that stumbles on this thread in the future… The condition should look as follows when set up in the UI Automation Editor:
