Just updated to 0.99.2 (from 0.91.2) and noticed that no matter what IP I am logged in from, the UI shows that the token I am using is last used from 192.168.1.1
Is this a bug in HA, or should I try to find something wrong with my network setup?
Do you use a reverse proxy? If you do, all addresses will come from the proxy unless you configure http settings with the proxy and allow_x_forwarded_for.
No. I don’t use revers proxy.
Last time I checked (on 0.91.2) I could see the correct IP address.
But except of upgrading Home Assistant I have also switched gateway and change provider for dynamic DNS. So the question is if it is a bug or if it is in my network setup?
