[BUG] iPhone location/timer not being updated correctly
Hi all!
I’ve migrated to 0.76 yesterday. After a very troubling start (I needed to do a clean install and copy back my config) i’m encountering some issues.
The issue I’ve found is that my iOS devices don’t update their location correctly. I’m not sure yet if the location itself isn’t updated or its just the “timer” which says “updated X minutes ago”. I’ve got a HASSIO setup running which showed this behavior. To make sure it wasn’t my HASSIO installation i also created a new fresh installation (by using a docker container on Ubuntu 17.10). This fresh installation showed the same behavior.
i’m currently suspecting the combination of the new auth system being implemented into Home Assistant and the fact that the iOS app wasn’t updated for 9 months already.
Note that the behavior occurs even when I press the “update location” arrow in the left bottom corner of the app.
Help would be appreciated!
Kind regards,
Rob
