My Aqara Hub M1S doesn’t show subdevices both in matter mode and homekit mode in Home Assistant it does show up but it doesn’t have any subdevices which is weird because I have got a Aqara Cube connected to my Aqara Hub M1S which has firmware version 4.0.2 so compatible with Matter Aqara also says that the cube should support matter after Aqara Hub M1S is updated to firmware version 4.0.2 which I have so I suspect that it is Home Assistant because the matter addon is showing random chip activity after I move the cube so it isn’t showing in Home Assistant even if it is supported by my subdevice which is strange because the Matter addon reports chip activity in the log which I didn’t have before connecting the hub I deleted the previous post because I didn’t have enough info also it just randomly posted as I typing
