Hello.
I think I am suffering a bug on lovelace using the code editor. As you can see on the gif below, when I select certain lines and I delete them, the remaining lines get merged in a weird way:
This is super annoying because it’s hard to spot, and all you notice on the first place is that some entities are no longer visible on the preview pane, leading to incorrect configurations
I’m using chrome on MacOs.
I don’t understand why it is not possible to just edit the YAML file even if you are in managed mode. After all you can do that with the edit raw configuration, so I don’t see the point to limit it.
