Bug report to ALSA Developers / Audio log
Going through my system logs after restoring from backup. AFIK, do not have a problem to solve related to audio.
I found the audio log (below) with this entry near the bottom,
> “Most likely this is a bug in the ALSA driver ‘snd_bcm2835’. Please report this issue to the ALSA developers.”
So that’s what this is. If you know a better place to report, please let me know.
Log follows.
  • David
    ———————.p
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
cont-init: info: running /etc/cont-init.d/filesystem.sh
cont-init: info: /etc/cont-init.d/filesystem.sh exited 0
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service alsa: starting
s6-rc: info: service alsa successfully started
s6-rc: info: service alsa-init: starting
[11:29:50] INFO: Adjust ALSA mixer settings for /dev/snd/controlC0
s6-rc: info: service alsa-init successfully started
s6-rc: info: service pulseaudio: starting
W: [pulseaudio] main.c: Running in system mode, but --disallow-module-loading not set.
W: [pulseaudio] main.c: Home directory of user ‘root’ is not ‘/var/run/pulse’, ignoring.
W: [pulseaudio] caps.c: Normally all extra capabilities would be dropped now, but that’s impossible because PulseAudio was built without capabilities support.
W: [pulseaudio] main.c: OK, so you are running PA in system mode. Please make sure that you actually do want to do that.
W: [pulseaudio] main.c: Please read What is wrong with system mode? – PulseAudio for an explanation why system mode is usually a bad idea.
W: [pulseaudio] module-udev-detect.c: Failed to open /proc/asound/card0: No such file or directory
s6-rc: info: service pulseaudio successfully started
s6-rc: info: service legacy-services: starting
s6-rc: info: service legacy-services successfully started
s6-rc: info: service legacy-services: stopping
s6-rc: info: service legacy-services successfully stopped
s6-rc: info: service pulseaudio: stopping
[16:20:35] INFO: Service restart after closing
s6-rc: info: service pulseaudio successfully stopped
s6-rc: info: service alsa-init: stopping
s6-rc: info: service alsa-init successfully stopped
s6-rc: info: service alsa: stopping
s6-rc: info: service alsa successfully stopped
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
[10:22:06] INFO: Adjust ALSA mixer settings for /dev/snd/controlC0
E: [alsa-sink-bcm2835 Headphones] alsa-sink.c: ALSA woke us up to write new data to the device, but there was actually nothing to write.
E: [alsa-sink-bcm2835 Headphones] alsa-sink.c: Most likely this is a bug in the ALSA driver ‘snd_bcm2835’. Please report this issue to the ALSA developers.
E: [alsa-sink-bcm2835 Headphones] alsa-sink.c: We were woken up with POLLOUT set – however a subsequent snd_pcm_avail() returned 0 or another value < min_avail.
