When I send this call to the HA websocket:
{“id”:1530842966449005,“type”:“call_service”,“domain”:“light”,“service”:“turn_on”,“service_data”: {“entity_id”:“light.ge_unknown_type5044_id3038_level”,“brightness”:40}}
The light turns on, and I get the expected acknowledgement:
{result: null, success: true, type: “result”, id: 1530842966449005}
However I don’t get a state_change event on the light.ge_unknown_type5044_id3038_level entity.
If I second request:
{“id”:1530843255276006,“type”:“call_service”,“domain”:“light”,“service”:“turn_on”,“service_data”:{“entity_id”:“light.ge_unknown_type5044_id3038_level”,“brightness”:60}}
I get a state_change even that indicates the state changed from “off” to “on” even thought the light was already on as a result of the first call
I work around this on my custom front-end by making every call twice. However when I ask Alexa to “Set Brightness” it only makes one call, which means I don’t see a state_change event for the light, and I don’t know to update my Front-End UI
Is this a bug?
