Hello, I hope I put this post in the right section?
I would like to define a service call: remote.send_command with more than just one command.
In yaml that would be something like this:
command:
- home_hold
- select
I could not find out, how to define that using the UI-Editor.
So I went to the script.yaml and edited that lines manually.
The script then woks fine.
If I open this script in the UI-editor then these lines are changed to:
command: home_hold,select
Afterwards this script does not work anymore.
