Bug with automation aliases
Hi there.
Since version 0.92.1, the trigger in my automation does not work.
I’ve been struggling to find the reason. Using the automation editor, I could have it running sometimes, and sometimes not.
After days of tests, I finally discovered the issue was the alias.
Any previously existing automation alias prevent the trigger to work.
If I rename the alias, it works fine.
Everything else work. Meaning related actions can be triggered manually.
What can cause this ? Is there anyway I can “clean up” the old aliases which might create this bug ?
I ended up renaming all my aliases and it fixed my problem.
Still this is a weird bug and might deserve a lookup.
Are they in quotes (particularly if you have spaces in the alias)?
- id: mains_power_fail_alert
  alias: 'Mains Power Fail Alert'
  initial_state: true
Some example show this, others don’t. I’ve always wrapped my aliases in quotes and haven’t had a problem.
I used to wrap my aliases in quotes, but now I only do that when linter/config checker complains :wink:
