Took the leap with the new naming scheme and seems ran into a bug.
Have a qubino 1D relay that was working perfectly. And now in the frontend it is always on.
Although all the rules wih motion sensor continue to work so seems it’s not reporting back the state change…
So before the leap it was named switch.qubino_zmnhnd1_flush_1d_relay_switch_7_0
Now from the dev page (you can see that it is on although the light is off and i have flipped the on wall swich several times without success)
switch.kladovka_switch on value_instance: 1
icon: mdi:lightbulb
friendly_name: Свет кладовка
value_index: 0
new_entity_id: switch.kladovka_switch
old_entity_id: switch.kladovka_switch_7_0
assumed_state: false
node_id: 7
And another one
zwave.kladovka Ready node_name: kladovka
is_info_received: true
receivedDups: 0
node_id: 7
friendly_name: kladovka
new_entity_id: zwave.kladovka
averageResponseRTT: 0
sentFailed: 0
product_name: ZMNHND1 Flush 1D relay
neighbors: 1,2,3,4,5,6,8,9,10,12
receivedTS: 2017-06-26 10:33:45:524
receivedUnsolicited: 0
is_awake: true
old_entity_id: zwave.kladovka_7
retries: 0
averageRequestRTT: 28
lastRequestRTT: 24
capabilities: listening,beaming,routing
max_baud_rate: 40000
lastResponseRTT: 0
manufacturer_name: Qubino
is_zwave_plus: true
sentCnt: 12
query_stage: Complete
is_ready: true
receivedCnt: 0
sentTS: 2017-06-26 10:42:54:260
is_failed: false
Any ideas on this one? The only weirdness i see is than in OZWC qubino reports status as on/off while fibaro’s are 0/1
