Hi everybody,
i wanna share with you a couple of bugs:
after you immediately load companion, the frontend is displayed within the screen WITH the bottom bar/navigation bar even if you 've set up companion to hide it . if in the android bar mentioned, you open the “already open apps menu” then you select again companion, it fits correctly as i was expecting it(hiding to android bottom bar)
this bug occurs after the latest update,so i think is strctly connected.
the second bug i found is about home assistant core(i suppose), and it has to do with dateformat and input_datetime: if you use in automation as i did, trigger:time and try to set a trigger in an automation that has to match an already setup input_datetime field, the trigger doesnt work as it did fo a couple of years.
curiously, while checking if this was the problem, i decided to add to the trigger a delay of 00:00:01 (1 second) and it started working again.
did somebody work with date format,maybe?
regards
