The buienradar website shows there are weather stations in Belgium, but only Netherlands stations are included so far in Hassio. As buienradar has the best rain forecast accuracy, it would be great to include the BE stations as well.
The integration shows that you can configure this for BE and so says the manual
Buienradar - Home Assistant (home-assistant.io)
Hi, thanks for the reply.
The BE in the configuration is related to the satelite images.
If you click on that page you shared to show the map of weather stations, you will see they are restricted to the Netherlands.
Then you should raise that with the developer as a feature request, this is a community and will not act on post like this.
Thanks for pointing that out. I came her because the page below says to come here in case of feature requests. Where/how would you suggest to reach out?
You are right, it is an internal functionality hence you are OK… although I am not directly affected…will vote…please also vote for yourselves
Some relevant answers to this feature request were provided here Buienradar belgium weather stations · Issue #77938 · home-assistant/core · GitHub
Buienradar Belgium does not have the relevant APIs available at this time.
I was also looking for a good source of weather data, and found the KMI app. It uses an api (https://app.meteo.be).
By looking at the code of the app, I managed to figure out how it works. However, I’m not a coder … So I’m looking for someone who could help me in creating an home assistant integration based upon the KMI api.
woul be nice to get data from meteo.be
Yeah looking for a solution for belgium too!
Would like rain forecast too (local)
I created a custom integration to get data from IRM KMI app (meteo.be) in Home Assistant. You can have a look here: Belgium weather provider: IRM / KMI (meteo.be)
As of version 0.2.6
, the integration provides the following:
- A weather entity with current weather conditions
- Weather forecasts (hourly, daily and twice-daily) using the service
weather.get_forecasts
- A camera entity for rain radar and short-term rain previsions
- A binary sensor for weather warnings
- Sensors for pollen levels
Hi @jdejaegh, thank you for the meteo.be addon! It seems to offer similar (and more?) features as the buienradar addon. I’m curious to see if it will be added to core!
This request was closed because the API wasn’t available for Belgium but I sent another request to expose the BE data on Buienradar.be - Contactpagina servicedesk
Kind regards
I do not plan to add it to core in the short term.
There are things to change in order to add it to Home Assistant core, mainly move the API communication to its own package on PyPI. Currently, all the API communication is done in the integration. Home Assistant requires core integrations to have the API communication as a dependency hosted on PyPI.
