Ive updated my main config to 94.4, and all is working except for the Buienradar sensors. I use the exact same config on a 94.3 system, and used it up to yesterday on a 84.3 system (which now has updated…) and they were and are (94.3) showing just fine.
We didn’t see a breaking change for Buienradar have we?
Still showing data for me, try restarting again and check the logs. Sometimes it might just be weird.
Also, if you changed from your configuration to not use long/lat from your config file but instead via the gui the lat/long might change slighty if you point it on the map resulting in a different one. When that happens you will get new ones with _2 at the end. (i had that when i moved)
hi thanks for chiming in.
I am afraid that’s not it, as you can see, Ive only entered br_ in the dev-state, which should reveal all br sensors, also the _2 ones if they were there.
there’s something else going on, I have ridiculous timing lags and issues, Ive never experience before.
For now am slowly taking the setup apart again… hoping to find a culprit for the lags.
2019-06-23 23:26:23 ERROR (MainThread) [homeassistant.core] Error doing job: Future exception was never retrieved
File "/usr/src/homeassistant/homeassistant/components/proximity/__init__.py", line 127, in check_proximity_state_change
proximity_latitude = zone_state.attributes.get('latitude')
AttributeError: 'NoneType' object has no attribute 'attributes'
2019-06-23 23:26:59 ERROR (MainThread) [homeassistant.components.hue.light] Unable to reach bridge 192.168.1.212 ()
2019-06-23 23:27:26 ERROR (MainThread) [homeassistant.components.hue.sensor_base] Unable to reach bridge 192.168.1.212 ()
2019-06-23 23:27:26 ERROR (MainThread) [aioasuswrt.connection] Host timeout.
2019-06-23 23:27:49 ERROR (SyncWorker_15) [homeassistant.components.rest.sensor] Error fetching data: <PreparedRequest [GET]> from https://redacted failed with HTTPSConnectionPool(host='redacted'): Read timed out. (read timeout=10)
2019-06-23 23:28:04 ERROR (MainThread) [homeassistant.components.hue.sensor_base] Unable to reach bridge 192.168.1.212 ()
2019-06-23 23:28:26 ERROR (MainThread) [aioasuswrt.connection] Host timeout.
2019-06-23 23:29:05 ERROR (MainThread) [homeassistant.components.hue.sensor_base] Unable to reach bridge 192.168.1.212 ()
2019-06-23 23:29:05 ERROR (MainThread) [pyhaversion] Timeouterror fetching version information for hassio
2019-06-23 23:29:35 ERROR (MainThread) [aioasuswrt.connection] Host timeout.
2019-06-23 23:29:55 ERROR (MainThread) [homeassistant.components.hue.sensor_base] Unable to reach bridge 192.168.1.212 ()
2019-06-23 23:29:56 ERROR (MainThread) [aioasuswrt.connection] Host timeout.
2019-06-23 23:30:16 ERROR (SyncWorker_13) [homeassistant.components.waze_travel_time.sensor] Error on retrieving data: Cannot get coords for Amsterdam, NL
2019-06-23 23:30:28 ERROR (MainThread) [homeassistant.components.hue.sensor_base] Unable to reach bridge 192.168.1.212 ()
2019-06-23 23:30:31 ERROR (MainThread) [homeassistant.core] Error doing job: Fatal error on transport
File "uvloop/sslproto.pyx", line 574, in uvloop.loop.SSLProtocol._do_shutdown
File "/usr/local/lib/python3.7/ssl.py", line 767, in unwrap
return self._sslobj.shutdown()
ssl.SSLError: [SSL: KRB5_S_INIT] application data after close notify (_ssl.c:2609)
2019-06-23 23:30:39 ERROR (MainThread) [aioasuswrt.connection] Host timeout.
2019-06-23 23:31:01 ERROR (SyncWorker_14) [homeassistant.components.waze_travel_time.sensor] Error on retrieving data: empty response
2019-06-23 23:31:20 ERROR (MainThread) [aioasuswrt.connection] Host timeout.
2019-06-23 23:31:21 ERROR (MainThread) [homeassistant.components.hue.sensor_base] Unable to reach bridge 192.168.1.212 ()
2019-06-23 23:31:36 ERROR (MainThread) [homeassistant.components.hue.sensor_base] Unable to reach bridge 192.168.1.212 ()
2019-06-23 23:31:37 ERROR (MainThread) [aioasuswrt.connection] Host timeout.
2019-06-23 23:31:43 ERROR (MainThread) [homeassistant.components.generic.camera] Timeout getting image from: Weer Roosendaal
2019-06-23 23:31:49 ERROR (MainThread) [homeassistant.components.generic.camera] Timeout getting image from: Buienradar
2019-06-23 23:32:27 ERROR (MainThread) [homeassistant.components.hue.sensor_base] Unable to reach bridge 192.168.1.212 ()
That a lot of error messages… indeed there is something more going on then just the buienradar on your side. I wonder which one it was, do tell always good to know (also for others)
